07-27-2015, 06:15 PM | #1 |
Rep 290
Anyone running 275 rears on a 335 m-sport?
I have a 2014...considering a set of RE11s with 245 front and 275 rear, stock suspension (for now),
Any rubbing issues? Any photos out there? Thanks! |
07-27-2015, 06:19 PM | #2 | |
Rep 1,134
07-27-2015, 07:50 PM | #3 |
Rep 1,035
does a 2014 328i m-sport count? i don't know what the fender differences are between a 328 vs 335, but i'm running 275/30/19, and lowered pretty significantly (not slammed) ... but no rubbing at all.
And i could go down another inch or two without issues... Ok, maybe only an inch... Last edited by squidlyboy; 07-27-2015 at 08:40 PM.. |
F30_SixSpeed1170.50 |
07-29-2015, 11:09 PM | #9 |
Rep 516
you can run 245-30 and 275-30 with no rubbing issues, even with coils. Just get the correct offset and the right brand of tires and you will be good to go.
F30 with H&R Spring 245-35-20 & 275-30-20 F30 Suspension ? 245-30-20 & 275-30-20 F30 on Coilovers 245-30-20 & 275-30-20 F30 on Coilovers 245-30-20 & 275-30-20 F30 on Coilovers 245-30-20 & 275-30-20 |
07-30-2015, 05:51 AM | #10 | |
Rep 117
I know for the front a 8.5x19 ET35 with a 245/35R19 is perfect but in the rear a 9.5x19 ET40 with a 275/30R19 I think the wheel is too narrow and it makes the tire (in my case Continental DW) fat, I was going to buy another set of 19x10 ET45 and mount my 275/30R19 on it and see but I have to spend more $$$... That is why I am interested. I have a post with my new setup here http://f30.bimmerpost.com/forums/sho....php?t=1151667
07-31-2015, 10:22 AM | #11 |
Rep 72
I am running Avant Garde M510 19×8.5 et35 in front, 19×9.5 et40 in the rear. Tires are 245/35 and 275/30. Stock 335i M-sport suspension (with DHP). Absolutely love the setup! I do not think it is too aggressive and is perfectly flush. Considering Dinan springs and Shockware software for the DHP.
Mike
2018 M3 ZCP 6 MT |
Dreamvillainz135.00 |
07-31-2015, 02:24 PM | #14 | |
Rep 516
08-03-2015, 09:56 AM | #15 |
Rep 7
20*8 offset 36, 20*8.5 offset 42, 405m
I'm new to all of this so please excuse my noob questions. First of all what are coil overs? Second of all, I wanted wider tires for my 405m wheels, will the 245/30/20 and 275/30/20 setup work or should I stick to 225/35/20 and 255/35/20? Also, I wanted all seasons performance tires, since im getting rid of my pirelli pzero run flats. Would matching different brands be a bad idea? I was think of continental dws all seasons in the front since they come in 225/35/20 and michelin pilot sport as3s in the back, since they have a speed rating of Y where as the rear continentals have a speed rating of W, or the Y or W speed rating would not make a difference, since my f30 maxes out at 160mph. Thanks guys.
08-14-2015, 04:06 PM | #16 |
Rep 528
Just for comparative purposes, I'm running a 295/25/20 on 10.5 ET 45 wheel in the rear with H&R sport springs. The only time it has rubbed was with 3 adults in the back seat.
'14 SQ5
'13 Land Cruiser '94 TT Supra Hardtop |
08-27-2015, 11:12 PM | #17 |
Rep 72
Hello guys, been looking around to purchase a set of tires for my 320d M Sport with Style 400M wheels.
Is it possible to use 275/35r18 for the rear wheels with the 400M? Any rubbing issue with it? Or would 275mm too wide to fit on a 8.5JJ rims? I'm asking this because the tyres I'm looking to purchase are Michelin Pilot Sport 3 but they don't have the stock size 255/40/r18 and I would like to keep the 400M. Any other options do I have? Well downsizing the rear tyre works but that's not really recommended is it. And I love 400M so I'm not about to change the wheels. Last edited by awyongcarl; 08-27-2015 at 11:55 PM.. |
08-28-2015, 12:57 AM | #18 |
Rep 5,140
Recommended wheel width for 275/35-18 is 9.5", 9-11" as alternatives. I wouldn't fit a 275 tire on a 8.5" wheel, but it might be possible.
Pilot Super Sport are available in 255/40-18 as another option. |
08-28-2015, 03:49 AM | #19 | |
Rep 72
Then PS3 for the used E46 330i with the stock 17inch stagger wheel I just booked few days ago. |
08-28-2015, 03:58 AM | #20 |
Rep 3,958
No need. The car doesn't have enough power to necessitate anything wider than a good 255 width tire. In fact, most people recommend a 245 square setup for performance. 275 is just extra weight that isn't really utilized.
08-31-2015, 06:13 AM | #21 | |
Rep 72
Anyway, I think the best is still keeping the diameter same or at least as close as possible, what are the sizes that I can go for and will not screw up the speedometer big time? |
08-31-2015, 07:17 AM | #22 | |
Rep 3,958
You have a few options. This is not an exclusive list: 235/45/18 - slightly larger 245/40/18 - slightly smaller I don't think either will screw you your speedometer big time. As far as cost, 235/45/18 seems a bit more expensive. |
