HELP ME!!!! Post DP Fix
07-24-2015, 01:17 AM | #1 |
Rep 2,486
Hey guys, I have been having some lean codes after I pulled and during the DP fix. Im 99% sure I put the wires in the correct place. Currently my car is FBO, Im running ST2+, I might still have some E85 left in the tank from the last fill up but it should be close to nothing. I cleared the codes a couple of times but after a 15-20 mile drive the codes come back up. I took some logs while normal driving, and some more aggressive driving. I was too scared to push it any harder with the CEL
I did recently put new coil packs in myself, could maybe that be the problem? Maybe I didn't install them correctly? Codes: P0174 P0171 P29E0 P29E1 Log 1 http://datazap.me/u/335mi6/log-1-fbo?log=0&data=1-9-22 Log 2 http://datazap.me/u/335mi6/log-2?log=0&data=1-9-22 Log 3 http://datazap.me/u/335mi6/log-3?log=0&data=1-22 Last edited by 335_MI6; 08-03-2015 at 02:31 PM.. |
08-03-2015, 03:44 PM | #3 |
Rep 2,770
Are you sure you installed the fix on the secondary and not one of the primaries?
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
08-03-2015, 04:35 PM | #4 |
Rep 2,486
08-08-2015, 09:53 PM | #7 |
Rep 2,486
So long story short the codes came back after I reset my adaptations with inpa... So I swapped the two pins/wires in the ecu and drove it around for roughly 35 miles and only some of the codes came back. Only the fuel mixture ones did
P0171 P0174 So I'm literally all out of ideas... Any one have any? Other then replacing the entire car/motor/ecu lol |
08-09-2015, 01:47 PM | #9 |
Rep 258
Have you changed the dial settings on the dp fix? Some cars do not work well with the default setting.
His: '21 Kia Telluride SX
Hers::'19 Lexus Ux250h F-sport His: '67 Jacobsen Tractor Formerly His:'09 335 xdrive |
08-09-2015, 03:08 PM | #10 |
Rep 2,486
08-10-2015, 12:12 PM | #11 |
Rep 258
Sorry, I misunderstood what you were describing. Please take a picture of the sub connector, just to verify the pins are all in their correct slots.
Good luck
08-10-2015, 02:37 PM | #12 |
Rep 2,486
