E91 Rear wiper Seized
10-19-2015, 08:00 AM | #1 |
Rep 401
Looking for some help on my rear wiper, was just driving along one day and I noticed that the wiper hadn't gone back to the set start position after a wipe cycle. I moved the wiper back to where the start position then as soon as I attempted a wipe cycle it just went back to where it was..
I then came out of work one night and tried to wipe the rear screen and it didn't even attempt to move at all. Had it in for a service today at Bmw today and they notified it during their health check that the spindle is seized and a new one would be £180 blah blah... I imagine its a common fault on the tourings, is there a simple DIY I can do without getting a new one? Wayne. |
10-19-2015, 08:32 AM | #2 |
Rep 405
It's a common problem. You often see e91s with the rear wiper stuck up like that.
There is a little metal rod/pin on the underside of the glass connected to the wiper. It's on a spring and engages in the hole on a disc attached to the motor within the boot door. Your metal pin will likely be stuck in. You need to grip it with a pair of pliers and pull it out. Use something like wd40 or better and press in and out until it springs back freely. I always give the pin a couple of presses when I open the hatch so rust doesn't seize it up. |
10-19-2015, 08:53 AM | #3 | |
Rep 401
Had a quick search after I posted this and I found some similar info, think i'll go and have a look while i'm off work! Thanks for the info, see if I have any joy or i'll order a new motor for it and fit it myself. |
10-19-2015, 02:15 PM | #4 |
Rep 15
I had the same problem and found this, great write up with pics,
http://www.bimmerforums.com/forum/sh...Rear-wiper-fix! |
10-19-2015, 02:30 PM | #5 | |
Rep 401
10-20-2015, 03:36 AM | #6 |
Rep 405
The thing I use to remove rust on things like this where you don't want to disassemble everything is deoxit. Not the most obvious choice but it works. Then lubricate with somehting like bilt hamber's ferrosol which is magic.
10-20-2015, 03:37 AM | #7 |
Rep 405
You can easily test the motor by opening the lid and activating the wiper. You'll see the disc moving if all is ok.
10-20-2015, 03:09 PM | #8 | |
Rep 401
