New stage 2 LPFP (with logs)
07-31-2015, 07:37 AM | #1 |
Rep 61
Installed my stage 2 LPFP yesterday from Steve. My old one was dropping down to like 35psi on the Cobb E30 map. Going to get an E50 tune after I have my meth kit and inlets installed sometime late august. Anyways, how do my logs look! Cobb E30 map
http://www.datazap.me/u/kyle335xi/lo...=1-2-5-9-10-12 http://www.datazap.me/u/kyle335xi/lo...2-8-9-10-12-13 |
07-31-2015, 08:00 AM | #2 |
Rep 1,093
Add cyl 1 ignition angle. You have some timing corrections but without timing advance cant see how aggressive your timing is. The fuel us obviously adequate.
07-31-2015, 07:52 PM | #5 |
Rep 1,093
And why would he get rid of a perfectly good Cobb? The same tuners that tune MHD tune will tune Cobb (as will a network of Cobb tuners). The Cobb logs everything necessary. He doesn't have a JB4 with backend flash updates to keep up with. Map switching is just as fast. I haven't seen any logs to suggest the base maps are better. There aren't any new table discoveries that are important to his level of tuning (or anybody beyond exploration at this point).
If you have nothing it's an easy choice(MHD). If you already have Cobb and aren't running a JB4 your doing it just because...which is okay as long as you know it. I'm going to get the MHD myself because I already have an android and it would be great to log and flash with it instead of a 14" laptop. What I ain't going to do is have spent $750 on a Cobb to sell it for $200 because sheep told me its inferior and don't know why. |
08-01-2015, 10:11 AM | #6 | |
Rep 483
08-01-2015, 11:36 PM | #7 | |
Rep 1,093
08-01-2015, 11:46 PM | #8 | ||
Rep 483
08-02-2015, 12:12 AM | #9 | |
Rep 647
Has ability to run 3.5 bar map sensor flash only, no jb4 required Has ability to raise all 17 idle tables for people with aftermarket clutch and flywheel. So no more flywheel chatter. Has ability to delete cold start Has ability to adjust over sensitive knock sensors Has ability to do load by gear, basically boost by gear. (only finished for IJEOS Rom so far) Has ability to reset several different adaptations independently. Tells you what emissions monitors are in the ready or failed position. I'm sure I'm missing a few, oh and Jake from motiv just remote tuned a motiv 700 car using mhd and I'm sure PTF or any reputable tuner if given the choice would choose mhd. |
08-02-2015, 09:22 AM | #10 | |
Rep 510
08-02-2015, 11:33 AM | #11 |
Rep 1,093
Just off the top of my head things that mhd can do that Cobb can't.
Has ability to run 3.5 bar map sensor flash only, no jb4 required Means nothing to anybody on stock turbos Has ability to raise all 17 idle tables for people with aftermarket clutch and flywheel. So no more flywheel chatter. means nothing to almost anybody. Do you really want your N54 idling like a 2 step to prevent SMFW. If you have a SMFW you know its going to chatter. Even if it works I'm not switching so my car will be better while sitting still. Has ability to delete cold start Again is this really anything someone cares about when considering switching from something you already have that's working? Another feature that is not important while actually driving Has ability to adjust over sensitive knock sensors and this has not even been discussed for use for anybody not pushing over 600whp with single turbo. Most advise not to tamper with period Has ability to do load by gear, basically boost by gear. (only finished for IJEOS Rom so far) ah so finally you hit one useful new capability. Plus one. Great for drag racing Has ability to reset several different adaptations independently. and this is a deal breaker why? You can still reset all adaptations and every time you reflash (or map switching as you call it) you do this anyway. My BT cable does this (what I use to flash BTW) Tells you what emissions monitors are in the ready or failed position. These are toggles. A) you should know...B) you don't have to change devices to find out, simply download the free tuning suite and look at the toggle...but basically if you are running catless DPs on FLASH ONLY and don't get a SES you already know the second o2 sensor readiness is toggled off. another feature that does nothing for the driving experience I'm sure I'm missing a few, oh and Jake from motiv just remote tuned a motiv 700 car using mhd and I'm sure PTF or any reputable tuner if given the choice would choose mhd. Once again, its well known the MHD has more features with ongoing development and development has ceased with the Cobb. What is being ignored is Cobb is already well developed enough to suite the 98 percentile in terms of tuning and has plenty of bells and whistles. Yes I see features useful to those who need to run 22-30 pounds of boost. Yes I see features that may be useful to the big players (increased torque ceilings and things you've mentioned). The features I see for the average FBO Tom, Dick and Harry don't warrant making changes IF you already have Cobb.... The fanboy's are the ones who can't think for themselves and determine if they see any features that warrant changing and just blindly switch based on it being the new in thing (not you but whoever the cap fits). I don't have a Cobb BTW. I'm perfectly satisfied at my level of mods with BT tool flashing. I need to be able to log without carrying a laptop so MHD makes sense for ME.... |
08-02-2015, 11:41 AM | #12 |
Rep 1,093
What part of ALREADY HAS did you miss. Boy you are slow! It you already bought it like almost everybody who wanted flash only tuning before MHD came out how are you wasting money. Wasting money is buying a new device/software suite to reap the same performance you already have.
08-03-2015, 12:46 PM | #13 | |
Rep 922
08-10-2015, 01:37 PM | #14 |
Rep 649
The fact that you can sell your Cobb tuner, switch to MHD, have a better tune and $$ on top of that should make it a no brainer.
Cobb has basically no development at this point. I switched from JB4+backend flash to MHD and it's a night and day difference.
17 M3 Comp
08-10-2015, 07:14 PM | #15 | |
Rep 1,093
As for this better tune stuff once again a device is not the tune. If you like Cobb OTS tunes better than MHD OTS tunes (many do) switching is counterproductive. If you have a Cobb Protuner that you prefer in terms of philosophy and skill vs a custom Wedge MHD flash switching is counterproductive. Idle tables, knock tables and one wastegate table (the new table discoveries) does not magically make your tune better or car faster. Some new table discoveries will never get touched. Others many will have no idea what to do with. NONE are going to outweigh who's at the controls (tuner) whether it be Cobb, OFT, BB flash or MHD. You guys do realize these tuning tables are the work of jyamona and updated XDFs. If we actually knew what we were doing most of this stuff can be taken advantage of with a BT cable, TunerPro and updated XDF...as what Terry has done with the updated backend(front end) flashes. |
