Help with misfire codes
07-21-2015, 07:00 AM | #1 |
Rep 125
I have an early N54 with 74,000 kms
Im running DCi's, JB4 and decats. Im getting misfires, generally on cylinder 5. I have replaced all the plugs and the coil on cylinder 5. I therefore went back out to do a few runs and reads the codes again. run 1 - Cylinder 5 misfire run 2 - cylinder 5 misfire run 3 - cylinder 5 misfire, cylinder 3 misfire, multiple cylinder misfire run 4 - cylinder 5 misfire, cylinder 3 misfire, multiple cylinder misfire. I typically get cylinder 5 misfire if im full power from low revs. But get the 3 codes if I full power say from 4krpm. Im reluctant to think its an injector as although its typically cylinder 5, I do get misfires on multiples cylinders. I though LPFP would only affect a bank of 3 cylinders. Not sure what the HPFP symptoms are, and same with carbon deposits. I, running map 2 which seems to make the issue worse, but it still misfires on map 0. What should I do next to identify the problem? |
07-21-2015, 08:36 AM | #2 | |
Joint Chiefs of Staff
4927
Rep 116,037
Mike |
07-21-2015, 10:42 AM | #4 | |
Rep 125
Hi Mike, Thanks for your advice. So you think injector 5 although I sometimes get codes 29CF (misfire on cylinder 3) and 29CC (misfire on multiple cylinders)? |
07-21-2015, 10:49 AM | #5 |
Rep 125
07-21-2015, 11:57 AM | #6 |
BimmerPost Supporting Vendor
24512
Rep 191,506
Start by swapping the injector and see if code follows
