DINAN problems
07-28-2015, 01:00 PM | #1 |
Rep 731
Drives: 2008 335i 6MT
DINAN problems
Hey so I just picked up my car. I love it and it runs great 99% of the time. The other 1% is when it has the hesitation at WOT in 3rd gear and up. I watch the boost drop from 14.0 to 13.5 and back to 14 then back to 13.5 all the way up to near redline.. Now it hadn't had this issue in a few days and then randomly last night was doing it quite a bit.. then this morning and today back to normal. Could this be an issue with the tune? I assume if anything was mechanically incorrect this problem would occur all the time.. no?
Thoughts and opinions appreciated - TY in advance EDIT: As a precautionary measure I plan to get the walnut blast done and some new plugs. Car only has 32k miles, but has been sitting for months at a time over the last 4 years (rarely driven). Do you think its too soon to do the walnut blast and I should wait? or just get it done regardless. EDIT x2: I've spoken to a few people about this issue because I noticed it when I test drove the car but after the original owner got rid of the gas that had been sitting in it for months and started fresh with some new 93, the car ran beautifully so I assumed the problem had to do with stale gas. I've driven it for a week with no issue until the little bit last night, then today its back to normal. I assumed maybe the weather changing at first, but its been colder then it was last night and still ran fine. My local BMW dealership no longer deals with DINAN so I cant get the tune updated that easily, and I've been told to ditch the DINAN tune for MHD or COBB regardless because DINAN sucks (allegedly). Basically I wanted to wait for more bolt ons before I went to a new tuner but if it is the tune causing this it definitely needs to go ASAP.
2008 335i Coupe / Alpine White / 6MT / Fully Built Motiv Closed-Deck Motor / Motiv ST Kit / XR 105/69S / Motiv Twin Disc / VRSF 7.5 FMIC / ActiveAutowerke Exhaust / EOS Intake Manifold w/ 1050cc injectors / TiaL BOV / External VTA PCV / Quaife LSD / DSS Axles / KW V3Coilovers
07-28-2015, 01:32 PM | #2 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Are the spark plugs original? If so, change them. If not, change them.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
07-28-2015, 01:37 PM | #3 |
Rep 731
LOL will do. What brand/gap is recommended?
07-28-2015, 01:41 PM | #4 |
Rep 3,475
OEM bosch will be ok, they're pregapped. NGK 5992 gapped to .022'' are better for tuned cars however. If don't plan to go back to stock, the NGK are the way to go.
07-28-2015, 01:46 PM | #5 |
Rep 731
Yeah not really planning on going back to stock.. only more HP from here on out. Thank you sir
07-28-2015, 01:48 PM | #6 |
Rep 731
You think the plugs are overkill because I'm only running 14psi
07-28-2015, 01:48 PM | #7 |
3442
Rep 79,211
Dinan is a good tune but it's conservative and you can get more power out of other tunes for considerbly less money.
That being said, change your spark plugs and go from there. If they have over 25,000 miles on them they should be changed on any tuned vehicle. Bosch OEM or NGK are recommended. |
07-28-2015, 02:00 PM | #8 |
Rep 3,475
Like I said, OEM Bosch will be adequate. I'm still running OEM bosch plugs on 18psi. But NGK will be better, if you ever upgraded to jb4/mhd down the road they'll be even better too.
07-28-2015, 02:01 PM | #9 | |
Rep 731
07-28-2015, 02:19 PM | #10 |
Rep 776
My dinan tune used to do this also, it had brand new plugs, coils and injectors and still did it. It got progressively worse, and a walnut blast eliminated it.
I have since gone jb4 with backend flash and honestly miss my dinan tune. If I had to do it again, I would have kept the dinan, added a fmic, an cold air intake, and exhaust. Would be a little less power than I have now but much more consistent, reliable and smooth. |
07-28-2015, 02:29 PM | #11 | |
Rep 731
07-28-2015, 02:30 PM | #12 | |
Rep 3,475
07-28-2015, 02:31 PM | #13 |
Rep 194
I hope you find the cause of this issue because I have the Dinan stg 3 tune and experience the same thing and cant figure it out. Ive gone through the whole list of part replacements...plugs, coils, injectors, walnut blasting, vac lines, adaptation resets etc and it still does it.
I read somewhere that this boost oscillation is the throttle plate opening and closing to control boost. Not sure how true that is but Ive come to live with it for the time being. It comes and goes, some weeks it runs great, other weeks it hesitates. |
07-28-2015, 02:36 PM | #15 |
Rep 950
I think JB4 will delete the Dinan tune. I know Cobb or MHD will.
2010 E90 335i Le Mans Blue Metallic // Saddle Brown // M Sport // iDrive // Comfort Access // Blown By Twins
07-28-2015, 02:43 PM | #16 |
Rep 776
Jb4 is a piggy back, dinan is a flash, so jb4 will ride the dinan, but not well.
I tried this and would get 30ff low boost codes, and spent a tonne of time and money chasing a boost or vacuum leak that didn't exist. 30ff was because dinans timing and afr is not safe for anything over 14psi. I reflashed with a bms backend via mhd and now I hold 17psi well. My dinan was very sensitive to gas octane before walnut blast. That sputter in a high load low throttle situation turned into a misfire with poor gas. Canadian gas sucks and my elevation is very high. |
07-28-2015, 08:03 PM | #17 |
Rep 1,465
Drives: 2009 BMW 335xi
Dinan tune does suck. If you search around there are a bunch of threads about the os illusion issue which they never solved. My car had dinan Stg 2 when I bought it. I ditched it for cobb and never looked back.
07-28-2015, 08:05 PM | #18 | ||
3442
Rep 79,211
Most people we know experience no issues with the NGK. For those that might, they may have other issues that haven't been corrected yet. Quote:
Jb4 will not delete the Dinan. Dinan is a flash tune, only another flash tune can remove it. |
07-28-2015, 09:50 PM | #19 |
Rep 731
Thanks everyone for the replies. I wasn't able to get to my computer until now. Sounds like the oscillation issue is probably tune related? I know someone mentioned that it could be related to the throttle plates.. But alot of people said that a flash tune fixed the problem. I am just afraid to flash MHD or Cobb and regret it and wish i could go back to the DINAN. I want to replace plugs and get walnut blast regardless, so im going to start there. Ill keep you guys updated.
07-28-2015, 10:12 PM | #20 |
Rep 3,736
If you have access to a BT tool, try resetting adaptations. If you don't, I would invest in one. You need to see if car has thrown any codes to help troubleshoot. I think also the bmwhats app may have this feature now too.
07-28-2015, 10:40 PM | #21 |
Rep 731
I used the scanner and there are no pending codes or active codes
07-28-2015, 11:01 PM | #22 |
Rep 3,736
Here is an old thread about resetting adaptations:
http://www.e90post.com/forums/showthread.php?t=386376 |
