Where can I post or send my logs to be reviewed?
10-01-2015, 02:43 AM | #1 |
Rep 76
I just recently bought a 08' 335i e92 and right away went and got the Cobb v3 because I've heard it unleashes a beast. The car feels like it has a lot more power but it seems to come with more risks. I ran the sport map and whenever I accelerated hard, I seemed to have very large numbers in the cylinder correction which seems dangerous. I tried to run aggressive one time and my car went into limp mode. I decided to change both the spark plugs and coils tonight. I took the car out for a drive and it looks like the cylinder correction has decreased but still apparent. Who can I send my logs to and have them checked out. Im getting my car walnut blasted next weekend. My car has 100,000km, 2008, auto, bms dci. Im in Vancouver Canada, running 94 Chev gas. What else could cause possible cylinder corrections besides the carbon build up on the valves that Im going to get cleaned up and possibly injectors??
Any help helps because I'm new to this tuning and boosted world. Thanks in advance. http://datazap.me/u/604e92/stg1-aggr...og=0&data=3-13 http://datazap.me/u/604e92/stg-1-spo...og=0&data=3-13 |
10-01-2015, 08:05 AM | #2 |
Rep 776
Canadian gas is garbage. Especially Chevron. Didn't they just get busted trying to sell 87 as 94? it was in the news here.(alberta)
Stick to sport map. After you get your valves blasted some of that timing will clear up. Check out the B.C sub forum here. They will help you out. |
10-01-2015, 08:05 AM | #3 |
Rep 390
Sell Cobb get JB4 and stack with MHD. Or just one or the other. Ken (wedge) or PTF can tune your Cobb if you plan to keep it. MHD as token over the flash tuning world.
My Build Thread: http://www.e90post.com/forums/showth...8#post16918878 |
10-01-2015, 08:29 AM | #4 | |
Rep 776
Mhd ots maps are garbage. Cobb is probably the best solution for people who are not fbo, and just want a little extra out of their car. I've gone from dinan, to jb4, to cobb, to mhd, back to jb4. Cobb by far was the smoothest. |
10-01-2015, 08:39 AM | #5 | |
Rep 554
Drives: 2013 335is E93 6MT
Voice recognition software problems?
Cobb could not possibly be the best solution for someone who just wants a tune. You're pissing away $900 on a piece of hardware when all you need is your phone.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
10-01-2015, 09:03 AM | #6 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Jb4 + pump flash would be ideal for you IMO. Cobb is eh, only worth it if you're gonna do a protune, but then you might as well switch to MHD for 1/10th the price for the exact same thing.
10-01-2015, 09:04 AM | #7 | |
Rep 776
http://www.e90post.com/forums/showthread.php?t=1169126 Cobb is the smoothest, safest, most reliable, user friendly tune. Sure. It costs more. Lets not highjack this thread into a tune debate. I will start another thread for that now. |
10-01-2015, 09:14 AM | #8 | |
Rep 3,475
10-01-2015, 09:19 AM | #9 |
Rep 3,553
Could be the gas, could be carbon build up.
As for MHD vs COBB, some people have had issues with the MHD OTS maps, but the majority do not and the same goes for the COBB OTS maps and the JB4 OTS Backend Flashes. Best thing to do now is try a different fuel and see if that works. If not, walnut blast. If neither of those work, get a pro tune. |
10-01-2015, 09:28 AM | #10 | |
Rep 554
Anyway, I had no timing problems when I was running the MHD OTS maps, so perhaps this is just a YMMV problem when it comes to a one size fits all solution. Just because a couple three out of however many people have negative timing corrections on a stock MHD map, while one of those people doesn't have the same timing problems while running an OTS Cobb map, does not make MHD OTS maps garbage and Cobb OTS maps the gold standard. Fallacy of composition.
10-01-2015, 09:57 AM | #11 | |
Rep 776
10-01-2015, 09:57 AM | #12 | |
Rep 776
10-01-2015, 10:30 AM | #13 |
Rep 554
That's not exclusive to MHD OTS maps. JB4, custom tunes, etc. I wouldn't pretend to know why given the variables particular to your car. Fuel, who knows. But again, while you may feel MHD OTS maps are garbage for your car for whatever reason, that certainly doesn't mean they are garbage period. Not unless everybody is reporting the same thing -- and they're not.
10-01-2015, 10:54 AM | #14 | |
Rep 776
Put my jb4 back on, issue gone. I'm not trying to bash mhd. Its an amazing flashing device. But considering I've tried almost all tunes available. MHD ots tunes were the worst. |
