JB4 was switching to Map4 - Logs inside
09-01-2015, 11:28 AM | #1 |
Rep 128
So I had some issues with my JB4 switching to Map 4 during WOT runs...
I got a few logs, but I can't access google drive from work so I have to post them in the "code" format... Can anyone take a look and tell me what they thing might be the issue? I'm familiar with tuning Subarus and from the looks of things to me.. the AFR that's being read is a little lean... the boost looks okay versus the target... so I'm not sure what's going on... Any help is appreciated! Map 1 Pull - JB4 Switched to Map 4 Code:
Firmware Interface Engine TMAP_V AvgIgn DWP MethTriggerMode FF MethSafeMode MethAdd MethScale MethPSI 28/02//2 7/1/2015 N54 E Series 1.99 7.1 40 100 79 0 0 0 8 BoostSafety PID Gain AutoShiftRed Fuel_OL FUA 1st_limiter 2nd_limiter 3rd_limiter FUD N20_TMAP 6CylMode 18 25 60 40 0 12 14.4 2 0 15 15 timestamp rpm ecu_psi target boost pedal iat fuelen pwm throttle fp_h ign_1 avg_ign dutycycle trims dme_bt meth fp_l afr gear ff load clock map afr2 ign_2 ign_3 ign_4 ign_5 ign_6 1.25 3391 1.7 2.5 2.4 47 107 1 36 61 11 12.7 0 49 6 1.4 100 73 13.9 4 35 0 0 1 14.2 0 0 0 0 0 2.5 3414 6.6 8.3 5.6 78 107 0 51 97 13 12.3 0 70 12 5.9 100 70 15 4 35 0 0 1 15.3 0 0 0 0 0 4.25 3453 6.2 9.7 6.4 86 107 0 45 96 14 12.3 0 42 14 6.5 100 66 13.8 4 36 0 0 1 13.8 0 0 0 0 0 5.25 3518 6.2 12.2 8.8 100 107 15 37 94 15 10.1 0 30 17 6.6 100 65 13.8 4 36 0.9 0 1 14 0 0 0 0 0 5.5 3552 6.1 12.6 10.7 100 107 28 36 98 16 9.3 0 36 40 6.6 100 69 14.8 4 36 1.8 0 1 15.5 0 0 0 0 0 7.5 3597 7 12.6 12.3 100 107 31 37 99 16 9.3 0 37 51 6.9 100 64 15.9 4 36 2 0 1 15.8 0 0 0 0 0 8.5 3649 7 12.7 12.9 100 107 31 36 100 17 9 0 37 51 7.3 100 74 17.2 4 36 2 0 1 17.5 0 0 0 0 0 9.75 3684 7.3 12.7 12.7 100 107 31 37 100 17 8.6 0 36 51 7.8 100 67 17.3 4 36 2 0 1 17.7 0 0 0 0 0 10.5 3715 7.3 12.7 12.5 100 107 31 39 100 17 8.2 0 34 51 7.8 100 73 17.3 4 36 2 0 1 17.9 0 0 0 0 0 11.25 3765 7.3 12.8 12.5 100 107 31 38 100 16 8.2 0 34 51 7.8 100 73 16.2 4 36 2 0 1 17.6 0 0 0 0 0 12.75 3796 7.3 12.8 12.4 100 107 30 40 100 17 7.8 0 36 51 7.8 100 63 16.5 4 36 2 0 1 16.7 0 0 0 0 0 13.75 3865 7.1 12.9 12.1 100 107 31 41 100 17 7.8 0 36 51 7.6 100 69 16 4 37 2 0 1 17.1 0 0 0 0 0 15 3903 7.1 12.9 12.2 100 107 31 41 100 16 8.2 0 36 51 7.6 100 66 15.8 4 37 2 0 1 16.6 0 0 0 0 0 16.25 3939 7.1 12.9 12.2 100 107 31 29 100 16 8.2 0 36 51 7.6 100 66 15.8 4 37 2 0 4 16.4 0 0 0 0 0 17.25 3989 8.5 6.5 12 100 107 5 37 36 15 8.2 0 37 51 7.6 100 73 16.2 4 35 1 0 4 16.8 0 0 0 0 0 18.25 4017 8.5 6.5 9.8 100 107 3 38 43 15 8.2 0 31 50 7.6 100 71 14.4 4 35 0.4 0 4 14.4 0 0 0 0 0 19.5 4054 7.1 6.5 8 100 107 2 34 97 14 7.5 0 33 38 7.6 100 71 13.4 4 35 0.2 0 4 13.5 0 0 0 0 0 20.75 4105 7.1 6.5 8.1 100 107 3 30 97 14 8.6 0 35 33 7.5 100 65 13.7 4 35 0.2 0 4 13.7 0 0 0 0 0 21.75 4152 7.1 6.5 8.6 100 107 7 32 100 14 9.7 0 36 36 7.6 100 67 14.8 4 35 0.4 0 4 14.4 0 0 0 0 0 23 4166 7.1 6.5 8.2 100 107 4 33 100 14 10.5 0 35 38 7.6 100 67 14.8 4 35 0.4 0 4 14.2 0 0 0 0 0 24.25 4214 7.1 6.5 7.4 100 109 0 36 100 13 10.8 0 37 35 7.6 100 71 14 4 35 0.3 0 4 13.9 0 0 0 0 0 25 4248 6.8 6.5 7 100 109 0 35 100 13 10.8 0 37 35 7.6 100 72 14 4 35 0 0 4 13.8 0 0 0 0 0 25.75 4263 6.8 6.5 7 100 109 0 35 100 13 7.5 0 35 29 7.6 100 68 13.7 4 35 0 0 4 13.7 0 0 0 0 0 27 4298 6.6 6.5 6.6 99 109 0 35 100 11 8.6 0 35 27 7.5 100 66 13.7 4 35 0 0 4 13.7 0 0 0 0 0 28 4332 6.7 5.5 6.6 90 109 0 28 100 12 8.6 0 38 27 7.2 100 65 14 4 35 0 0 4 14.1 0 0 0 0 0 29.5 4372 6.7 5.2 6.6 85 109 0 26 100 12 9 0 36 23 7.2 100 68 13.8 4 35 0 0 4 13.9 0 0 0 0 0 29.75 4403 5.5 3.2 5.9 65 111 0 27 100 12 9.3 0 45 17 7.2 100 67 14.1 4 35 0 0 4 14 0 0 0 0 0 31.75 4427 4.9 1.2 5 44 111 0 22 100 11 10.1 0 45 14 7.3 100 67 13.9 4 35 0 0 4 14 0 0 0 0 0 34 4450 5.1 0 4.9 22 111 0 32 23 10 10.1 0 48 14 7.3 100 67 14 4 35 0 0 4 14 0 0 0 0 0 Code:
Firmware Interface Engine TMAP_V AvgIgn DWP MethTriggerMode FF MethSafeMode MethAdd MethScale MethPSI 28/02//2 7/1/2015 N54 E Series 1.99 7.1 40 100 79 0 0 0 8 BoostSafety PID Gain AutoShiftRed Fuel_OL FUA 1st_limiter 2nd_limiter 3rd_limiter FUD N20_TMAP 6CylMode 18 25 60 40 0 12 14.4 2 0 15 15 timestamp rpm ecu_psi target boost pedal iat fuelen pwm throttle fp_h ign_1 avg_ign dutycycle trims dme_bt meth fp_l afr gear ff load clock map afr2 ign_2 ign_3 ign_4 ign_5 ign_6 0.25 3364 0 0 0 46 105 0 47 14 5 2.9 0 57 8 0 100 67 18.9 4 35 0 0 2 13.9 0 0 0 0 0 1.75 3361 0 2 0 46 105 0 47 14 5 7.7 0 55 8 0 100 66 16.2 4 35 0 0 2 13.8 0 0 0 0 0 3.25 3366 0.3 8.9 0.3 83 105 0 100 94 9 13.8 0 70 8 6.5 100 63 14.4 4 35 0 0 2 13.6 0 0 0 0 0 4 3400 0.3 8.9 0.3 83 105 0 100 99 9 13.8 0 70 8 6.5 100 60 12.4 4 36 0 0 2 12.3 0 0 0 0 0 5.25 3416 4.4 12.4 3.6 100 105 0 100 100 12 13.5 0 71 8 6.5 100 71 12.4 4 36 0 0 2 12.3 0 0 0 0 0 6 3436 6.9 12.4 3.6 100 105 0 73 100 14 13.5 0 71 8 6.5 100 71 15.1 4 36 0 0 2 13.3 0 0 0 0 0 7.75 3467 6.1 12.5 9.3 100 105 18 41 100 15 12 0 42 10 6.8 100 64 15.1 4 36 0 0 2 14.5 0 0 0 0 0 8.5 3511 6.1 12.5 10.9 100 105 30 38 93 16 9 0 37 38 6.6 100 67 16.5 4 36 1.9 0 2 14.4 0 0 0 0 0 9.5 3552 6.1 12.5 10.9 100 105 30 38 93 16 9 0 37 38 6.6 100 67 16.5 4 36 1.9 0 2 16.3 0 0 0 0 0 11 3582 7 12.6 13.3 100 105 31 34 99 17 9.3 0 36 51 7.2 100 60 18.2 4 36 2 0 2 16.9 0 0 0 0 0 11.75 3635 7 12.6 13.2 100 105 31 35 100 16 9.3 0 36 51 7.2 100 60 18.2 4 36 2 0 2 18.4 0 0 0 0 0 13 3665 7.3 12.7 12.9 100 105 31 36 100 16 8.6 0 35 51 7.2 100 62 18.2 4 36 2 0 2 18.7 0 0 0 0 0 13.75 3727 7.3 12.7 12.9 100 105 31 36 100 16 9 0 35 51 7.6 100 70 17.9 4 36 2 0 2 18.3 0 0 0 0 0 14.75 3753 7.3 12.8 12.5 100 105 31 38 100 17 5.6 0 36 51 7.8 100 64 17.1 4 36 2 0 2 18.2 0 0 0 0 0 16.25 3792 7.1 12.8 12.2 100 105 31 40 100 16 6 0 35 51 7.6 100 64 16.4 4 36 2 0 2 17.7 0 0 0 0 0 16.5 3858 7.1 12.8 12.2 100 105 31 40 100 16 6 0 35 51 7.6 100 68 16.1 4 36 2 0 2 17.1 0 0 0 0 0 18.25 3887 7.1 12.9 12.2 100 107 31 40 100 16 6 0 37 51 7.6 100 72 16.2 4 36 2 0 2 16.2 0 0 0 0 0 19.75 3920 9.1 6.5 11.5 100 107 13 30 100 16 6 0 36 51 7.6 100 70 15.7 4 36 2 0 4 17.3 0 0 0 0 0 20.5 3957 9.1 6.5 11.5 100 107 13 30 100 16 6 0 36 51 7.6 100 67 17 4 35 0.8 0 4 16.9 0 0 0 0 0 21.5 3985 7.1 6.5 9.2 100 107 0 38 74 15 5.6 0 32 47 7.6 100 72 14.1 4 35 0.7 0 4 14.2 0 0 0 0 0 23 4024 7.1 6.5 7.6 100 107 0 33 98 14 6.7 0 36 35 7.5 100 65 14 4 35 0 0 4 13.4 0 0 0 0 0 24 4058 7.1 6.5 7.9 100 107 2 30 98 14 6.7 0 36 35 7.5 100 65 14 4 35 0.1 0 4 13.9 0 0 0 0 0 24.5 4098 7.1 6.5 8.4 100 107 5 30 100 14 7.5 0 36 39 7.5 100 63 14.5 4 35 0.4 0 4 13.9 0 0 0 0 0 26 4124 7.1 6.5 8 100 107 3 31 100 14 7.8 0 36 39 7.5 100 69 14.5 4 35 0.4 0 4 14.5 0 0 0 0 0 27.25 4147 7.1 6.5 7.3 100 107 0 33 100 14 8.2 0 36 36 7.5 100 70 13.8 4 35 0 0 4 14.2 0 0 0 0 0 28 4184 6.5 6.5 7.3 100 107 0 34 100 13 8.2 0 36 36 7.5 100 70 13.8 4 35 0 0 4 13.9 0 0 0 0 0 28.75 4197 6.5 6.5 6.9 100 107 0 35 100 13 7.8 0 36 32 7.5 100 68 13.7 4 35 0 0 4 13.9 0 0 0 0 0 30 4218 6.4 6.5 6.5 100 107 0 34 100 13 9.7 0 38 28 7.5 100 62 13.7 4 35 0 0 4 13.7 0 0 0 0 0 30.75 4246 6.3 6.5 6.4 100 107 0 34 100 13 9.7 0 38 25 7.5 100 62 14 4 35 0 0 4 14 0 0 0 0 0 32.25 4279 6.4 6.5 6.4 100 107 0 36 100 12 10.5 0 38 25 7.2 100 68 14.1 4 35 0 0 4 14.2 0 0 0 0 0 32.75 4319 6.3 6.5 6.3 100 107 0 35 100 12 11.2 0 37 23 7.2 100 67 14.1 4 35 0 0 4 14.5 0 0 0 0 0 34.25 4335 6.2 6.5 6.3 100 107 0 33 100 12 11.2 0 37 23 7.2 100 67 14.1 4 35 0 0 4 14.1 0 0 0 0 0 35.5 4373 6.2 6.5 6.4 100 107 0 35 100 12 10.1 0 42 20 7.2 100 67 14 4 35 0 0 4 14 0 0 0 0 0 37 4400 6.5 6.5 6.4 100 109 0 35 100 11 10.1 0 40 17 7.3 100 67 13.9 4 35 0 0 4 14.2 0 0 0 0 0 37.75 4442 6.6 6.5 6.4 100 109 0 35 100 11 10.1 0 40 17 7.3 100 67 13.9 4 35 0 0 4 14 0 0 0 0 0 38.75 4463 6.6 6.5 6.4 100 109 0 35 100 11 10.5 0 40 15 7.3 100 70 13.9 4 35 0 0 4 14 0 0 0 0 0 39.5 4483 6.5 6.5 6.5 100 109 0 35 100 11 7.1 0 37 11 7.5 100 70 13.9 4 35 0 0 4 14 0 0 0 0 0 40.5 4504 6.5 6.5 6.5 100 109 0 35 100 11 7.1 0 43 11 7.5 100 67 13.9 4 35 0 0 4 13.9 0 0 0 0 0 40.75 4529 6.6 6.5 6.5 100 109 0 35 100 11 7.1 0 43 8 7.5 100 69 13.9 4 35 0 0 4 14 0 0 0 0 0 42.25 4552 6.7 6.5 6.5 100 109 0 35 100 11 7.5 0 40 8 7.6 100 65 13.9 4 35 0 0 4 13.9 0 0 0 0 0 43.25 4567 6.2 6.5 6.5 100 109 0 35 100 11 7.5 0 40 6 7.6 100 65 14 4 35 0 0 4 14 0 0 0 0 0 44 4594 6.5 6.5 6.5 100 111 0 36 100 10 7.5 0 40 6 7.6 100 67 13.9 4 35 0 0 4 14 0 0 0 0 0 45.25 4624 6.4 6.5 6.5 100 111 0 35 100 11 8.6 0 42 3 7.6 100 66 13.8 4 35 0 0 4 13.8 0 0 0 0 0 46 4646 6.7 5.3 6.5 87 111 0 26 100 11 8.6 0 42 2 7.6 100 66 13.8 4 35 0 0 4 13.8 0 0 0 0 0 47.25 4672 6.7 5.2 6.5 86 111 0 31 100 11 8.6 0 43 2 7.6 100 68 14 4 35 0 0 4 13.9 0 0 0 0 0 48.25 4694 5.6 5.2 5.7 86 113 0 32 100 11 9.7 0 51 0 7.8 100 67 13.8 4 35 0 0 4 13.8 0 0 0 0 0 49 4714 5 5.2 5.3 86 113 0 32 100 10 9.7 0 50 0 7.8 100 66 13.9 4 35 0 0 4 14 0 0 0 0 0 50.25 4735 4.7 5.5 4.9 91 113 0 35 100 10 10.5 0 50 0 6.8 100 66 13.9 4 35 0 0 4 14 0 0 0 0 0 51.5 4757 5 6.3 5.1 98 113 0 37 100 10 10.5 0 48 0 6.8 100 64 14.1 4 35 0 0 4 14.1 0 0 0 0 0 53 4785 5 6.5 5.1 100 113 0 34 100 10 10.5 0 48 0 6.8 100 64 14 4 35 0 0 4 14 0 0 0 0 0 54 4824 6.9 6.5 6.6 100 113 0 34 100 11 10.5 0 60 0 8.1 100 66 14.2 4 35 0 0 4 14.2 0 0 0 0 0 55.75 4859 7 6.5 7.1 100 113 0 33 100 12 9.7 0 44 0 8.1 100 69 14 4 35 0 0 4 14.2 0 0 0 0 0 57 4911 6.9 6.5 7 100 113 0 34 100 11 9.7 0 47 0 8.1 100 69 13.7 4 36 0 0 4 13.5 0 0 0 0 0 59.5 4948 6.7 6.5 6.5 100 113 0 34 100 11 10.1 0 44 0 8.1 100 65 13.5 4 36 0 0 4 13.7 0 0 0 0 0 60.25 4975 5.9 6.5 6.3 100 114 0 34 100 11 10.1 0 47 0 8.1 100 67 13.5 4 36 0 0 4 13.6 0 0 0 0 0 61.5 4990 5.8 6.5 6.1 100 114 0 35 100 11 10.5 0 53 0 8.2 100 66 13.8 4 36 0 0 4 13.8 0 0 0 0 0 63.25 5038 6 6.5 6.2 100 114 0 34 100 11 7.5 0 53 0 8.4 100 66 13.6 4 36 0 0 4 13.8 0 0 0 0 0 64 5063 6 6.5 6.2 100 114 0 35 100 11 7.5 0 42 0 8.4 100 67 14 4 36 0 0 4 14 0 0 0 0 0 65 5087 6.5 6.5 6.4 100 116 0 35 100 11 6.7 0 42 0 8.4 100 67 13.5 4 36 0 0 4 13.6 0 0 0 0 0 66.25 5105 6.5 3.7 6.4 64 116 0 18 100 11 6.7 0 41 0 8.4 100 67 13.6 4 35 0 0 4 13.6 0 0 0 0 0 67 5125 6.4 0 6.2 3 116 0 7 97 11 7.1 0 20 0 8.4 100 67 13.6 4 35 0 0 4 13.8 0 0 0 0 0 68 5064 6.4 0 6.2 3 116 0 7 97 11 7.1 0 20 0 8.4 100 71 13.3 4 35 0 0 4 13.4 0 0 0 0 0 Last edited by Izero; 09-01-2015 at 12:52 PM.. |
09-01-2015, 11:33 AM | #2 |
Rep 128
Note: I did change one thing... I bumped the Max Boost alarm to 18psi, and I changed the 3rd_limiter from 2.0 to 0 [disabled]
I thought that might be why it's having issues....? I did have a DMTL pump issue that I resolved and so far the issue hasn't come back, but I want a 2nd opinion. |
09-01-2015, 11:56 AM | #3 | |
Rep 80
Drives: 2015 M4
Also, if you haven't already, you should post this to N54tech as you'll find a lot more support for the JB4 there |
09-01-2015, 12:39 PM | #5 |
Rep 128
BMS DCI
JB4 [/endmods] Firmware version is listed up on the log.... I got the JB4 only a few months ago so it should be the most updated firmware... Jeff@TopGearSolutions I don't have access to that site at work either... can I just e-mail you? if so, PM me your e-mail address. Last edited by Izero; 09-01-2015 at 12:50 PM.. |
09-01-2015, 01:36 PM | #6 |
Rep 2,283
your afrs dont make any sense on that spreadsheet, can you upload to datazap? Makes it much easier for interpretation
09-01-2015, 02:22 PM | #7 |
Rep 128
09-01-2015, 06:57 PM | #8 |
Rep 265
I had a similar issue recently and mine was due to a misfire which ended up being a coil pack. Map 4 I could go WOT no issues. Map 1 as soon as (or shortly after) getting to full boost about 13 psi and also around 3800 rpms, car would sort of hesitate/stutter (this was the misfire) and check engine light in dash would come on (but not the "half engine" light on the i drive). as soon as i let off the gas and driver normal, no issues and after about 20-30 seconds the Check engine light would go away and I could drive as normal on map 4 since it automatically kicked over to map 4 when this occured.
08 335xi- CP-E DCI's,VRSF 7" FMIC, UR Charge pipe w/ Tial Q BOV, JB4 G5, PE mod, 19" Sonic Tuning SC 7 wheels
09-02-2015, 02:54 AM | #9 |
Rep 345
you are not a little lean, you are dangerously lean. AFr and Trims skyrocket.
Fuel open loop is set to 40, FUD is set to 2. Let me guess - you bought the JB4 second hand and it is configured to run with a backend flash, but you have none on your car? Revert to default settings. |
09-02-2015, 06:32 AM | #10 | |
Rep 128
Incorrect I bought it brand new and haven't changed those settings at all.... What should the settings be? I can show you other logs where I'm around 12-11 afr in those same load cells Also not running any kind of back end flash.... At all.... |
09-02-2015, 09:08 AM | #11 |
Rep 3,553
09-02-2015, 11:32 AM | #12 |
BimmerPost Supporting Vendor
24491
Rep 191,486
Jb4 goes to map 4 if car is running dangerously lean or when car is dangerously overboosting. It does so to protect your engine.
In your case it is going to map 4 because you are running lean. Reset settings to default and log again. Are you running E85? Running too much E85 can cause this issue as well
09-02-2015, 12:49 PM | #13 |
Rep 128
I'm not running E85 or any Ethanol other than whats in the 93 Octane at my local Sunoco station... I change my oil regularly, just replaced all of my plugs, and am pretty meticulous with fixing anything that's broken.
The old plugs I took out actually didn't look bad at all, but I figured since I didn't know when they were done last when buying the car it was better that I just do it myself. I changed all the JB4 settings back to "default" and I put the most updated firmware on there just to be sure. Here are the settings I used. Boost Safety: 18.0 Default Wastegate Position: 60 [This was set at 72] PID Gain: 25 Auto Shift Boost Reduction: 60 FF/Wastegate Adaption: 80 Fuel Open Loop: 70 [This was not 70] Meth Safety Mode: 0 Meth Trigger Mode: 0 [This was set to 50 somehow] Max Boost 1st: 12.0 Max Boost 2nd: 14.4 Max Boost 3rd: 0.0 Future Use A: 0 Future Use D: 0 N20 TMAP (0/1): 15 6-Cyl Timing Logging: 15 TMAP Voltage: 1.97 Firmware Ver: 31/2 Interface Ver: 7/1/15 Avg Ign: 8.9 |
09-02-2015, 01:01 PM | #15 |
24491
Rep 191,486
Sounds good
09-02-2015, 01:09 PM | #16 | |
3442
Rep 79,211
09-02-2015, 01:21 PM | #17 | |
Rep 128
I'll take some logs today on the way home, god I wish the USB cable they gave you was about 3' longer so I could close my glove box while logging... hahaha |
09-03-2015, 08:01 AM | #18 |
Rep 128
Took some logs this morning:
http://datazap.me/u/izero/after-dmtl...log=0&data=1-4 Let me know what you call think.... the AFRs look a little better but they are still lean where I'd expect peak torque to be which concerns me a little bit. Any suggestions? |
09-03-2015, 01:03 PM | #20 | |
Rep 128
How do you enable 6 cyl ignition logging? |
09-03-2015, 02:06 PM | #21 | |
Rep 3,553
09-03-2015, 02:52 PM | #22 |
24491
Rep 191,486
CPS_7000 options:
i8a0s timing corrections: 1 ijeos timing corrections: 2 ilaos timing corrections: 3 i8a0s raw timing values: 4 ijeos raw timing values: 5 ila0s raw timing values: 6
