Best place to get a 335is clutch
10-26-2015, 11:44 AM | #2 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
10-27-2015, 01:13 AM | #6 |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
What about OEM flywheel to match? Where are you guys getting these at the best price?
10-27-2015, 05:50 AM | #7 |
Rep 1,093
I had to go to ebay for that. ECS use to have a good price on that but BMW must have raised the price because it went from like $500 to 1000 overnight (when oem prices go up ECS oem prices go up as soon as old stock is sold). I got a new in the box luk DMFW off of eBay for $550
10-27-2015, 02:09 PM | #9 |
BimmerPost Supporting Vendor
24477
Rep 191,448
Check the vendor section, lots of good deals
10-27-2015, 07:11 PM | #10 |
Rep 731
Drives: 2008 335i 6MT
How much hp/tq can the 335is clutch hold? Im sure it could hold anything you could throw at the stock turbos but when you upgrade the turbos and run 600+ will it still hold? I feel like since its such a labor intensive job it might be worth it to just do a SPEC clutch and flywheel and be done with it since they have been rated for tons of power/abuse.. but if I can get away with this one, why not?
2008 335i Coupe / Alpine White / 6MT / Fully Built Motiv Closed-Deck Motor / Motiv ST Kit / XR 105/69S / Motiv Twin Disc / VRSF 7.5 FMIC / ActiveAutowerke Exhaust / EOS Intake Manifold w/ 1050cc injectors / TiaL BOV / External VTA PCV / Quaife LSD / DSS Axles / KW V3Coilovers
10-28-2015, 12:05 PM | #11 |
Rep 385
I have 20k on my 335is clutch with a single mass flywheel and I'm a little under 600 ft lbs at the wheels.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
10-28-2015, 05:27 PM | #12 |
Rep 2,872
10-28-2015, 05:46 PM | #13 | |
Rep 2,189
The stock flywheel, well thats a different story but I'm a firm believer in matching the clutch to the general power area you want to be in, even if that means upgrading the clutch again down the road as you take a large step up in power and the stock DMFW is a good match for stock turbo power levels.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
