BMS DCI Install
08-21-2015, 03:17 PM | #1 |
Rep 57
BMS DCI Install
Hi all,
I installed my burger motorsports dual cone intakes this evening which I found to be fairly straightforward apart from the rear intake which was a right pain to get in. I just want a second opinion on 1st of all a couple of the battery cables which I could only manage to route over the rear intake, is this normal or is it going to cause damage to the cables? Also the thin back pipe that plugs in just to the left of the oil filter housing, mine seems to form a different shape to others which I have seen including in the installation instructions. This means that this pipe is also resting on the rear filter, again is this going to cause any harm? Finally are other peoples filters touching at all as mine seem to be seating very close to each other. Please see attached image. Thanks Alex |
