Transmisison Service
07-28-2015, 07:03 PM | #1 |
Rep 780
Hey guys
Anyone got it done? My E90 is about 100,000k now and I have been looking around to get a oil change done for the tranny. I have done it on my old X5 and thought that I should do the same for the E90. I think from memory the dealership charged me around ~$700 to get it done for my E53 X5. I'm thinking to get it done at a transmission shop this time. For those who has got it done Where did u do it? How much did it cost? There is a lot of debate out there that some people think it is not require as per the dealership. But a lot of people still do it as ZF themselves said it should be done 60-80,000ks.
2020 BMW G07 X7 3.0d M Sport
2018 Audi FY Audi SQ5 2016 BMW F36 440i GC M Sport |
07-28-2015, 09:37 PM | #3 |
Rep 40
I just ordered the parts required this morning, I plan on doing it myself.
The oil cost $80 and the transmission pan with filter cost $126. Hopefully my car still runs after this weekend! |
07-28-2015, 10:12 PM | #4 |
Rep 137
I'm not sure if the 330d has the same mechatronic sleeve issues as the 335i, do a search to see if you should replace it whist you have the pan dropped.
07-28-2015, 11:11 PM | #5 | |
Rep 1,123
Drives: E39 540i, E90 320d,F15 30d
sht, thats hardcore DIY changing transmission oil at home! |
07-29-2015, 03:28 AM | #7 |
Rep 1,382
I also heard that transmission oil change is not needed.
even saw an article saying that potential damage to the transmission system due to air going in? I would really want to know how many of the members here have done it? |
07-29-2015, 04:06 AM | #8 |
Rep 6,285
With most AT's you need to flush them via a pump to remove all of the old fluid, by draining what's in the tranny wont be fully effective (compared to a flush by a tranny specialist or indy) as you'll still have a few litres floating around in the torque convertor and if you have one tranny cooler etc.
07-29-2015, 05:37 AM | #9 |
Rep 11,905
Changed drained and serviced my tranny once, was put back together wrong and ended up with a full transmission rebuild for my trouble... not that I'm suggesting this will happen to you
08-01-2015, 08:39 AM | #11 | ||||||
Rep 780
I was thinking of taking it to a trasmission specialist close to me
Sorry to heard ur trouble. How much did u cost u at the end?
08-04-2015, 12:57 AM | #12 |
Rep 40
VW recommend servicing the DSG not sure of the service interval but it's quite long I think 60,000kms or something.
Changed the oil over the weekend and definitely a big improvement, no longer jolts when upshifting under load |
08-05-2015, 06:47 PM | #13 | |
Rep 780
I'm hoping to get it done sometime next week. Hopefully I will also see the improvement similar to urs.
08-05-2015, 09:37 PM | #14 |
Rep 568
Drives: BMW M4 DCT (F82)
You'll need to replace the transmission oil pan when replacing the fluid. The pan has a built in oil filter that can't be replaced separately, BMW will quote you $500 for the pan, but you can get it from overseas for about $200 and it's genuine. I like to do things right, you can't put in fresh fluid on a dirty filter.
When I had my 2006 auto E90 325i I did a transmission service at home by myself, there are plenty of DIY on this forums for this job (you'll need a thermometer for this job btw). I replaced: 1- Transmission fluid (used about 8.5L of the 10L I initially bought from BMW) 2- Tranny oil pan including built in tranny oil filter and the gasket (about $200 from turner motorsport) 3- electric connector rubber sleeve (cost $15 and known to leak, so might as well do it) 4- I also replaced all the bolts that hold the oil pan in place, BMW advises to replace them (came free with my oil pan) I did it mostly for preventive maintenance, straight after servicing my transmission the shifts were a bit faster and smoother, other than that no real performance advantage doing this job. P.s. A year later I sold my car and now I drive a 6 speed manual which I am planning to service its transmission soon. I think for the manual, only fluid needs replacing. No pan or filters required for the getrag 6mt box afaik. If you take it to a shop to do the job, make sure they don't charge you more than 2 hours of labour max.
Current: F82 Mineral White M4 7DCT
Gone but never forgotten: E92 Sparking Graphite 335i (N54) 6MT build thread. |
08-07-2015, 12:09 AM | #15 | |
Rep 780
$550 all inclusive in GST. Change oil, inc gasket, oil filter so I thought it was quite reasonable. I asked him to check the transmission repair done by Brisbane BMW and also the jolt from 2nd to 1st gear. Will let u guys know how it all went down next week.
08-07-2015, 12:55 PM | #16 |
The Cheap Arse Asian
47
Rep 585
I'm surprised your car hasn't development a dreaded leak at 100k km, mine developed a leak at just 65k so I had them do the entire flush while they replaced all the bits and pieces.
