335i JB4 9 Codes!!!!!! After new plugs and coils!
09-04-2015, 12:39 PM | #1 |
Rep 66
Hi guys, me again with more problems.
So I ended up putting new plugs and delphi coils in my e90 335i. I warmed it up three times, and my car automatically took off its engine light for misfire cyl 2. Everything ran great. However, yesterday I let my Dad take my car to work and he said the engine light came on when he was coming back. I checked to see the codes with the jb4 and there are 9!!!!! However, the jb4 only read out 7, for two of them it kind of lags, it does not show the speedo and tach moving but it still waits for the two codes to go through. Here is what the JB4 gave me: 2E7 2E19 2E1B 2E1A 2E1D xxxx Tach and speedo didnt show these two codes? xxxxTach and speedo didnt show these two codes? 29F5 I know these are cat codes which is fine 29F4 I know these are cat codes which is fine What is going on with my car? |
09-04-2015, 12:53 PM | #3 |
Rep 390
May be injectors.
My Build Thread: http://www.e90post.com/forums/showth...8#post16918878 |
09-04-2015, 12:58 PM | #4 |
Rep 240
09-04-2015, 01:20 PM | #6 |
Rep 66
Bosch ZGR6STE2 plugs, I did not gap them.
Delphi Gn10571 coils. I pressed the coils really hard to make sure they are seated. Here is the weird part, my obd scanner only shows the 2 cat codes. Is the jb4 glitching? And the other thing is, the car runs good with the new plugs and coils even with these codes. I deleted these codes with jb4 and will see if they come back but im stumped. P.S my car does blow white smoke at times which is not condensation! However, i am completely catless with muffler delete. |
09-04-2015, 01:24 PM | #7 |
Rep 2,084
Make 100% sure you plugged the connector onto the coils as far as you can. Those coils are for N55 and do not have the mechanism that "pulls" the connector onto the coil when you close the lever on top of the coil like the N54 coils do. You have to push the connector as far as possible, then close the lever. If you don't you could get misfire codes.
2013 135is DCT Carbon Black Metallic |
09-04-2015, 01:45 PM | #8 |
3442
Rep 79,211
Yea as others mentioned I dont think the coils are seated fully.
If they are still fully seated then you may want to look into your white smoke issue is that is a different problem. Otherwise I'd reinstall a fresh map and firmware on the JB4. |
02-16-2016, 09:48 AM | #10 | |
Rep 39
02-16-2016, 10:50 AM | #12 |
Joint Chiefs of Staff
4927
Rep 116,037
02-16-2016, 12:18 PM | #14 |
Rep 998
I recently purchased a brand new set of bosche coils and got a bad batch. No idea which one was bad, but didn't want to deal with it so returned all 6 and purchased the new and updated Eldor ignition coils off ecstuning. All my problems went away and the car pulls hard Here's the part # just in case:12138657273
02-22-2016, 12:02 PM | #15 |
Rep 11
