Engine Overheating!!!!!!
09-07-2015, 10:24 AM | #1 |
Rep 1,321
Drives: Truck in snow, coupe in summer
Driving to work on Labor Day bc trains were operating on a weekend schedule. Get about 1.5 miles from work and I get yellow engine heat warning sign. Tried to make it to the garage and bam hit with the red warning! Rolled into garage. I checked coolant and it was at a good level. Letting the car sit for a few hours and may try to drive the 8 miles home. Prolly not a great idea. I will see if fan comes on and I get a yellow warning. Then I will pull over and get towed home.
2009 BSM E92 335xi - RR600's/FBO-VRSF/Apex Arc 8/Wedge E60 MHD/Fuel it Stage 2/BMW PE w/ Dimisa Tips/Alpina TCU/Dinan Springs/RB Inlets/3.5 Bar TMAP
09-07-2015, 12:33 PM | #2 | |
Rep 2,049
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
09-07-2015, 01:15 PM | #3 |
Rep 194
When my waterpump died I cut the car off at the yellow warning light and let it sit for 3-4. When I started it back up apparently the pump started working again because the fan wasn't losing its mind so was able to limp the car home 4 miles away. If you start it up and the fan isnt on max, you may be able to make it home.
09-07-2015, 01:20 PM | #4 |
Rep 2,233
Drives: '12 M3
Hmm... Towing a car home or buying a new motor after driving with a blown water pump?
Sounds like an extremely difficult choice... |
09-07-2015, 01:26 PM | #5 | |
Joint Chiefs of Staff
4927
Rep 116,037
Mike |
09-07-2015, 02:41 PM | #7 |
Rep 494
Nope, water pump usually does not give any warning. Mine would die, but work after restarting the car. I got home and replaced the water pump + cleared all those pump failure codes. Do a thermostat while you are at it too, as it is same job twice if it fails later.
09-07-2015, 04:36 PM | #9 |
BimmerPost Supporting Vendor
24491
Rep 191,486
Good luck
Let us know how it goes
