Codes after downpipe
10-06-2015, 09:03 PM | #1 |
Rep 1,173
So after installing downpipes within less than 40 miles driven i got a few codes... I was actually on my way to get e85 (3 gal) to get a test run vs a friends modded ISF when the SES came up.. I still continued to get the e85 because i was less than a mile away.. Anyways after the e85 the car sputters a bit more, pretty much drove home limp mode... Car isnt daily driven and i pulled codes tonight
2AAF- Fuel pump 29F4- cat converter conversion 29F5- Cat converter conversion 2 29cf - misfire cyl 3 2c77- lambda probe behind cat converter signal Car is 07 with 90k miles... Mods areas listed Dual conefilters BMS downpipes AR charge pipe/ tial BOV JB4 Used JB4 to pull codes, misfire i kind of suspected, had a thread about a very small minor sputter i would get ever so random at idle andwas told thats normal for this car, injectors were changed by dealer before so im chalking that up to coil pack or plugs... Now as far as the fuel pump could the other codes have triggered that?.. I actually think the pump was changed before when prev owner had car.. Thoughts?.. Downpipes need foulers??
02 A33 6mt maxima- sold (toy)
04 UA6 Acura TL- sold (my reliable baby) 07 N54 335i- the new adventure (i think) Last edited by Grand_hustle17; 10-06-2015 at 09:27 PM.. |
10-06-2015, 09:15 PM | #2 |
MR. Rocket
46
Rep 398
Drives: 2010 E92 335i M-Sport
How old are the plugs? If more than 10k, swap them. If that doesn't help, replace the coil packs. But I would log your car before going anywhere past those parts. In fact, do that first to see what's happening.
10-06-2015, 10:31 PM | #4 |
Rep 725
o2's swapped
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
10-07-2015, 07:38 PM | #7 |
Rep 971
Drives: Ducati Hypermotard
I also noticed a 29F4 and 29F5 code several days after catless DP install. From what I've read, they are common with catless DPs and do not affect performance at all.....just keep clearing them. Have you heard the same??
BMWCCA #454364
10-08-2015, 08:34 PM | #9 |
Rep 1,173
????... Should i?.. Guys that installed it are bmw pros.. Infact they had about 4 bmws in the shop.. E90's and a E60 M5... In fact they had a F10 M5 as well... They are well verse with this platform. In fact the mech owns a N54... So i would assume they did what needed to be done... Has anyone used anti foulers?
10-08-2015, 11:18 PM | #12 |
Rep 725
everyone makes mistakes just check and make sure they are not swapped
Then you can rule it out .
10-09-2015, 06:36 AM | #15 |
Rep 1,173
10-09-2015, 07:28 AM | #16 |
Rep 1,497
10-09-2015, 05:24 PM | #17 |
Rep 2,136
10-09-2015, 05:35 PM | #18 |
Rep 1,173
10-09-2015, 05:36 PM | #19 |
Rep 1,173
