E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Perma seal headlights
Reply
      08-17-2015, 05:29 AM   #1
Will335d
Will335d's Avatar
Drives: X6M F86
I'm looking for a cheap set of Perma-seal headlights does anyone know any other headlights that are, I've found F30, E90 LCI halogen and Golf R are but these go for a lot of money
Or does anyone have a set of used, any condition cheap F30 headlights?
I'd like to practice opening some which aren't mine
Thanks
2018 Donington Grey X6M
      08-17-2015, 06:33 AM   #2
Aragorn30d
Drives: E90 330d
Do you mean headlamps which are glued together with a non-heat-sensitive glue?
Audi A4 (B5 facelift and B6) lamps made by Valeo have the permenant glue that requires serious brute force to get them open.
Many aftermarket versions however use a different adhesive that does soften with heat, so you need genuine ones.
      08-22-2015, 01:18 PM   #3
Leah1
Drives: 320d m sport
What you planning on Doing?
I have e90 lci xenon and I'm planning on splitting them to install some dtm angel eye rings and maybe a new projector bowl, for better light cut off etc,
But biggest thing is getting them apart.
If I knew I could do it without breaking them I'd go for it but it's just the opening that's putting me off
I've had quotes for £300 which isn't bad really
      08-23-2015, 02:40 AM   #4
Aragorn30d
Drives: E90 330d
This is a pretty decent write up for the mod on the A4, i presume the procedure should work equally well on the BMW lamps, but i've not personally tried it:
http://www.a4mods.com/index.php?page...ages/joey.html
Reply
e90post
