CIC HDD to SSD
08-06-2015, 07:43 AM | #1 |
Rep 604
CIC HDD to SSD
I’ve been tempted to do this for some time, but finally got round to doing it yesterday.
I’ve read conflicting reports on the benefits of a faster SSD over the stock HDD, but it definitely makes a difference. Boot up is near instant and changing the map scale is much faster. Getting the HDD out is easy. The hard bit is the fact that the HDD is IDE not SATA so an IDE to SATA convertor is required and software that can image on a bit by bit basis. The IDE SSD was around £80. Faster speed, plus I have the old HHD as a backup if anything goes wrong. (I’ve read that if the HDD fails BMW will make you change the whole unit). |
08-06-2015, 08:16 AM | #2 | |
Rep 1,707
How much gb on the ssd? What did you use to transfer the data from the HDD to SSD? |
08-06-2015, 11:29 AM | #6 | |
Rep 604
If you can drop the HDD & SSD off to me I could copy it for you to save you buying the software and adapters. (It will take at least 24 hours) |
08-09-2015, 07:10 PM | #8 | |
Rep 32
do you know if this would be fine ?
http://www.ebay.co.uk/itm/New-USB-2-...item3a958607ef thanks Quote:
08-10-2015, 04:10 AM | #9 |
Rep 604
^ That won't work. Its USB to SATA and the hard drive is IDE.
If you PC does not have IDE you have two options. Copy the HDD to a SATA HDD (or SSD) and then copy the image from the SATA drive to the IDE drive. This is what I did, however it is better (less risky and time consuming) to copy direct from the HDD to the SSD. To do this however you will need 2 IDE converters. Here is a link to what I purchased: StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter Zheino 2.5 Inch Pata Ide 44 Pins 128gb SSD Solid State Drive Hard Disk Manager 15 Professional |
08-10-2015, 05:00 AM | #10 | |
Rep 32
thanks , i'm probably going to get 40GB-60gb but the rest lead would be waste after 1 use
08-10-2015, 10:49 AM | #11 |
Rep 604
^ With a 128 GB SSD you will end up with unused space as I don’t think it is possible to resize the partitions. Having unused space is not a bad thing however on an SSD. Most SSD’s will use this for internal garbage collection and wear levelling and this works over the entire drive, regardless of how many partitions are created. As the SSD will not receive TRIM commands this is a good thing.
The next size down from 128 GB is 64 GB, which is insufficient. |
08-10-2015, 11:35 AM | #12 | |
Rep 32
Ohh i see , guess ill wait a bit then
Really tempted though Thanks Quote:
08-10-2015, 02:42 PM | #13 | |
Rep 2,022
08-17-2015, 08:39 AM | #14 |
Rep 209
I tried this over the weekend with the following SSD (supposedly it has higher temperate range tolerance). Super Talent DuraDrive ET3 128G.
In short, it didn't work. I'm still investigating a fix and will update this thread. Removing the old drive and imaging it was easy, but all attempts to use the new SSD resulted in the same problem: the "OS" booted and I got to the home screen, but the Navigation did not load when clicked (it tried but failed with "Function currently not available") and the info section of the onboard music storage had "No Info". It was like the additional partitions were not visible to the CIC. I tried the following utilities to clone it:
After much searching (especially in the Jeep and Chrystler forums since they have a similar QNX OS), I downloaded the QNX VMware image and am attempting to mount the filesystem in there and see what is going on. I've got a few theories at the moment:
I'll post more as I learn more. Also, if I can mount the file system, then I do believe that enlarging the music partition (though I'm not actually interested in doing so) is probably possible. Off to learn more about QNX... Bottom line, I was hoping a simple clone would work, but it didn't. I know others have reported success. Last edited by kioneo; 08-19-2015 at 07:10 PM.. |
08-17-2015, 02:20 PM | #15 |
Rep 604
A simple clone does work if you do it bit by bit. The OS on the drive is irrelevant if you copy the drive on a bit by bit basis. Did you leave a jumper on the drive you copied to? (Slave/ Master set jumper)
I copied from HDD to an SSD and then from that SSD to the SSD I wanted to use with the satnav as I only had one IDE connector. No problem at all. If you did do a bit by bit copy try a secure erase on the SSD before cloning. |
08-17-2015, 02:34 PM | #16 | |
Rep 209
My hunch is telling me that Clonezilla is to blame because it did a partition-by-partition copy (albeit with dd). I need to investigate further, but it may be that the MBR/EBRs are not being recreated correctly (or that Clonezilla or another program I tried with "partition handling" is screwing it up). I saw a number of type 5 partitions (Extended CHS) as opposed to type 15 (Extended LBA). Certainly if they truly are type 5 on the source, it may be a geometry mismatch. I have an 80G drive (hopefully same geometry) to try as a same-same clone. Then figure out the needed changes when going to the 128G. That doesn't explain why a dd on the whole drive at a time failed, but again, I'm guessing I have partition table problems. And you are right, I probably ought to do a complete erase of the SSD. Maybe there is something sticking around. Getting closer... |
08-18-2015, 05:57 AM | #18 |
Rep 282
08-18-2015, 08:59 AM | #19 |
Rep 505
This all sounds good but from what I've read no one has been able to expand the partition that holds the music so it’s still the same size drive in effect, just faster.
Is there no software available that could expand that partition..? The original drive is 40GB but the new SSD that most people use is 128GB so that’s a lot of wasted space. |
08-18-2015, 09:06 AM | #20 | |
Rep 282
08-18-2015, 10:16 AM | #21 | ||
Rep 209
08-18-2015, 10:17 AM | #22 |
Rep 604
MAN15H its not wasted space if you read post 11. Also SSD's are now much cheaper. The first SSD I purchased was an Intel X25 E. £600 for 32GB. What you are getting with an SSD is much faster performance. Instant boot up and faster map zooming.
