N54 Engine Malfunction (Off Gas, High RPM)
09-10-2015, 07:55 PM | #1 |
Rep 47
Car Info:
-335i xDrive -6MT -Turbos replaced under warranty ~5K miles ago I noticed this problem occurs somewhat regularly. Typical situation below: I'll be doing a 2nd or 3rd gear pull, nearly to the redline and then let off of the power. As the RPMs fall through around 5K or 6K I get an "engine malfunction" warning. It happens rarely as i try not to punish the engine like that too often. From time to time I just get carried away and forget to shift up. The problem is solved by turning the car off and then turning it back on. Anyone have a similar experience? |
09-13-2015, 09:37 AM | #3 |
Rep 4
I have the same problem. Only codes I have gotten have been something about a turbo leak. I haven't actually had this happen in awhile, as I know how for to push the car before it does it. Although, for some reason it almost feels like it happens a lot easier when the car is really hot. Would like to know if there is any fix. My turbos were also replaced about 20k ago.
-07 335i coupe 6MT |
09-13-2015, 12:10 PM | #4 | |
Rep 2,049
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
09-13-2015, 12:11 PM | #5 | |
Rep 2,049
Either way it's going to be a guessing game until u read the codes.
'10 e92 N54
01-31-2016, 10:31 PM | #6 |
Rep 47
Don't mean to bring back this old thread, but I was finally able to re-create the problem on the way back from DC today. I was having fun in a tunnel and ended up letting the car drop down in 3rd gear through most of the rev range. Just like that limp mode kicked in.
Luckily I have a COBB AP now so I pulled over and read the code. The code is P2A87 "Outlet-VANOS, mechanics". The AP info says that it's likely dirty VANOS solenoids, which is very possible since they have likely never been cleaned. Like before, I just pulled over, restarted the engine and was back to full power. Just wanted to respond in case someone else can find my experience useful. |
Tags |
335, engine malfunction, high rpm, turbo |
