0-60
01-26-2006, 10:07 PM | #1 |
Rep 81
0-60
Why so much variation in the numbers? it seems that if 3-4 runs are done around a certain time...it would be fairly reproducible. 5.6-6.7 is quite a range.
01-26-2006, 10:20 PM | #3 | |
Rep 151
01-26-2006, 10:22 PM | #4 | |
Rep 4,838
01-26-2006, 10:24 PM | #5 | |
Rep 151
Hey, with all the shit in those burgers, I'm sure a fat guy can bring the time up a few 10th's! |
01-27-2006, 12:37 AM | #6 |
Rep 2,168
What Shim and DTm both said... and I will add "mechanical sympathy" to that list.
Some testers drive it like they stole it, some have a policy of treating cars like their owners would in order to get more real-world times...
'05 E90 325i | '06 E90 325i | '08 E90 325i LCI | '13 F30 328i M-Sport | '14 F10 535d M-Sport
Current: '19 G01 X3 M40i |
01-27-2006, 12:43 AM | #7 |
missing two turbos.
581
Rep 4,859
Drives: fast around corners.
mag racing no good.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
01-27-2006, 12:48 AM | #8 |
Rep 1,038
Drives: X5
The driver has a big factor on the 0-60. If you can't drive the car....
New: 12 X5 xDrive35i Premium Alpine White/Cinn Brown
Old: 08 E92 335i|Space Gray/Coral Red/Gray Poplar Old: 06 E90 330i|Black Sapphire/Black /Burl |
01-27-2006, 02:11 AM | #10 | |
Rep 2,168
I thought this would loose time though as the engine will bog down a bit when you let go. The scenario where it would seem to make any sense is if the car had a low second gear, and a low RPM limit and you had to do a 2-3 change to reach 100km/h just at the end. Starting in 2nd would save a gear change. So I don't see this as being a general rule, perhaps for some specific types of cars only.
01-27-2006, 07:12 AM | #11 |
Rep 10,858
Never in a BMW. 1st will always be quicker. Some folks find it easier to negotiate slippery conditions (ice) by starting in 2nd.
The slowest 0-60 times are for automatics loaded with options tested under 'normal' driving conditions (Edmunds). The fastest times are Euro model manuals tested under 'hot-rod' techniques (Car&Driver). Driver is not usually a big factor in magazine comparos -- just what starting/shifting techniques the magazine tries to keep consistent. E.g., Car & Driver prides themselves on being hotshoes, and usually post times that are a 1/2 sec or so quicker than Road & Track. Last edited by stressdoc; 01-27-2006 at 07:57 AM.. |
01-27-2006, 07:50 AM | #12 |
Rep 1,832
Drives: bmw e90 320d
the main factor is the driver
e90 320d,arktis,lumber support, hifi speaker, alarm, dakota beige, 162 18", xenon with washer spray,window chrome trimmings, professional radio, 6 cd changer wood trimmings
6 speed manual. |
01-27-2006, 07:57 AM | #13 |
Rep 69
I can't remember where I read it. At the time I had an E36 M3 Evo and it may have been one of the bmw magazines that suggested 0-60 in 2nd gear (as it will easily hit 60 in 2nd).
01-27-2006, 08:01 AM | #14 |
Rep 10,858
Keeping it in 2nd (maybe even redlining it), yes. Starting in 2nd? Bizarre. The M3 Evo loves revs, so unless you could get (and keep!) the tires spinning sufficiently to keep it in the powerband, it would bog compared to launching in 1st.
You can do an effective start in 2nd in a Corvette, but not a 3-series. Last edited by stressdoc; 01-27-2006 at 03:02 PM.. |
01-27-2006, 08:02 AM | #15 |
S0THPAW
8784
Rep 7,853
Always use 1st gear for those 0-60 times. (First put DTC totally off)On a dry tarmac road put it in first, rev it to about 3000rpm. 'Dump' the clutch and hit the throttle with 'some wheelspin' you 'll feel, then @ 6600rpm shift as fast as possible to second and do the same again:slam the throttle
At 6600 shift again etc etc. Disclaimer, be careful and don't bring yourself or others into danger I'm no streetracer |
01-27-2006, 02:03 PM | #16 | |
Rep 176
You'd start in 2nd, shift to 3rd, and be done with the race. Most cars with the torque to do this were big block V8s pulling mid-13 second or better q-mile times. The high revvers won't hold the wheelspin if you try to start in 2nd. |
