Need some help.. with n52
07-24-2015, 05:23 PM | #1 |
Rep 25
Car is throwing p0015 from standard scan tool..
I swapped the vanos solenoids, and tested with 12v, working. the code did not change and remained the same I changed the CPS and nothing changed Symptoms only show after car is driven for about 30 minutes rough idle and car will stall when you hit the brakes. i'm stumped at this point. |
12-01-2015, 09:25 AM | #3 | |
What am I doing here?
190
Rep 463
Car drives fine initially but eventually goes into a limp type mode where it seems to run very rich or something that causes the throttle response to be sluggish and the engine wants to stall when I take it out of gear. Similar to the symptoms you had.
N52 : 6MT : ZSP : ZPP : BC Racing Coilovers : BMW PE
