MHD stage 1 tune
08-18-2015, 09:38 AM | #1 |
Rep 12
MHD stage 1 tune
so about a month ago I flashed the mhd stage 1 tune and have just a couple of questions. one thing I have noticed that I cannot do a burnout now? im a auto 07 335i. before I could just power brake and burn out with no problem, now when I try the wheels will spin for about 2 seconds and the power gets cut. anyone else have this problem? I went to the dragstrip and was going to warm the tires up a little to try and help out with loss of traction but couldn't do it. next question is I would like to know how many people actually hit target boost and how early? seems to be a little laggy and not always hitting target. here is a log to check out from a stop to 3rd pull.
http://datazap.me/u/t2ae/mhd-stage-1?log=0&data=4-24 |
08-18-2015, 03:04 PM | #4 |
Habitual Speeder
Rep 10
Had the same problem. The increased boost is pushing past the stock dv's. Replaced charge pipe with Cobb unit and the dv's with a pair of Hyperboost and now it will cook my 275's.
E90 335i Monaco Blue
08-18-2015, 05:27 PM | #5 |
Rep 12
08-18-2015, 07:20 PM | #7 |
Rep 12
http://datazap.me/u/t2ae/mhd-stage-1...og=0&data=4-24
this was a log I just did in third gear from 2500rpm. what do you guys think |
08-19-2015, 04:27 PM | #9 |
Rep 12
will look into this...possible that cause lag as well? I was running the stage 1 w fmic for awhile but started to throw 30fc code.
08-19-2015, 11:40 PM | #10 | |
BimmerPost Supporting Vendor
1339
Rep 1,701
Drives: Slot Machines.. Keep Taking $
08-20-2015, 07:12 AM | #11 |
Rep 12
08-20-2015, 03:53 PM | #15 |
Rep 183
woah that boost curve is all over the place. Did you recently install a FMIC? I know I had a minor boost leak at one of my couplers when I installed mine.
Good luck figuring it out. 13psi seems low as a peak ever for stage 1.
2008 135i SGM 6-Speed l AD Engineering ST 6262BB l MHD Tuned l MAXBoost/N20 Map l GFB electronic boost controller l Spec 2+ l Walbro 450 LPFP l VRSF 7" FMIC l VRSF CP l Tial BOV l BMR 3.5" Exhaust l BMS Catch Can l RB pcv l |
