10-26-2015, 05:38 AM | #1 |
Rep 18
Does All F22 have Brake Energy Regeneration?
Hi Guys, as the title, is BER a standard feature with the F22 since it has the Eco mode?
http://www.bmw.com/com/en/newvehicle...ation.html#t=l As I'm thinking of upgrading the brakes.. and don't want to jump into this blindly |
10-26-2015, 06:36 AM | #2 |
Bright Sky
1165
Rep 922
Drives: BMW M235i (8AT)
As far as I know it's standard on every F22 and it's always "active", even in Sport(+).
But I could be wrong.
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
10-26-2015, 07:20 AM | #3 |
Rep 886
The term "Brake Energy Regeneration" in the 2-series refers to using a locked transmission to spin the engine with the fuel injectors off and the alternator loaded on. It is not what one would typically consider "brake regeneration", where you use generators at the wheels (functionally, electric motors in reverse) to convert kinetic energy to voltage.
Changes to the brakes will have zero effect on the process.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
10-26-2015, 07:28 AM | #4 |
Rep 893
As far as i am concerned the only thing that does is give me a cool effect on my instrument cluster
Current Car: Bicycle
Former Car:BMW i4 M50 Brooklyn Grey (MY22)| BMW i3s BEV (MY19)|Former Car: BMW X1 20d x-drive (MY16)|BMW m235i (MY14)|Former Car: BMW 120d (MY12)|Former Car: Volvo C30 T5 R-Design (MY08)|Former Car: Volvo C70 T5 (MY06)|Former Car: Volvo S40 2.0T(MY1999) |
10-26-2015, 10:15 AM | #5 | |
Rep 288
Done correctly, it can be beneficial, but done incorrectly (IIRC, the N63, for example, which in some vehicles require a new battery at each oil change), and it can suck. http://www.roadandtrack.com/car-cult...ns-bmw-n63-v8/ |
10-26-2015, 10:53 AM | #6 | |
Rep 886
The hoops the manufacturers are being made to jump through regarding fleet mileage may or may not be doing anything worthwhile on gas consumption, but they're sure as hell not increasing vehicle reliability.
10-26-2015, 12:17 PM | #7 |
Rep 862
Drives: '19 M2 '21 X5
Minimizing the time the alternator is engaged has more benefits than just fuel mileage. It also increases available engine power as the alternator isn't dragging on the system.
10-27-2015, 09:50 AM | #8 |
Rep 886
Sure, I just hate the way it's implemented. If they had a "Keep the battery charged and then unload the alternator" setup, I'd be all for it. The current "Let the battery run down, and charge it once the car starts to slow down" scheme doesn't do anything good for battery life, regardless of small mileage gains.
10-27-2015, 11:02 AM | #9 |
Rep 288
Car makers are all searching for new and innovative ways to meet the ever-increasing mpg requirements, which in a global viewpoint isn't such a bad thing in general.
Some ideas will work out, some won't. IMO, the jury is still out on this method of enhancing mpg. |
10-27-2015, 11:32 AM | #10 | |
Rep 2,010
When I read road test results on high performance cars, one of the first numbers I look at is average MPG. The majority of these 4 to 6 hundred + horsepower cars that can just barely beat our cars get poor MPG. So, bravo BMW for hitting a good balance.
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
