AEM meth kit Cobb v3 how to be safe?
08-23-2015, 11:13 PM | #1 |
Rep 615
Read a lot yet I'm not sure what the answer is, I now have a AEM meth kit installed and a led light for when it's low or malfunctioning but how do I let my shop know how to make it so if anything fails the waste gates stay open ? Is this the fail safe way to set up the kit. I'm working with Ken and Dimitri on a custom map so I assume it will be pushing high Boost that if meth stopped flowing it would cause serious issues. Any advise be great. Scares me to go back to jb4 but I'm loving the Cobb and. Potential tune.
08-25-2015, 09:26 AM | #4 |
3442
Rep 79,211
In the instructions you can rig it up to tell the waste gates to bleed boost when meth flow is not adequate, same as aquamist kits. I've never done it personally so I can't offer further detail.
08-25-2015, 09:36 AM | #5 |
H O O N
86
Rep 694
There's no way to directly integrate the meth kit with Cobb.
I don't believe the AEM kit comes stock with a flow sensor, just voltage fault failsafe w/that little light. You'd have to run a flow sensor and failsafe, with a solenoid on the WG vac lines to cut boost. Alternatively you could try intercepting the stock WG solenoid wires with a relay controlled by the failsafe. This is how the Aquamist HSF4 controls boost, but wired directly to the controller instead of a relay as the controller has the function built in. The boost safe output from the AEM controller could also run the relay or solenoid but that wouldn't account for flow issues.
U WOT M8? |
08-25-2015, 10:04 AM | #6 | |
3442
Rep 79,211
Integrated Boost Safe Feature The controllers in AEM’s Water Methanol systems include an integrated “Boost Safe” output feature that monitors the entire injection system and triggers a ground signal via an output if it detects a voltage-related error (short, bad connection, broken wire, overheated pump, high or low voltage signal, etc.), allowing users to define their failsafe strategy from something as simple as flashing a warning light to more advanced strategies like pulling boost or ignition, or switching fuel maps on a standalone engine management system. Combined with the integral and highly accurate conductive low-fluid switch in the tank, “Boost Safe” can also put your engine in safe mode before the system runs dry. This exclusive feature is found only on AEM Water/Methanol Injection Systems. There are some good reads here about the kit including instructions: http://www.aemelectronics.com/?q=pro...soline-engines |
08-25-2015, 10:42 AM | #7 |
3442
Rep 79,211
Also forgot to add the failsafe flow gauge by AEM.
http://www.aemelectronics.com/produc...failsafe-gauge Today’s water/methanol injection systems have proven themselves as a viable means for effectively reducing engine inlet air temperatures and suppressing harmful detonation. This allows enthusiasts to reliably increase boost and advance ignition timing without the need for racing fuel. Despite the proven effectiveness and reliability of water/methanol injection, there exists a potential for engine damage if the water/methanol tank runs dry, if the pump stops working or more commonly if flow volume decreases due to fuel contamination, a clogged nozzle or a leak in the system. While failsafe devices for water/methanol are not new, competitors’ failsafe systems have limitations that do not allow them to completely protect your engine if the water/methanol injection system stops flowing. Most failsafe devices have settings for high and low range flow parameters, but only monitor flow at a single point. And, without actually calculating volume versus time to establish a flow rate, instead running the system at full blast and using the nozzle’s potential for flow as your established flow rate, it is impossible to know the actual flow of the water/methanol system. Short version: if you think you are flowing 500cc/min and are actually flowing 300cc/min, and you are relying on your failsafe to trigger an alarm at a single reference point using 500cc/min of flow as your reference, then you have created the potential for engine damage. Other competitors’ failsafe systems use a flow meter to establish water/methanol flow and utilize an external adjustment to trigger an alarm if the system does not detect maximum flow, using a time-delay strategy to compensate for part throttle operation. The problem is, water/methanol flow is rarely zero or maximum flow, and with all of the potential flow rates one can experience, a time delay strategy is not completely failsafe. Actively monitors the entire water/methanol fuel injection curve to trigger an alarm event under any defined adverse condition! Can be used on virtually all water/methanol injection systems with either 1/4" or 4mm OD tubing "Auto Set" feature automatically creates baseline configuration Built-in warning lights inform user of an alarm trigger Internal data logger records all injection flow and alarm status data Included high-tech analog gauge has black and white faceplates and bezels to match vehicle interior, and is programmable for either 0-500cc/min or 0-1000cc/min flow ranges Gauge alarm and backlighting are user programmable to match interior lighting Data analysis using AEMdata software. This aspect would be in addition to the base kit. |
08-25-2015, 02:06 PM | #9 |
Rep 615
Response from AEM.. Very fast response too.
Good afternoon Jordan, I don't have any install instructions specifically for the Cobb. The controller will output a "ground" signal when there is an error condition present. Some examples; - Lowside connected to the other side of a warning light. - Opens/closes the boost solenoid so the car runs on wastegate pressure. You need to figure out what your solenoid needs to open/close. - Input into an aftermarket ECU to pull timing and slow down the engine - etc etc etc Thanks Ryan |
08-25-2015, 02:19 PM | #10 |
Rep 2,084
How can we use a ground signal to trigger the wastegates to open? Can it be tied into the boost solenoid wiring?
2013 135is DCT Carbon Black Metallic |
08-25-2015, 03:39 PM | #12 | |
3442
Rep 79,211
I'm pretty sure that's what they mean. |
08-25-2015, 04:04 PM | #13 |
Rep 2,084
I guess I was looking more for specifics. I've heard our wastegates operate in reverse of normal cars, so I wonder if grounding the signal to the solenoids would cause the wastegates to open or close?
08-25-2015, 04:09 PM | #14 |
3442
Rep 79,211
I don't have the schematic in front of me but you got a 50/50 shot, right?
08-25-2015, 05:08 PM | #15 |
Rep 2,084
Hah yes, but one of the options is the exact opposite of what you would want to happen when the meth fails. I'm also curious if there is any chance of screwing up the solenoid or DME. Surely there would be an SES light. But small price to pay if it means saving your motor.
08-27-2015, 03:05 PM | #16 |
Rep 615
Im still at a lost on what to ask my shop to do ...( I realize the light will shine if all fails but since i am using the meth to increase my map parameters so higher than normal boost levels and timing I assume i cant have it fail and then not have the wastegates open. Cant change mapps with the flash. not sure how to get it to reduce boost or timing with Cobb. Perhaps JB4 is the answer. How does Aquimist do it again?
08-28-2015, 11:58 AM | #17 | |||
H O O N
86
Rep 694
For the base AEM meth kit as supplied, there's no way for it to accurately account for things like a clogged nozzle, leak, etc without measuring actual flow via a failsafe w/flow sensor such as the AEM failsafe gauge. Use of the ground signal to trigger the WG is what I was speaking of, put a relay into the wiring going to the stock WG's and control it with the output from the AEm controller. Make the relay trip open on the event of a ground signal, which in turns cuts out the WG noid and gates default to open. Quote:
U WOT M8? Last edited by Snertz; 08-28-2015 at 12:18 PM.. |
08-28-2015, 12:14 PM | #18 | ||
3442
Rep 79,211
Chromey, if you have a schematic, please feel free to post it. I'm sure others would find it helpful. Last edited by Jeff@TopGearSolutions; 08-28-2015 at 12:19 PM.. |
08-28-2015, 12:32 PM | #19 | |
H O O N
86
Rep 694
I recommend taking a look here for the schematic : http://www.bmw-planet.com/diagrams/r.../e90/index.htm
U WOT M8? Last edited by Snertz; 08-28-2015 at 12:40 PM.. |
