Hesitation on Light Throttle - N53
09-03-2015, 06:53 AM | #1 |
Rep 104
Afternoon All,
Car is a '08 E92 330i MSport (N53) Experiencing a slight hesitation in the mornings when applying light throttle. (Usually pulling off driveway). It seems to resolve itself quite quickly once warmed up.No EML's or anything on the dash, car seems quite happy with itself. Pulled the codes (BMWWhatApp/CARLY), I suspect at least one of these will be the culprit; Fault: ifferential pressure sensor intake manifold / Pedal sensor plausibility / Air mass meter, signal correction Code: 2B07 Fault: :2, potentiometer, throttle / pressure sensor intake manifold / Accelerator pedal module, pedal sensor 2, Working range: High Voltage / Differential pressure sensor intake manifold / Pedal value sensor 2 / Air mass meter, signal correction Code: 2B06 Fault: :Intake air temperature sensor bank 1 / Intake manifold pressure Code: 2AFB Fault: :Nitric Oxide Sensor Code: 30DA Can anyone shed any light? I have a BMW warranty (Purchased via Mondial), and was wondering if any of the above were out of scope if replacement is required. Warranty is comprehensive). I've cleared the codes previously but they always seem to re-register themselves within a day or so. Thanks Chaps |
09-03-2015, 07:15 AM | #2 |
Rep 3,201
Drives: E92 325i MSport Coupe
Looks like your intake pressure sensor has failed. And that should be covered by the warranty - it's not a 'wear and tear' item...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
09-03-2015, 07:32 AM | #3 |
Rep 621
Drives: E93 M3 LCI DCT & F01 730d SE
I have this exact same issue which has developed within the last 2 weeks on my 330i so will be interested to hear what the solution is for yours.
09-03-2015, 07:36 AM | #4 |
Rep 104
Thanks, I'll see what the part is like in terms of pricing as I have an excess on the warranty.
Is this sensor known as the MAF on the N53? I have found it on RealOEM listed as 'Differential pressure sensor' with a part number of 13628617097 Last edited by Stoatmaster; 09-03-2015 at 07:42 AM.. |
09-03-2015, 10:33 AM | #5 |
Rep 3,201
No it's not the MAF. It's the small unit shown in this pic.
See the five parallel lines to the right of the word 'BMW' on the inlet manifold, top right? The pressure sensor is mounted where one line is shorter than the rest.
09-03-2015, 01:28 PM | #6 | |
Rep 621
09-07-2015, 02:34 PM | #7 | |
Rep 621
Mine was put on the diagnostic software at the local Indy this morning and it was showing the nitric oxide fault and no. 6 cylinder misfiring. Car going in on Monday for investigation. Have found out from dealer that the car had all of its injectors replaced in 2008 under a recall and the high pressure fuel pump replaced in 2014. |
09-07-2015, 04:46 PM | #9 | |
Rep 621
Just literally come back from a hick spin to see what it would drive like and it started off with a misfire again on what seems like one cylinder and then after 1 mile of A road driving it was all back to normal again. Will be interested to hear whether this sensor makes a difference to you or not... |
09-08-2015, 02:58 AM | #10 | |
Rep 3,201
Just my five penn'orth...
09-08-2015, 05:09 AM | #11 |
Rep 621
Thanks phil. The car is going in on Monday unless I see a vast improvement over the next few days.
01-02-2016, 04:35 AM | #12 |
Rep 621
So after shelling out £300 for plugs, 2 coil packs and labour I decided to take things into my own hands.
I changed the coil pack on cylinder 6 despite the diagnostics showing cylinders 4&5 were being at fault but this didn't change anything. Still a misfire on cold start and a hesitation on the throttle until the engine was warm. So I then changed the injector and instantly it seems to have solved the problem. I'll try and use the car for a longish journey soon and see if there are any further issues. OP - did you get to the bottom of your issue in the end? |
