Buckled alloy
10-27-2015, 03:17 PM | #1 |
Rep 306
Buckled alloy
Hi people,
Whilst getting a new tyres fitted a noticed it was wobbling whilst being balanced. I'm guessing this means it's buckled and I just need a new one? Also will this effect the cars handling much? Thanks |
10-28-2015, 10:22 AM | #3 |
Rep 306
Well it was a mobile tyre fitter, he just said it was damaged, but he just said that because it was wobbling, he didnt check it or anything, sene a wheel on ebay for £30 so might just get a new that
10-28-2015, 11:01 AM | #4 |
Rep 686
There is a difference between buckled and dented.
buckled is where the centerline of the rim is skewed off the centerline of the bolt hub. dented is where there is a flatspot on the wheel. i had a buckled wheel it was too bad to balance out with weights. i used to get vibrations at around 50mph and 80mph. and it caused significant wear to the inside edge of the tyre. Mine was a rear wheel. if its front it may have different characteristics. but if you can replace it |
10-28-2015, 11:23 AM | #5 |
Rep 306
yeah i think i will, something doesnt quite feel right with the handling, at higher speeds it feels a bit loose if that makes sense, so ill get the new wheel and then the tracking done
10-29-2015, 06:06 AM | #6 |
Photographer
413
Rep 2,643
More likely the tracking is out than the wheel. If it balances fine you'll barely feel even a serious buckled wheel.
Yes it should be replaced especially if you've got a wheel style which is cheap. |
