Boost and Timing Corrections
09-05-2015, 09:40 AM | #1 |
Rep 1,070
Hey guys,
I ran (4) logs this morning. I'm running 93 pump gas. It was 72*F and my AIT's never crossed 100. That said, it seems that after peak boost roughly 5,000 or so RPMs, the car is pulling timing. http://www.datazap.me/u/jwebb335xi/l...-16&mark=59-78 http://www.datazap.me/u/jwebb335xi/0...0-13&mark=8-20 I'm going to add a gallon of E85 and log again in the morning, but I'd love comments if you all have them.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
09-05-2015, 09:57 AM | #3 | |
Rep 1,070
JWebb335xi
09-05-2015, 12:34 PM | #5 |
DisplacementReplacement
440
Rep 1,131
E85 is the most cost effective octane booster, couldn't agree more@!!!!!!!!
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
09-05-2015, 02:14 PM | #6 | |
Rep 1,070
The first log/picture is for a 3rd gear in 4th pull. http://www.datazap.me/u/jwebb335xi/5...2-13&mark=19-7 The second starts in 2nd gear, through 3rd and into 4th. http://www.datazap.me/u/jwebb335xi/8...7-8-9-10-12-13 Timing appears to be solid with just a bit of e85 added. I noticed my gauge showed some knock voltage, which I set during this run and never have used before.. The number was very small, but I don't really know what it means.
JWebb335xi
09-05-2015, 02:23 PM | #7 | |
Rep 1,070
http://www.datazap.me/u/jwebb335xi/m...-6-7-8-9-13-16
JWebb335xi
09-05-2015, 03:02 PM | #8 |
Rep 2,872
Timing looks good (I'm on mobile, but as far as I can tell anyway)!
My car has timing corrections on any brand 93, regardless of map, new plugs, blah blah blah, but with even 1-2 gallons of E, she holds all the timing that's requested. |
09-05-2015, 04:13 PM | #9 |
440
Rep 1,131
That's exactly what i experience, i can run a fairly aggressive timing curve up to 10.5 or even 11 degrees up top with just a gallon or two or E and my timing is clean, really amazing stuff@!!!!!!!!!!!!!!!!
09-05-2015, 04:54 PM | #10 | |
Rep 1,070
JWebb335xi
09-05-2015, 04:58 PM | #11 | |
Rep 1,070
JWebb335xi
09-05-2015, 05:59 PM | #12 |
Rep 554
Drives: 2013 335is E93 6MT
No, I have an aggressive custom tune, and, at least for my car, if I want the boost, I have some negative timing corrections -- which E85 completely smooths out. Somebody called it "band-aiding" your tune, as if it were a bad thing, but the other option to get rid of the timing corrections would be to lower the boost. Adding E85 is a no brainer.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
