Wedge/MHD E60 335xi Mustang Dyno (425awhp/500wtq)
08-09-2015, 09:56 PM | #1 |
Rep 4,393
Dynoed this morning so figured i'd post up the results. Shop fan setup was very poor so my IAT's skyrocketed and as a result the car started to pull timing. On the road I have zero timing corrections across all cylinders and the car runs extremely well. Anyways I only have the graph of the attempted stock run and the first pull on the dyno. The second pull which isn't on the graph it made 425awhp and 500awtq. Tried to do a baseline pull but it clearly didn't work out too well... Maybe something to do with the big E85 mix running stage 0? Anyways baseline is kinda useless since peak numbers are high due to all the spikes the dyno picked up. I'm pretty pleased with these numbers on a mustang dyno. My friends B8 S4 with APR stage 1 only made 330awhp so it does read a bit low.
Extremely happy with the Wedge flash. I've been through JB4, JB4 backend flash, Cobb, Cobb w/ Motiv, and now MHD with Wedge. He is extremely responsive/helpful and the car performs amazingly. Log: http://datazap.me/u/psmith95/dyno?log=0&data=4-18 Graph: Video: Edit: Figured I should put my full mod list -MHD Flash (Wedge E60 tune) -Roc-euro DCI -ER Charge pipe w/ Tial BOV -VRSF 7" FMIC -VRSF Catless DP -Walbro 255 Inline LPFP -PE mod exhaust w/ xpipe and resonators
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
08-09-2015, 10:01 PM | #3 |
Rep 4,393
Yup that's next up on the list but for xi the whole subframe has to be dropped. Either way eventually will do the VRSF inlets most likely
08-10-2015, 01:20 PM | #7 | |
More Boost?
59
Rep 283
08-10-2015, 01:26 PM | #8 |
Rep 1,818
holy shit, your IAFs go from 120 to 200F??? No wonder you're pulling timing, that's insanely high. Definitely a reason you're dropping off 13 deg past 5500 (but impressive that it can hold up till then at those temps, e85 works some serious magic. I can't do 5-6 degrees at even 120 IAT on 91 )
I don't know what that wgdc # means but you aren't holding boost target pas 4700, might just be tired turbos |
08-10-2015, 01:59 PM | #10 | |
Rep 649
17 M3 Comp
08-10-2015, 02:09 PM | #11 |
Rep 3,553
08-10-2015, 02:39 PM | #12 | |
Rep 649
On my z06 its zeroed out...pretty sure every person on every platform does it this way when running e85
17 M3 Comp
08-10-2015, 02:41 PM | #13 | |
Rep 4,393
http://datazap.me/u/psmith95/log-143...og=1&data=4-18 In terms of boost falling off that's just how the stock turbos operate i'm pretty sure. Map is supposed to peak around 21 PSI then taper to 15-16 stock turbos can't hold that target of 20 to redline
08-10-2015, 03:09 PM | #14 | |
Rep 1,818
http://datazap.me/u/psmith95/log-143...-22&mark=50-89 makes sense on the boost, I have a dyno map where I was ~e60 and saw similar boost numbers (my target was tapered so I attributed it more to that, but it looks to be the same curve regardless of my target or yours so I guess that's a hardware limit) http://datazap.me/u/tc535i/8214-eas-...4&zoom=170-220 Last edited by tc535i; 08-10-2015 at 03:18 PM.. |
08-10-2015, 07:55 PM | #15 | |
Rep 4,392
By making the table completely null, you are allow the chance for real knock occurences leading to timing corrections rather than to have the DME pull timing to avoid real knock occurrences E85 is not indestructible to heat, very resistant yes, but it does have its breaking point ( E30 Test Source with table null ) Dont forget seasonable blends and not everyone keeps in mind of this. It fine if you do it on your own car but no tuner should do it in blind ignorance , monkey see monkey do, without knowing what the breaking point is for the given fuel type / iat / load / timing . The only way to know this is by testing. Leaving an entire table null is not testing, but a shortcut Last edited by BQTuning; 08-10-2015 at 08:13 PM.. |
08-11-2015, 01:45 PM | #17 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Nice numbers! This make me want to do an E30 Wedge MHD tune. I'm currently on the BMS race flash with JB4 running E30, so around 9 degrees of timing and 18psi tapering to 15psi.
08-11-2015, 04:50 PM | #18 |
Rep 4,393
There's a station that sells E85 in Greenwich CT. Across the street from the whole foods on the post road. Near Glory days diner
08-11-2015, 05:28 PM | #19 |
Rep 1,340
Dropping the subframe isn't to difficult for us xi guys. My boy and me just did xi downpipes for his friend.
