How do you assemble this BOV?
09-13-2015, 10:00 PM | #1 |
Major Private First Class
450
Rep 1,327
Drives: 2010 E90 335i M Sport
I bought a VRSF charge pipe and Tial BOV. It didn't come with any instructions. WTF??? Do they they assume all their customers are mechanically inclined? I mean, I got all the OEM parts out so I know that much but I've never owned a turbo car before let alone seen a BOV. Where does the brown Oring go?
Before you say put it on the VRSF CP flange, it keeps popping off. Is this correct? Thanks
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs Last edited by N54Society; 09-13-2015 at 10:05 PM.. |
09-13-2015, 10:50 PM | #3 |
Rep 704
One more thing make sure you lube the sensor and twist it left and right while putting enough pressure to push the sensor in. Its not ricket science. And make sure to push it in the center of the sensor and not the tabs.
09-13-2015, 11:28 PM | #4 | |
450
Rep 1,327
09-14-2015, 12:36 AM | #5 |
Rep 704
It should came with a barbed vacuume connector that connects the tial vacuume hose to the oem hose from the intake maniforl. Be careful not to break the nipple from the intake manifold.
09-14-2015, 02:58 AM | #6 | |
450
Rep 1,327
09-14-2015, 04:55 AM | #7 |
7456
Rep 10,259
That's it.
You don't need Tiago, you need to do some reading. There's a few DIY's around (which Tiago would direct you to anyways). Google N54 charge pipe install and you're good to go. |
09-14-2015, 06:00 AM | #8 |
Rep 416
You'll have to tap a hole in the intake manifold or use an adapted to connect it to the stock line (not recommended). Also you'll realize the line included is to big for the barb (adapter) included. Also on mine the water/meth bung was crostreaded. I had to use a tap to clean it up or my nozzle wouldn't go in more than 2 turns. I think there's more QC needed.
Check out this post for pictures. http://www.e90post.com/forums/showth...1161102&page=2 Last edited by LQQKOUT; 09-14-2015 at 06:27 AM.. |
09-14-2015, 07:45 AM | #9 |
Rep 704
No! Thats not it! Contact tiago they sent me the wrong one too! But he managed to expedite the right part. It should be both male end. Not female male end.
09-14-2015, 08:25 AM | #10 |
Rep 102
Did you remember to take the large O-ring out of the stock Charge pipe and transfer over to the onside of the new charge pipe? It goes inside a little groove near the Throttle Body connection. Just buy a longer Vacuum hose and run from BOV to the stock vacuum connector. Advance Auto sells the vacuum hose/windshield washer hose.
09-14-2015, 12:50 PM | #11 |
Rep 416
The CP comes with a new o-ring from VRSF, just make sure to install it. The stock vacuum/boost fitting is to small in diameter and will slow down BOV response.
09-14-2015, 02:05 PM | #12 | |||||
450
Rep 1,327
EDIT: Apparently drilling a larger hole into the intake manifold will resolve this.
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs Last edited by N54Society; 09-14-2015 at 02:25 PM.. |
09-14-2015, 02:12 PM | #13 | |
Rep 2,084
You might also want to put a lighter spring into the BOV. It probably has an 11psi spring now. I went down to a 10psi spring and it made it more responsive and less flutter.
2013 135is DCT Carbon Black Metallic |
09-14-2015, 06:39 PM | #17 |
Rep 439
Drives: 07 E92 335 / 17 F16 X6 35i
My VSRF CP and BOV are showing up tomorrow so I'll make sure to come back here with any pics/info I figure out as well.
@mikecentola
07 335i SG / CR - LOTS OF MODS - BUILD THREAD 17 X6 SG / LCSW - ZMM/ZCW/ZDA/ZDB/ZLP/ZPP/MPPK - H&R VTR / Vossen 22x10.5/22x12 18 Ford Raptor |
09-14-2015, 11:42 PM | #18 | |
450
Rep 1,327
Please do. Thanks!
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
09-15-2015, 02:08 AM | #19 |
450
Rep 1,327
Here's the ghetto rig from last night. Yes, the y-connector you see is from the stock diverter valves. I forgot to take pictures then, mostly because I was upset regarding the missing barb(s):
And then tonight, after getting the proper barb and new vacuum line after work: It's still a temporary fix. I'm planning to drill/tap the intake manifold and place the barb that came with the kit on eventually.
09-15-2015, 07:22 AM | #20 |
2097
Rep 43,350
You can use either the adapter we include to tap your manifold or you can purchase an adapter to go from the small line to the large line from autozone/advanced auto. Tial recommends the use of a full 1/4" line in order to make sure the BOV works correctly which is why we include that adapter.
I personally have run the adapter that mates from the smaller line to the larger line without issue but we have recently started offering Tial's recommended option. |
09-15-2015, 01:28 PM | #22 | |
450
Rep 1,327
Thanks for the input.
