2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - California Camber Plates Installation
      08-20-2015, 01:06 PM   #1
bd307
Chef
bd307's Avatar
928
Drives: Things with wheels or no wheel
For those who have their Ground Control camber plates installed on their m235, where did you go to do the install? How much are they charging?
Any recommendation on alignment besides West End?
      08-20-2015, 02:36 PM   #2
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Platte forme AG is another great alignment shop.
G05 - M Performance roof spoiler
      08-20-2015, 02:48 PM   #3
rwalker
Drives: the wheels off
I've had mine installed/re-installed several times at a couple of shops. It's a 2 hour job if you're really quick about it, but none of my shops had any experience with the platform or the product, so times stretched way out (one shop took 4.5 hours and charged me for it :-( ).
Since that experience, I've been doing it myself. My first try with a friend's help took 5 hours. Now I can do the whole shebang in about 2.5 hours.
This kind of spring compressor helps: http://www.ebay.com/itm/360846827647
My process:
  1. break lug torque
  2. lift front of car from center jack point, place jackstands
  3. remove wheels
  4. unplug EDC connectors, place out of way
  5. unclip all bits (brake lines, brake sensor, etc.) from the strut and body so that the suspension can fully droop
  6. unclip headlight level from LCA for full droop
  7. detach sway bar end link from strut
  8. unbolt knuckle from strut
  9. rubber mallet on the hub to send suspension to full droop and detach strut from knuckle
  10. unbolt strut plate from body and tower brace while holding strut from below (helper useful here)
  11. remove strut from car
  12. place strut in spring compressor
  13. compress spring just enough to de-tension strut plate
  14. remove plate from strut shank
Assembly is the reverse. Use a jack to push the knuckle onto the strut after mounting loosely at the top, and to align sway bar end links with mounting holes on the strut.
I found torque specs scattered around the web, and torque for plate mounting bolts varies based on brand of camber plate. For the strut to knuckle bolt I used 60ftlb, for the sway bar end link nut I used 50ftlb.
      08-21-2015, 06:02 AM   #4
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Thanks for this info.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
2addicts
