Smoke coming from exhaust
07-16-2015, 06:23 PM | #4 |
Rep 632
Sounds like bad turbo's to me! The most common and frequent smoking cause!
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
07-29-2015, 10:22 AM | #5 |
Rep 1,869
So i am in the same situation. What can i expect down the line. Holding boost just fine, def lacking low end as described, burning about 2 quarts every 5k.
07 335xi (2007-2010)
08 Legacy Spec B (08-) 09 335i (2010-) 15 X5 xdrive 35i (2015-) 17 Forester XT (2016-) |
07-29-2015, 11:52 AM | #6 |
BimmerPost Supporting Vendor
24491
Rep 191,486
take it to a mechanic and let them check your turbos. If your turbos are shot replace them under warranty at the dealership ( if under 82k miles). If not time for some RB
07-29-2015, 12:03 PM | #7 |
these are the times that try mens soul's
37
Rep 280
07-29-2015, 02:11 PM | #8 |
Joint Chiefs of Staff
4927
Rep 116,037
If its predominantly one pipe the sounds like a turbo / turbo seal going. Its just going to get worse before completely failing. Depending on whats wrong you may have a bad failure so I would definitely get this looked at.
Mike |
07-29-2015, 02:13 PM | #9 |
Rep 162
Update: got the car diagnosed and the laggyness/smoke is caused by gunked up vanos solenoids and because of a worn out valve cover gasket thus leaking oil
07-29-2015, 02:14 PM | #10 |
4927
Rep 116,037
07-29-2015, 02:19 PM | #11 |
Rep 162
Indeed its crazy how a simple wear and tear part going bad on these motors will cause your car to go into full retard mode, Thanks for the advice everyone!
07-29-2015, 02:22 PM | #12 |
24491
Rep 191,486
Thats great news, im glad its all good now
07-29-2015, 09:38 PM | #13 | |
Rep 1,869
For Future reference, Any one with experience with turbo replacement basically fbo without the dps? I know the risks of going in with any mod, would only like responses from people with experience. I only have my stock intake with me, FMIC i cant see being problem, my cp blew last week and i do have dp back exhaust.
07-29-2015, 10:00 PM | #14 | |
24491
Rep 191,486
07-30-2015, 06:40 AM | #15 | |
4927
Rep 116,037
Mike |
07-30-2015, 11:28 AM | #16 | |
24491
Rep 191,486
You might be better off just getting the vargas stage 1 turbos or a cheap stage 2 turbos
07-31-2015, 09:33 AM | #17 | |
Rep 1,869
08 Legacy Spec B (08-) 09 335i (2010-) 15 X5 xdrive 35i (2015-) 17 Forester XT (2016-) Last edited by Lshaw; 08-03-2015 at 09:58 AM.. |
07-31-2015, 09:40 AM | #18 |
Rep 950
I dont think any turbos are "cheap", not the ones I want on my car anyway
2010 E90 335i Le Mans Blue Metallic // Saddle Brown // M Sport // iDrive // Comfort Access // Blown By Twins
