What rpm is full boost?
09-03-2015, 09:16 PM | #1 |
Rep 466
I have a e90 with fbo running 91 octane on map 5. My car hit full boost about 14psi at 4,000rpm. It seem kind of late and laggy to me. What rpm are you supose to hit full boost in these cars on say 3rd or 4th gear?
2007 e90 335i
pure stage 2 DD turbos, rb inlets |
09-03-2015, 09:55 PM | #2 |
Boost
1355
Rep 3,697
Drives: 135i M-Sport
Depends on boost target, age of turbos, boost leaks but full spool is generally around 3k RPM for an aggressively tuned car from what I've seen
09-03-2015, 11:32 PM | #3 |
Rep 1,031
Drives: 335 E92 DCT
what he said above best to check your logs and you'll know exactly
Certified Australian
09-04-2015, 07:06 AM | #5 |
Rep 554
Drives: 2013 335is E93 6MT
If by full boost you mean the end of the steep ramp up from 2500 RPM on a pull, I hit that at about 3100 RPM. That's 17 psi, but I hit peak boost (18.8 psi) at 4100 RPM.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
09-04-2015, 04:24 PM | #6 | |
BimmerPost Supporting Vendor
24494
Rep 191,499
Post logs
09-04-2015, 05:04 PM | #7 |
Rep 466
Just by the jb4 fuel gauge hijack for a boost gauge it shows me hiting 12-14psi somewhere between 3,500-4,000 rpm in 3rd or 4th gear. Seam to spool slow. I will log will mbd later today and post it up. Thanks.
2007 e90 335i
09-04-2015, 05:46 PM | #8 |
Rep 319
15lbs at 2700rpms and 20lbs at 3700rpms
20lbs to 5200 rpms drops to 15 at redline Stock turbos, e85 and stock inlets, 100k mile stock turbos I'm quite surprised by them |
09-04-2015, 06:31 PM | #9 |
3442
Rep 79,211
Is the question when do the turbo's spool up or when do you hit peak boost? Would depend on tuning and other things but peak boost is usually right before 4000PRM.
09-04-2015, 08:28 PM | #10 |
Rep 1,070
Check logs; compare request to actual. When I was looking at a boost issue a while back, I looked at requested boost to actual boost and noticed it took almost 2 seconds at WOT to hit very near requested and stay there. Once I resolved my issue with diverter valves and logged again, I'd hit near request in well under one second..
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
09-05-2015, 06:20 AM | #12 |
Rep 84
Depends,
This is what my boost curve looks like till 18.2 psi target. http://datazap.me/u/odanbe/mhd-stage...=0&data=4-6-22 |
