BIMMERPOST Universal Forums Off-Topic Discussions Board Computer help!
      07-16-2015, 09:45 PM   #1
Taskmaster
Japan
2482
Drives: M235i 6MT / E92 328 Msport 6MT
Computer help!
Help!!
Computer is a Lenovo U410 I5 with 6GB of ram, running windows 8.
unfortunately, it went into hibernation one day and decided not to wake up...ever.
Sonthe problem is I cant recover the computer at all. Contacted Lenovo and bought recovery disk, and those didn't work, as the disk was defective. Had them send me another set, and the system will quit partially theough, do to a missing file/unable to read file. I even had a friend supply me with Windows 8.1 ISO, and I'm trying to use that.
Here is the problem though, I can't format the drive. At all.
defective harddrive, better software..what's going on?
I have an 80GB I popped in and it worked to format windows and is installing it fine..but my 500GB took forever to even read, muchless attempt to install windows 8.
Wtf is going on?
      07-16-2015, 09:46 PM   #2
Who's on first
Who's on first's Avatar
Drives: A-10C
Buy a Mac.
      07-16-2015, 09:51 PM   #3
Delta0311
Drives: 2011 BMW 335xi E92 2016 228xi
For starters get windows 7. Windows 8 is an absolute piece of garbage, it's pretty much windows ME all over again. And if a drive won't format then it is safe to say it is shot.
      07-16-2015, 09:56 PM   #4
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
Drives: Deezul
If it's stuck at BIOS and not booting Windows, then it's your hard drive.
Deleted, ATM I/C and tuned by B.R.R.
      07-16-2015, 09:59 PM   #5
Taskmaster
Japan
2482
Negative Captain, I don't have that option. I am working with what I have, but you believe that the hard drive is toast?
      07-16-2015, 10:07 PM   #6
The Automotive Enthusiast
Retired BMW Genius
The Automotive Enthusiast's Avatar
Drives: 2018 Audi S5 Coupe
Sounds like your HD is on its last legs.
You need a Mac. I've converted three of my friends, and they are never going back.
Last edited by The Automotive Enthusiast; 07-16-2015 at 10:08 PM.. Reason: Whoops, spelling.
      07-16-2015, 10:07 PM   #7
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
Drives: Deezul
You should have a BIOS, it's based from the motherboard. The hard drive most likely went to crap and thus making not run any programs. You can possibly still save it and install another 500GB+ HD, and depending on the SATA ports available, hook the bad HD to it as well and maybe view the files.
      07-16-2015, 10:09 PM   #8
Taskmaster
Japan
2482
UltraBook, so I can't really do any of that. Any free programs to test the HD.
      07-16-2015, 10:17 PM   #9
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
Drives: Deezul
Damn, a laptop? It's anybodies game with those, as a lot of the parts are integrated. I'm really not too familiar with the repair of laptops. Hopefully someone else can guide you better with those.
      07-16-2015, 10:27 PM   #10
Delta0311
The hard drive will be a SATA drive and it is not built into the laptop. You can remove it and replace it. You can then buy a SATA reader. Basically you plop the drive into it like a NES cartridge and the connect it to your PC via USB. Most likely you will be able to at least get your data of off it.
      07-16-2015, 10:30 PM   #11
Delta0311
Here is the disassembly instructions.
Fairly easy to get to the HD.
      07-16-2015, 10:35 PM   #12
Taskmaster
Japan
2482
Already disassembled and harddrive removed.
So:
500GB HD
Recovery disk don't work
USB boot/Windows install takes forever to boot
Attempted to reinstall windows from USB, but Windows installer cannot format drive
60GB HD
USB Boot/windows install works instantly
Windows formatted drive just fine.
Bad harddrive?
      07-16-2015, 10:41 PM   #13
FL335
Drives: 2009 335i
Seriously...throw the HD/tower in the ocean and buy a Mac..problem solved for like 20 years. OR buy another PC and deal with the same sit every 5-6 years....Profit.
      07-16-2015, 10:50 PM   #14
Hard drives are hard drives, Mac or not. They're just as likely to die in a Mac as they are in a PC. I use Windows and Mac all day long. Both have their bugaboos and both have their charms. But the hard drives are identical equipment. Buying a Mac won't prevent or even reduce hard drive failure.
      07-16-2015, 10:57 PM   #15
FL335
Drives: 2009 335i
Seriously...that's like saying an engine is an engine....a Renault will easily be as reliable as a Honda....
Nonsense. Not only is it way off, it's not in the same atmosphere.
      07-16-2015, 11:01 PM   #16
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
You do realize Apple doesn't make its own drives right? They are samsung drives and yes I'm an Apple user.
      07-16-2015, 11:03 PM   #17
GregTheStig
derp
GregTheStig's Avatar
Armenia
51
Drives: a Tuk Tuk
ITT: 2 people provide useful advice and everyone else jerks off Apple.
Taskmaster2481.50
      07-16-2015, 11:05 PM   #18
Delta0311
Oh good God. (Insert face palm)
Apple DOES NOT make its own components. CPU is Intel, video cards are nvidia, hard drives are what ever vender has cheapest, and mother boards are proprietary but made at FOXCONN (China) using standard components. The only thing that makes a Mac so different than a PC is the OS. Yes the MAC will fail like any other PC. Components do not last forever.
      07-16-2015, 11:15 PM   #19
Whostheboss
Whostheboss's Avatar
424
Drives: a 9incher
The 500GB disk probably has slow read speed. Do you know what the read write speed is?
The 60GB disk is probably faster.
That's my guess.
Get yourself a 128GB SSD and install your windows there.
Newegg.com always have the best deals
WHO'S THE BOSS
      07-16-2015, 11:16 PM   #20
FL335
Drives: 2009 335i
Apple DOES NOT make its own components. CPU is Intel, video cards are nvidia, hard drives are what ever vender has cheapest, and mother boards are proprietary but made at FOFCONN (China) using standard components. The only thing that makes a Mac so different than a PC is the OS. Yes the MAC will fail like any other PC. Components do not last forever.
Come on! Seriously....anything PC is Fkn garbage...ive had a macbook for years, no issues. My last windows anything...lasted only a few years. Shit gets a llo bogged down and banged up.
Look...I get it. Using mac isn't mainstream but PC is dead...beleedat.
      07-16-2015, 11:19 PM   #21
dreamingat30fps
OP just buy a new drive, put windows on it then install the old drive as a secondary drive and see if you can pull anything off it and call it a day. Or you can even get one of those drive cloners off Amazon for $20 and see if you can clone the old drive onto a new one. Drives are cheap.
      07-16-2015, 11:21 PM   #22
Whostheboss
424
Drives: a 9incher
Hahahaha
1st) i don't like the term PC. They're all PC to me.
2nd) i have both. I built my Windows machine with quality parts and it works great.
3rd) i like both but if i were to pick only one, i'd go with the Windows.
Because of its open flexibility. Apple controls too much.
WHO'S THE BOSS
