ER charge pipe installation trouble; Please help
08-09-2015, 05:00 PM | #1 |
Everyday I'm Repairin'
88
Rep 757
Drives: 10 335i
I'm in the middle of installing my ER charge pipe And the area where the pipe is supposed to bolt to the car, there's a big gap and the screw won't fit it.
I removed pipe and tried rotating it, etc and it's still too far. What am I doing wrong ? Ps: I'm not done so the clamps aren't installed
Make money, no vacation Pay cash, don't make payments |
08-09-2015, 05:11 PM | #2 | |
Rep 50
Drives: 2010 e90 335i 6A/T
08-09-2015, 05:16 PM | #3 |
Rep 4,392
I ran into this before. Disconnect from the TB and then try to bolt it down but only enough so you can reconnect the CP to the TB again, then tighten it down
08-09-2015, 05:22 PM | #4 |
Joint Chiefs of Staff
4927
Rep 116,037
08-09-2015, 05:55 PM | #5 |
88
Rep 757
Drives: 10 335i
So the screen that bolts it down...fell and I can't find it now ...how screwed am I??
08-09-2015, 05:58 PM | #6 |
88
Rep 757
Drives: 10 335i
This install is the biggest pain in the ass ever..:I've installed most of my mods and by far this is the worst. 30 minute install my ass lol
08-09-2015, 06:00 PM | #7 |
88
Rep 757
Drives: 10 335i
And can I drive the car without it being bolted down?
08-09-2015, 06:08 PM | #8 |
Rep 50
You can, and it shouldn't be that much of an issue. I'd recommend taking the time to find it. Save yourself from going crazy later when you start hearing sounds. Check cover underneath, check underneath the throttle body where the connections for the HPFP and LPFP sensor are. If not when you're driving it may move around and you'll hear it hit the brace. I only assume, I never ran mine without the screw.
08-09-2015, 06:41 PM | #9 | |
88
Rep 757
Drives: 10 335i
I finished hooking everything up and cranked the car and revved it up and everything appeared to be ok. The pipe doesn't seem to move under throttle , but I don't want anything to end up breaking later on
08-09-2015, 07:37 PM | #11 | |
Rep 50
08-09-2015, 07:41 PM | #12 | ||
88
Rep 757
Drives: 10 335i
Do you think it would melt though?
08-09-2015, 07:46 PM | #13 |
Rep 50
08-09-2015, 07:48 PM | #14 | |
88
Rep 757
Drives: 10 335i
On the other hand, do you happen to know the name of the bolt that I lost lol? I'd like to order another one but don't know what it's called
08-09-2015, 07:55 PM | #15 |
Rep 50
Not sure, you could give ER a call they open at 9AM tomorrow and they may have some in stock. And there's always Home Depot. You can find the correct size from your install guide and go from there
08-09-2015, 11:41 PM | #16 |
Rep 1,028
Hey Workhorse, I'll be installing the same charge pipe this week on my 335is and I'm less mechanically inclined than you. Does the ER CP come with those black caps to cap off the diverter valves then? I'm trying to picture how it's all going to go back together. I'm also installing a dual cone air filter set up at the same time.
Can we see a photo of your finished project? Thanks.
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
08-10-2015, 12:12 AM | #17 | |
88
Rep 757
Drives: 10 335i
I too have the dual cone intake. So for me, this has been a major pain in the ass. Idk how everyone else does this in "30 minutes" etc but I'm literally on day 2 since I didn't have all the necessary "household tools"the first day. Make sure you have a T20 and T30 bit as you'll be using those for the MAF sensor and removing the mounting bracket. And yes, they do come with the caps and clamps for your valves.
08-10-2015, 12:16 AM | #18 |
88
Rep 757
Drives: 10 335i
So I just took the car out for a drive to see how everything was and feel the new throttle response etc BUT when I was driving down the on ramp to get onto i5 my rubber hose blew off on the lower charge pipe side and since it's not "bracketed on" because I dropped the screw it's now unsealed and causing me a huge pain in the ass.
So now I'm through dealing with this myself and will pay someone to correctly fix these minor issues. Is anyone located in or near San Clemente, Ca that has installed an ER charge pipe that's willing to fix this for me? I'll pay you for your service.
08-10-2015, 12:38 AM | #19 | |
Rep 50
In either case give it a try.
Daily Driver:2010 e90 335i AT
ER FMIC w/CF Shroud - ER Competition Oil Cooler - BMS Oil Cooler Valve - JB4 G5 ISO - 100%E85 - Alpina TCU Flash - Vanguard Exhaust - Macht Schnell 3' CTLS DP - TFT Inlets - aFe Air Dam - TiAL BOV - Fuel-it! STG3 LPFP - Motiv PI - PURE STG2 - DSS Axles - 717whp/686wtq |
08-10-2015, 12:52 AM | #20 |
Rep 1,028
I'll piggyback my experience with the ER charge pipe and dual cone filters here in a few days. Fortunately, I have 2-3 very mechanical friends who are naturals with this kind of stuff. I'll be honest about my experience.
Workhorse, how many lbs of boost are you running to blow the end off?
08-10-2015, 01:00 AM | #21 | ||
88
Rep 757
Drives: 10 335i
08-10-2015, 01:01 AM | #22 | |
88
Rep 757
Drives: 10 335i
