What is beneath the rear passenger seat?
10-02-2015, 12:32 AM | #1 |
Rep 7,484
I know the low pressure fuel pump assembly is there somewhere for one... but is it on the rear passenger side? The reason I ask is whenever I have a passenger sat there... I can smell fuel! The smell usually goes away after a good five minutes but it is strong to the point that I need to ventilate by opening windows...
I have ordered some dye and a UV light... I think there may be a leak somewhere and this could explain why I have used 1/2 of fuel in 5 days rather than 1/4... no change in driving style, no air con on, tyre pressures spot on, traffic free journeying... Or could it be evap related? No codes... but I remember when my evap went on my S3 and I replaced it after 6 years at 64,000 miles. Well my N52B25 is now 8 years and near 80,000 miles. Thanks |
10-02-2015, 02:38 AM | #2 |
Rep 3,201
Drives: E92 325i MSport Coupe
The low pressure fuel pump controller is mounted behind the o/s rear seat. The access cover to the petrol tanks is under the rear seat. Sounds like your fuel pump/sender unit may be leaking where it fits into the tank.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
10-02-2015, 02:56 AM | #3 |
Rep 604
Personally I would not drive the car until it is sorted out. Seriously, you are taking a massive risk driving the car in that condition. Your phone could cause fuel vapour to ignite. Your cloths could cause a static charge. Wiring, the list goes on. Do yourself a favour and don’t drive it.
10-02-2015, 05:15 AM | #4 |
Rep 2,343
Yes you want to be sure this is sealed properly! Otherwise a spark\naked flame could cause the whole cabin to ignite like a cylinder! Plus your seats may be soaked in petrol
Check out a video entitled "NOS Leak Causes Flash Fire Inside Car When Passenger Lights a Cigarette"
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
