08-31-2015, 05:26 PM | #1 |
Rep 56
Run flat vs non run flat trunk space
I was wondering if I should get run flat when I order 2016 328i. I am under the impression that run flats don’t come with a spare. I am also assuming that the non-run flat tires come with a spare.
So how much extra space is in the trunk? It would be nice to have a photo comparison between a run flat trunk vs a regular tire trunk, anyone want to take a photo of there trunk? How hard would it be to switch between run flat and non-run flat, since the trunk is not built to handle a spare. Also inversely so, if switching from non-run flat to run flat is there any computer mechanisms that are required for run flat tires to function properly? |
08-31-2015, 06:37 PM | #2 |
Rep 1,562
I'm not sure you can get non-run flats with your new car. There is no spare in any case. You would need to purchase one yourself and just put it in the trunk leaving very little room. I don't have run flats on either of my BMWs and have never had an issue with a flat tire (M Roadster has over 100K). I do carry a plug kit and air compressor (never needed to use either).
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
08-31-2015, 07:20 PM | #3 |
Rep 56
I believe the 18" Light Alloy V-spoke Style 398 Orbit Grey option comes with Non-Run Flat Tires.
So does that mean if I order that option, it won't come with a spare... |
08-31-2015, 09:38 PM | #4 |
Rep 267
09-01-2015, 07:42 AM | #5 |
Rep 2,118
To clarify, you have to order the Track Package to get the go flat tires and as EJL says, it comes with the inflation kit. Otherwise you will get RFT's.
09-01-2015, 08:53 AM | #6 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
Other thing to consider is that you have to get a jack to go with the spare, whether it's space-saver or not. I've put non-runflats on all of my cars that came with runflats originally. I've not had any flats yet, but I do have the "M-Mobility Kit" in the trunk. Aside from that, I also have an AAA membership, which will get you a flatbed tow to the nearest tire repair facility.
Consider also that, when deflated, runflats are good for 50 miles at moderate speeds. When you get to a repair facility, you're going to buy a new tire, because the runflat is no longer safe and nobody wants the liability of repairing one. If your tread is 50% or more worn on the other tire on the other side of the same axle, you're going to buy two. You don't want one new and one worn tire on the same axle due to safety and handling/traction concerns.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
09-01-2015, 09:31 AM | #7 |
Rep 3,493
For the most part, a can of fixaflat will solve anything that a runflat would be able to handle, modern tires are extremely tough. And if it's catastrophic enough that it doesn't, most likely a runflat wouldn't work anyway and you'd need a tow. The shredded tires you see on the highway are big rig retreads 99.9% of the time, guys that just let their tires go crazy-bald or have crazy catastrophic failures. The rubber on the inside of tires is pretty gummy so most penetrating objects tend to seal around themselves fairly well, you lose air, but not at a rate that prevents you from getting somewhere reasonably close.
09-01-2015, 09:54 AM | #8 |
demoted
454
Rep 1,172
Not really. I've had run-flats repaired twice now by the local tire shop, no problem. The last tire I had to replace was a Michelin PSS on my M3, and the critical damage was done getting to a safe place to pull over.
09-01-2015, 10:34 AM | #9 |
Rep 72
Just driven my 320d M Sport for 3000km and notice the tire tread (Pirelli Cinturato P7) has been considerably worn, bit and pieces falls off and it looks like I just tracked the car or something. Is this suppose to happen? I know I drove the car to a mountain pass spiritedly but that was only once! I didn't know P7 gets worn down so fast.
Anyway, already planning what tire to switch to when this is worn out. Looks like my option is pretty limited..With the price of P7 I could easily get the Mich PSS for the same size and cheaper which I am very keen on trying but it is not RFT.. |
09-01-2015, 01:22 PM | #10 |
Rep 6,993
Really...you had a runflat "repaired", as in a plug put in the tire, and then continued to drive on it, despite the manufacturer warning that they are only safe to drive for a maximum of 50 miles after a complete loss of pressure? I don't know how things are in Canada from a legal standpoint, but no shop I've ever visited will "repair" a runflat tire. In fact, many don't have the proper equipment to mount/dismount runflats. I got rid of mine at 14K miles because I just couldn't stand them any more.
09-01-2015, 01:35 PM | #11 | |
Rep 288
Drives: 2016 328i xDrive M Sport
09-01-2015, 08:13 PM | #12 | |
Rep 2,118
09-01-2015, 08:18 PM | #13 | |
Rep 52
09-01-2015, 09:42 PM | #14 | |
Rep 16,195
This doesn't crop up with non-RFTs, as when they go flat and one continues to drive on them they suffer sidewall damage that's anything but invisible. The 50 mile caveat is how far you can expect to drive on one that's fully deflated before it totally shreds. Rest assured if you drive it 50 miles, or even 5 miles when fully deflated, it will be toast. I keep a tire repair kit and pump on board, along with a jack and wrench, so that if I get a puncture I can fix it immediately, before sidewall damage occurs. Last edited by Billfitz; 09-01-2015 at 09:49 PM.. |
09-01-2015, 10:20 PM | #15 | |
Rep 73
Drives: 2018 X3 M40i, 2021 X5 45e
09-01-2015, 10:36 PM | #16 | |
demoted
454
Rep 1,172
09-02-2015, 02:29 PM | #17 |
Too much is never enough
655
Rep 3,079
For a complete spare with jack, etc. it's tough to beat the package Bimmerzone puts together:
http://www.bimmerzone.com/BMW_Perfor...0-328-KIT.html As far as repairing a RFT - I had a dealer patch a tire that had a puncture from a large bolt last winter. I've put well over 5K miles on it since with zero issues. As stated, run on flat tires CAN be repaired, but the correct procedure is to use a patch plug, not just a standard external plug. It also can't be too close to the edge of the tread (true of all tires). The concept of a 50 mile range on a flat tire is more of a rule of thumb than anything else. If the tire has overheated the interior of the carcass will disintegrate and the tire will be full of rubber dust or small marbles. If that hasn't happened, regardless of miles driven, there's no need to replace the tire. |
