BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > Tilt Down Mirror F20 Coding
      08-12-2015, 09:35 AM   #1
marcospoffo
marcospoffo's Avatar
Brazil
17
Drives: 320 F30 - 2013
I need help to encode a F20. She has Tilt down since changed the mirror selector and nothing.
Is there any coding to Tiltdown?
320 F30 2013.
      08-14-2015, 04:27 AM   #2
RiczPT
Drives: F21 118d
I'm not sure it's that easy. I think I read something that said you either have to have memory seats or electric folding mirrors to have this option. But, then again, I am not entirely sure
      08-19-2015, 02:03 AM   #3
dishy
I have a 2015 model, with electric mirrors and memory seats but I don't know how the auto tilt down thing works. The dealer said to me "when you park, the mirror tilts down" but at the moment it does not. How is this feature supposed to work?
      08-22-2015, 03:00 AM   #4
Ben_M135i
Drives: 2013 M135i
There is an option in iDrive you select and then the mirror will tilt down. No need to code anything
      09-01-2015, 06:13 AM   #5
04S
04S's Avatar
174
Drives: M4 xDrive, X5 40i and U11 X1
If you have the functionality on your car it either tilts or not according to where you have the selector to adjust the external mirrors. To the left or right turns it on, the other way turns it off. I think it might be dependent on which side you drive, so experiment with it in both positions and you should be able to work out which one makes it work.
      09-04-2015, 09:36 AM   #6
neilwilliams
Drives: F20 116iSE
When you engage reverse gear the passenger side mirror will tilt down. It's not the fastest thing in the world. When you deselect reverse (neutral or forward) it will return to the normal position.
      12-20-2015, 02:39 PM   #7
GeeDee
Mirror adjust switch needs to be set to driver side for passenger switch to drop on reverse.
      08-17-2016, 09:09 AM   #8
w0rf
haven't seen the option yet, any clue on where to look in idrive?
      12-26-2016, 02:52 AM   #9
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Coding is ASP_BORDSTEINAUTOMATIK_DELTA. Change to werte to higher value like 4B or 5A for increased vertical tilt.
      01-27-2017, 01:59 AM   #10
Masquarade
Poland
Drives: 118i M package
I have tried to code this, and it does not work on 2016 F20...
What you have to code should be in FEM_BODY:
ASP_BORDSTEINAUTOMATIK => Activate (mine was not)
ASP_BORDSTEINAUTOMATIK_DELTA => Change value to 4B or 5A as above)
The code worked without errors.
At the end, it did not work, I am really sad because this option is quite usefull as I park in tight places everyday...
If anyone has any idea how to make it work? I do not have memory seats, but I do have electric mirrors (without folding motor)
      01-27-2017, 02:02 AM   #11
Almaretto
Almaretto's Avatar
2374
When you read Fem_body again, are values set as desired? Is switch on drivers side?
      01-27-2017, 02:21 AM   #12
Masquarade
Poland
Yes... Tried kinda everything, switch on the left or right , changed values and all.
There must be another option to activate for cases like mine that dont have folding mirrors or memory seats.
I will try again this evening, maybe the coding took quite some time to take effect? as i was trying right after coding.
Also in this code, it is only possible for passenger side mirror to tilt down? i would like both mirrors or actually only Right mirror to tilt down (left driver seat) as in parkings its much more usefull to have better view on the right side of the car.
      01-27-2017, 11:43 AM   #13
Almaretto
Almaretto's Avatar
2374
May not be possible with your vehicle. Coding takes immediate affect.
Only passenger mirror and only when switch is on driver's side.
      09-21-2017, 04:35 PM   #14
dorgo
Drives: F20 116i
Has anyone managed to activate the 'tilt down' without having electric seats/folding mirrors?
This feature can be very helpful.
      11-25-2020, 01:43 PM   #15
balee13
Drives: BMW F36
Hi,
I don't have electric seat nor folding mirrors, but this function (mirror tilt) was working for me. Now it is not working. I have checked with e-sys, and tried to change the Asp_bordsteinautomatik_delta to different values, but it is still not working.
It is also confusing that e-sys offer two option for this: 59_Digits and 85_digits. What is the default here?
      12-16-2020, 03:14 PM   #16
aquasurf
aquasurf
Australia
Drives: 2016 120i
I searched for this extensively some weeks back and the result was that the mirror tilt on passenger side only with reverse selected can only be successfully coded for cars fitted with folding mirrors.
1addicts
