HELP!! Car throwing Codes!
08-30-2015, 05:39 PM | #1 |
Rep 883
Hey guys so it seems the NA section is more active so I hope we can help figure this out. I already posted this in the General Section Here but its very slow.
The Second part I want to ask is anyone with a 2007 E90 328xi post a picture of their fuse box? Im sure if i was missing a fuse somehow my car would probably run like crap or even run at all. Im running out of options here. I even took out my throttle body and cleaned it. Im leaning towards my servo motor now but i don't hear any grinding or anything. And it would help if i knew what some of the codes meant. Thanks in advance, -Max
08-30-2015, 07:41 PM | #3 | |
Rep 883
An update: so now I was cruising in 6th gear going 60 mph, I down shifted just to see it go over 2500rpm. I accelerated at the same time as if I was going to pass someone and it got to about 3100r and then my codes popped up again. So I pretty much can't accelerate now. Before I have had it go in limp mode while just normally cruising but that was on occasion. I wouldn't be able to replicate the codes. Now I can get the codes to pop up anytime now.
08-31-2015, 03:12 AM | #4 | |
Rep 306
http://www.e90post.com/forums/showthread.php?t=1151317 then this is what I did; I went to BMW they checked the car and found nothing with it, so they deleted cleared the faults, and I left...car was fine after almost a month, it did the same, so I cleared the faults myself using the BMWhat app. its working fine till now, again almost a month, and I m driving like hell to assure everything is fine.
M.Etreby
F M double Grills, 19"313, Perf.Exhaust with dimisatips, RPI red scoops, K&N filter, LUX-H8 160, Aluminum strut bar, PBX, Perf. Suspension, F30 M-Perf. Brakes |
08-31-2015, 06:27 PM | #6 | |
Rep 9,004
