How do you drain the oil
09-11-2015, 02:52 AM | #1 |
Rep 980
Drives: '08 BSM 335i e92
I'm a pretty DIY-friendly guy and I like taking on as many tasks as I can related to my car. That being said, I've always done my own oil changes, ever since I started driving. My 335 is no different. I've done all of it's oil changes under my ownership, however, recently something came to mind that puzzled me. I have an 08 335i with pretty much all the bells and whistles. Thus, I have the factory oil cooler. Something I thought about recently while doing an oil change that I had never thought about before was that I'm not draining ALL of the oil from the system. I'm doing the majority of it, but not ALL of it. I jack the front of the vehicle up via the central jacking location, then secure it by placing jack stands under the side skirts at the jacking points. Then I proceed to place a pan under the car and remove the oil drain plug. While it's draining I go up top and remove the filter cap and replace the filter and both O-rings. At this point I notice there is a flaw in the design of the filter housing where all the oil doesn't drain out of the filter housing due to it being on a slight angle. I usually get a few rags or paper towels and soak up the excess oil in the filter housing and wipe it clean. Then, reinstall the new filter into the housing. By this time the oil is just about done draining from the bottom, and I replace the copper crush washer and re-torque down the drain plug. So the vehicle should be empty of oil.... but then I thought about it.... I have an oil cooler. Assuming this stays full of oil, how would I drain the oil from that? Being that the thermostat only opens the oil cooler once the oil temp reaches a certain temperature, I'd assume the thermostat is "shut" when the engine is off (during the oil change) so how would one drain the oil that's left inside the cooler? Or does everyone just drain the oil from the pan and filter housing and call it "good enough"?
'08 BSM E92 335i 6MT/MHD stg 2+/VRSF 7" FMIC/VRSF CP/HKS BOV/VRSF catless DPs/BMS DCI/muffler delete/BC Extreme lows/OEM style 167s/BMS high side OCC/Mishimoto low side OCC/etc
09-11-2015, 05:22 AM | #2 |
Rep 2,793
I take my whole engine apart and sop up every drop of oil.....then refill.....takes week but I have the cleanest engine in town
I jest,I jest! |
09-11-2015, 07:49 AM | #5 | |
Rep 1,070
Instead, spend your time making sure that you change coolant, brake fluid, trans, and diff at proper intervals. How about a nice clean air filter too!
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
09-11-2015, 12:17 PM | #6 |
Rep 980
I can't use rhino ramps, I'm too low. The rhino ramps are too steep for my car to ascend.
09-11-2015, 12:22 PM | #7 |
Rep 670
The factory oil cooler and lines hold less than a quart. Don't worry about it.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
09-11-2015, 06:05 PM | #8 |
Rep 1,643
Get some low incline raceramps. Best investment I ever made. I used to do what you do and it sucked.
2007 E92 335i MT
09-11-2015, 06:56 PM | #9 |
Rep 272
Put a 2x4 in front of each ramp and it will move your bumper up high enough to clear the ramps . It's the only way I can use regular rhino ramps .
FBO , MHD , tuned
09-11-2015, 08:19 PM | #10 |
Rep 704
09-12-2015, 10:40 AM | #11 |
Some dude
92
Rep 1,780
There is no need to worry about the oil left in the cooler. Even it it were a huge Fluidyne with 1+ qt capacity, it is not worth the effort to drain and pre-fill the oil cooler and lines. If you have suffered internal engine damage or complete failue, the cooler should be scrapped anyway.
RRT
E92 335i/6MT with stuff and things |
09-12-2015, 11:27 AM | #12 | |
Rep 695
09-15-2015, 12:32 PM | #13 | |||
Rep 980
