Turbo lag reduction
08-18-2015, 09:06 PM | #1 |
Rep 8
Turbo lag reduction
Hi guys, I have been autocrossing my e90 335i for about a whole season now, and in most of the courses that require you to stay in 2nd the turbo lag (or lack of power in low rpm) is really holding me back when I need the car to rotate, so it doesn't plow, but when the boost kicks in it seems to be too late. The ecu is chipped with a jb4 and I usually run map 5 or 2 I don't find much of a difference between them. Is there a map I could program that could help with this? Also I plan on upgrading my down pipes soon, if someone could recommend me a set that is affordable but would suit my needs I would appreciate that!
08-18-2015, 09:11 PM | #2 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
VRSF downpipes, these will decrease lag slightly, a DCI may help, but not so much, inlets help more though. Otherwise not much you can do. What RPM are you talking here? When I autox I get down to maybe 2500, and I don't think there's much lag in second gear at 2500rpm running 18psi.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-18-2015, 09:16 PM | #3 |
Rep 2,872
Which JB4 are you using? G5 ISO?
And which firmware? 2nd gear in my car is like a damn on/off switch on the boost-o-meter.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
08-18-2015, 09:27 PM | #4 |
Rep 8
I recently installed the jb4 so I believe its the G5 with recent firmware not 100% sure but i'm going to run a usb in my glove box for easy access to that.
I have a BMS DCI seems to be sucking a ton of hot air from the engine though. The lag seems to be around 2k rpms the car seems to bog and take a few seconds then the boost kinda throws me forward, can be sideways if your not careful. I've had some issues with limp modes from the vanos solenoid's replaced the exhaust one and got 1 code from the intake vanos so far. Last edited by TrippleG; 08-18-2015 at 09:36 PM.. |
08-18-2015, 09:36 PM | #5 |
Rep 3,339
Welcome to turboland! Not much you can do other than keep DWP (Default Wastegates Position) at 100 via JB4. Not sure how much that will help though.
08-18-2015, 09:38 PM | #7 |
Rep 8
I've had terrible wastegate rattle so i'll have to give this a shot! Starting to consider something naturally aspirated... Or maybe doing a supercharger swap
08-18-2015, 09:38 PM | #8 |
Rep 3,339
It's more of a function of the turbos. They really don't spool to full boost until 3200+ rpms. Until then you're really just waiting until those snails to spool.
08-18-2015, 09:40 PM | #9 |
Rep 3,339
If you're having issues with WG rattle then you should drop DWP to 12. But that will give you boatloads of turbo lag (but really throaty exhaust since WG's are letting exhaust gases flow right through).
08-19-2015, 11:54 AM | #15 |
Rep 3,475
Better yet take a log with jb4 in second gear so we can see the spool.
08-19-2015, 02:48 PM | #16 |
Rep 38
Sounds like me, I'm laggy as hell and get 1/2 engine every once in a while... low boost, let me know what you find out. I'm running JB4 map1, but i get the code throw sometimes on map 4, (stock+log)
08-19-2015, 03:01 PM | #17 |
Rep 3,475
Take some logs and post them, we'll be able to see what's wrong.
08-19-2015, 05:15 PM | #18 |
Rep 8
09-15-2015, 03:12 PM | #20 |
Rep 197
Set map 10 to 5k rpm when autocrossing, this sets the DWP to 100. I drive around town with DWP at 0 because of rattle but when I push my car I set it to 100.
09-15-2015, 04:59 PM | #21 | |
Rep 3,475
Also update your jb4 firmware to 31_4
09-15-2015, 09:20 PM | #22 |
Boost
1355
Rep 3,697
Drives: 135i M-Sport
There's a boost leak or your turbos are probably on the way out... These cars have almost no turbo lag at medium levels of boost (which you'd want for autox) no need for more than 400wtq or so unless you're in super sticky tires.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
Tags |
335i autox jb4 |
