Engine Malfunction N54 JB4 Tuned
10-25-2015, 12:24 PM | #1 |
Rep 116
I recently installed a JB4 on my stock 2009 335i xDrive with 86,000 miles. I also installed new Bosch spark plugs before installing the JB4. The install went smoothly, and the car started up fine afterwards. I drove it 1 mile before the Engine Malfunction light came on. I turned the car off, turned it back on, and it was gone.
I drove the car about a week or two with no issues. If I would go 50% Throttle while cruising (basically pushing in the speed but not enough to downshift), the engine light would come on. If I went WOT, no engine light and it ran well. This happened with Map 0, Map 1, and Map 5. Yesterday I turned the car on and immediately the Engine Malfunction (half orange engine) light came on. The car started fine, idled smoothly as far as I could tell, but it was super loud. The noise came from underneath the hood, sounds like the fan is running on high. There should be no reason for the fan to be running on a 50 degree day after the car just barely started. I tried turning off the car, switching from Map 1 back to Map 0, no change. The loud idling continued, and the car was in limp mode. This morning I try to start the engine immediately after inserting the key, it started, then died right afterwards. Tried starting again and it started fine. Idled a bit rough for a little while, smelled super gassy, the fan was on high, so i just turned the car off. Anyone have any ideas? Please? I've searched google and this forum, but I'm a BMW noob, just bought this car two or three weeks ago. |
10-25-2015, 01:19 PM | #3 | |
Rep 272
FBO , MHD , tuned
10-25-2015, 07:46 PM | #4 |
Rep 116
Ran the codes, got 3 of them...
30FF 2FBC 2D2E I inspected my charge pipe and it looks somewhat frayed/melted. So I'm ordering a new charge pipe as I write this, I think I'll be buying the Cobb charge pipe. Might also need a new HPFP? Any ideas? |
10-25-2015, 07:48 PM | #5 |
Rep 946
Don't buy the Cobb charge pipe! They are known for frequent fitment issues. The VRSF is quite similar in price and style but fits better.
10-25-2015, 08:01 PM | #6 |
Rep 116
10-25-2015, 08:21 PM | #7 |
Rep 946
10-25-2015, 10:02 PM | #8 |
Rep 5,776
If your fan is running like crazy that is a sign of a water pump failing, which can cause other odd things to happen.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
10-25-2015, 10:05 PM | #9 |
Rep 337
Try to cancel the cobb cp asap. If you can't, then return it as soon as you receive it. Don't even attempt to fit it, because if you marr it in any way, you might not be able to return it. Please save yourself and or your indy days of frustration. (ask me how I know )
If you search on here or google : cobb charge pipe fitment issues, you'll get a ton of hits. The VRSF pipe is cheap and fitment is perfect. |
10-25-2015, 10:17 PM | #10 | |
Rep 946
10-26-2015, 03:18 AM | #11 |
Rep 589
Drives: E90 M3/E92 M3
Just cancel the order or refund it.
I have the VRSF one and I can vouch for it. Stock charge pipes are known to go out anyways. |
10-26-2015, 02:57 PM | #12 |
Rep 249
You may have a turbo leak, and your turbos are probably working twice as hard to build the boost you need for low end pressure
10-26-2015, 07:44 PM | #13 |
Rep 116
Cancelled the Cobb charge pipe, ordered a VRSF charge pipe with Tial BOV and BMS Dual Cone Intakes. Not sure I should be modding the car since it's not even running well, but whatever.
I tried removing the JB4, and the car still ran exactly the same. So far the closest I've come to an idea of what the problem is, is that it might be the fuel pressure control valve? Any idea of how to fix/replace it, along with a DIY? Or am I barking up the wrong tree? I'm thinking maybe since the car is running so rich, that it's automatically turning the fan on high to prevent overheating? I'm starting to the think the charge pipe is not the culprit, but I guess it's good to replace it anyway. |
10-26-2015, 08:10 PM | #14 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Did you try clearing all the codes? Did you buy the jb4 used? Maxcool might be on causing the fan to always run at full speed. I believe 6/2 turns it off.
And the car running rich won't cause the fan to come on.. running rich actually causes it to run cooler. My advice is to clear the codes, try to drive it and take some logs when driving and then read the codes after to see if they come back. |
10-26-2015, 08:14 PM | #15 | |
Rep 116
On a side note, I did buy the JB4 used. Looks brand new, doubt there's anything wrong with it being used. |
10-26-2015, 10:22 PM | #16 |
Rep 3,475
The OBD2 scanner is useless. Hook the jb4 back up and select menu1/2 to delete the codes, then select 6/2 to make sure max cool is off. If the codes are still there (they would be if you only used the obd 2 scanner) then it could cause it so still not run right.
Do you know how to select those using the steering wheel controls? And I'm not saying something is wrong with it, the previous owner could have had max cool on causing the fan to run at full speed all the time. Lastly, it's also possible you water pump is failing, with increased boost comes increase stress on the water pump. It's not uncommon for the wp to go out if you're on the original with more than 60k to need a new one after tuning your car.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
10-26-2015, 10:23 PM | #17 | ||
Rep 272
FBO , MHD , tuned
10-27-2015, 12:25 AM | #18 |
Rep 649
Throw the JB4 away and switch to MHD, your tranny will thank you. Plus then you can do everything from your phone and feel confident that you have a real tune and not piggyback BS.
17 M3 Comp
10-27-2015, 07:34 AM | #19 |
Rep 337
30FF is boost leak, change the charge pipe and see if you still get this
2D2E can also be related to the charge pipe 2FBC might be a problem with your HPFP The best thing to do is to repair/replace the obvious problem first (your charge pipe). Then tackle the other items. When I first bought my car, I had a ton of different codes. Some were related to each other, while others were completely unrelated. The only way to tell, was to fix the known problem, then narrow things down. Trial and error, process of elimination. |
10-27-2015, 02:29 PM | #21 |
Rep 116
I contacted Burger Tuning about the issue, and they are suggesting I check my fuel rail pressure sensor. I will try to do that tonight, hopefully I can find some info about it on the forum so I know what to look for. He said it also could be a fuse for the fuel sensor, so I'm hoping that's all it is.
Tags |
engine malfunction, jb4, n54 |
