BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F21 OE underbody rear brace retrofit onto F20
      10-05-2015, 02:56 AM   #1
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
3 dr cars have a much better bracing between mid ships to fwd rear subframe connections. Installed the hardware below this week on my 5dr.
1 x 33326797099
6 x 33326764505 (or 07119907189 longer bolts if using m3/4 spacer, part no. 33312284647)
1 x 33326793651
1 x 33326793652
2 x 33306793892
2 x 33326796225
2 x 33306861221
I didn't get any photos - here's an extract from an F30post showing key extra F32 parts being swapped out on f30. Similar to what I did on my F20.
http://f30.bimmerpost.com/forums/sho...78&postcount=7
Components to be installed
F30 underside - f20 very similar and brace plate across transmission tunnel will be removed
As will these parts be removed
And replaced with these on both sides
How it will look when I'm done
Also I will re-use the f8x alloy cross bar de Item # 2 in the attached realoem page. Part no. 33312284647 and the longer bolts as a spacer / stiffener.
http://www.realoem.com/bmw/showparts...81&hg=51&fg=80
Best way to describe impact is its like having upgraded bushings in the rear subframe and rear suspension arms.
Much less flex when putting the power down on straight or out of a corner. Car feels more stable and less squirmy. Especially as I'm running Jb4 stg2 with ~ 400/460 crank power and torque c/w LSD.
On my regular commute this morning, there's a roundabout with my exit having a tight left immediately after the exit. Road was wet due to rain and 2 different road surfaces - grippy on the r'bout and shiny on the road with the tight left at the exit.
Normally, with a firm squeeze on the throttle, I get a tad of "hip wriggle" as the car's rear axle makes the transition from grippy to shiny surface. That's gone now with F21 underbrace and M3 x brace spacer.
BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      10-05-2015, 03:48 AM   #2
ovekvam
Norway
266
Drives: 2021 Galvanic Gold i3S
So that probably means that BMW regards the 5 door body significantly stiffer than the 3 door body, since they only reinforce the latter?
      10-05-2015, 04:21 AM   #3
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Not necessarily. I think it's more to do with weight reduction to help keep 5dr m135i in the same emissions bracket as 3dr m135i.
It's noticeable in terms of rear subframe location is more rigid than it was before fitting.
      10-05-2015, 05:37 AM   #4
ovekvam
Norway
266
Looking back at the E30, the 2 door version had less torsional rigidity than the 4 door version, but was also 20 kg lighter.
For the E36, BMW added reinforcements to the 2 door car, so the weight was the same. Now the torsional rigidity was also similar.
      10-05-2015, 05:54 AM   #5
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Maybe so. I drove a 3 dr and 5dr F2x back to back and felt 3dr was a bit more focussed than the 5dr.
All I can say is that with M135i with ~400/460 crank power/torque going thru my QLSD, this relative cheap mod, easy DIY bolt off and replace bolt on has my rear s/frame is now tied down a lot better with this OE brace than without it.
      02-08-2016, 03:39 AM   #6
pcfanta
Drives: M135i Manual
I'm planning on installing these including the F8x spacer.
Did you DIY it or get it installed?
If former, did you tighten the bolts to the specs that you can share?
I'm struggling finding the tightening torque specs...
      02-08-2016, 08:11 AM   #7
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
PCF,
An easy DIY job - all bolt off and bolt back on.
As for torque settings - Numbers relate to the diagram at the bottom of this post
No 5 - 108Nm
No 6 - 47Nm + 45 deg
No 17 - 24Nm
No 18 - 100Nm + 90 deg
BP
      02-08-2016, 03:26 PM   #8
pcfanta
PCF,
No 5 - 108Nm
No 17 - 24Nm
BP
Thanks Bee Pee
By the way, how did you get the numbers? Is there any service manual available for download in the forums?
      02-08-2016, 04:24 PM   #9
pcfanta
I just got a quote from a local dealer and the numbers are as ridiculously inflated as they usually are in Australia.
Bee Pee, do you mind if I ask how much all the parts set you back?
Can you give me the contact details of the dealer/seller?
      02-09-2016, 02:13 AM   #10
WAY
Australia
460
Drives: Fast ones
How much was it from your dealer pcfanta?
      02-09-2016, 02:35 AM   #11
pcfanta
AUD631 in total.
Also they don't have them in stock.
Honestly not 100% sure if this is a rip-off, but I heard OE parts are pretty cheap in EU and US even for beemers.
      02-09-2016, 04:26 AM   #12
WAY
Australia
460
Drives: Fast ones
Originally Posted by pcfanta View Post
AUD631 in total.
Give Southern BM a call. They may be cheaper!
      02-09-2016, 05:42 AM   #13
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
PCF,
Total parts cost was about 160 GBP here in the UK.
Bought mine from Cotswold BMW - parts dept contact is Phil Ennis. Have used this guys a lot and Phil is a top bloke so he might be able to give your a good price shipped to Oz.
Contact CotswoldBMWMini user as they are a forum sponsor, check here:-
http://f80.bimmerpost.com/forums/member.php?u=294804
Also a sponsor on BabyBMW.net forum too
http://www.babybmw.net/forum/viewforum.php?f=49
BP
      02-11-2016, 09:40 AM   #14
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
From another forum, which were provided originally by CotswoldBMW
As far as workshop/service manual - see below from Bentley's website but its not FoC
http://www.bentleypublishers.com/bmw...ir-manual.html
      05-18-2016, 11:15 PM   #15
Hoss1
Drives: 2014 F20 M135i
AUD631 in total.
Hi pcfanta
Did you proceed with this mod? If so, from where did you source the parts and how much?
Regards
Hoss
      05-19-2016, 02:58 AM   #16
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Hoss,
If not spotted already across on BB forum there's a good thread about the brace on M135i with lots of info and photos
http://www.babybmw.net/forum/viewtop...93&hilit=brace
You should also consider the OEM M4 front lower control arm upgrade....
http://www.babybmw.net/forum/viewtop...8&hilit=camber
BP
      05-19-2016, 05:46 AM   #17
Hoss1
Hoss,
BP
Hi BP
Thanks for the links. Most helpful as I haven't done much investigation about the braces or the M4 front lower arm upgrade.
Ian
Bee Pee1787.50
      05-19-2016, 06:10 AM   #18
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Theres now folk that have added M4 tension struts to compliment their M4 LCAs....
More details in the thread below:-
http://www.2addicts.com/forums/showthread.php?t=1250352
It can be a cash pit !!!
      05-19-2016, 06:19 PM   #19
Hoss1
Thanks for the pics of the M tension rods. Very nicely machined spacers.
You're absolutely correct about modding cars being a cash pit, BP.
Bee Pee1787.50
      10-30-2016, 04:57 AM   #20
GeeZee_SKG
Greece
11
Drives: F20 118i (MY2011)
Took the plunge and fitted the subframe braces. Works sweetness with the b8/eibach combo and ch-r 18ers . Good value for money this one. 184 euro in Greece VAT inclusive. Cheers!
Bee Pee1787.50
      10-30-2016, 12:51 PM   #21
1SolidF20
Drives: 118i M Sport
Price includes installation?
      10-30-2016, 12:54 PM   #22
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
£150/€200 and about hour labour
1addicts
