2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding: Delay after folding mirrors
      09-03-2015, 08:23 PM   #1
BoomWasabi
Drives: M4
I have coded my car to open and close windows, mirrors and sunroof using CA and key fob. In general it works, but not quite like I want it.
Here is what I would like to achieve:
1. Whenever I lock the car using single press of the lock button on key fob, I'd like to fold the mirrors immediately.
2. If I keep holding the lock button, it should close windows and sunroof.
3. Optionally: similar behavior with CA. Touching the door handle for 1 second should lock the car and fold mirrors, holding it for longer than 1 second should close windows and sunroof.
Code:
KOMFORTSCHLIESSUNG_FB       aktiv
KOMFORTSCHLIESSUNG_PA       aktiv
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN    aktiv
KOMFORT_SCHLIESSEN          0
// delays between closing windows and roof
KOMFORT_SCHL_VORNE werte    15 (1500ms)
KOMFORT_SCHL_SHD werte      15 (1500ms)
Usually I want to keep my sunroof tilted. And 66% of the time my current settings work. I.e. car locks, mirrors fold, and sunroof remains tilted. But often it will also close the sunroof. Is there a separate value to set a delay between folding the mirrors and do the rest of the "convenient closing" stuff?
      09-03-2015, 08:38 PM   #2
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
Code:
maybe increase KOMFORT_SCHL_SHD to like 10 secs 10000ms that's why it's set to 3500 by default i guess...
also hex 15 is not 1500ms... it's 2100ms
      09-04-2015, 08:47 AM   #3
BoomWasabi
Drives: M4
Thanks, will try.
Duh!
      09-06-2015, 12:50 PM   #4
BoomWasabi
Drives: M4
Ok, this did not help. ;-(
Played a little with the key fob and noticed this: if windows are not closed, then briefly hitting 'Lock' button will lock the car, fold the mirrors and move the windows up for about a half inch. Tried it a dozen of times, and it is pretty consistent. When the windows are closed, and the roof is fully open, then locking the car will cause the roof to move a little. If the roof is tilted, then it is a crapshot - could move it a little or close it all the way down.
I guess the 'Lock' button logic is defined something like this:
1. Lock the car and wait for KOMFORT_SCHLIESSEN time
2. Fold Mirrors and Check Windows
2.1. If windows down, start closing them. When closed wait for KOMFORT_SCHL_SHD time
3. If roof is not closed, start closing the roof.
So, if window are already closed than the KOMFORT_SCHL_SHD delay is ignored.
2addicts
