10-30-2015, 09:33 PM | #1 |
Rep 99
Low fuel warning range accuracy
Just thought I’d share the results of my little driving experiment today. I will start by saying that I fully realise running a tank near empty is a stupid thing to do, but take this opportunity to learn from my idiocy.
I was driving around town in an area with lots of gas stations. My low fuel warning light had come on and I was curious how accurate the fuel range was and continued driving for a bit. I pulled into a gas station with my car estimating I could only go another 1 kilometer before running dry. My average MPG at the time was 21.5 (I say this as the range estimate varies depending on your current fuel economy). It took 48.5 litres of gas (12.8 US gallons) to fill the 52 litre tank (13.7 gallon tank). So there was less than a gallon of fuel left in the tank if the published specs are accurate. TLDR – Fuel gauge/range is pretty darn accurate, if it says you’re on empty you probably are. |
10-31-2015, 08:09 AM | #4 | |
Rep 282
It amazes me how this varies by manufacturer (and car?)
10-31-2015, 08:49 AM | #5 |
Rep 1,091
I'm sure BMW incorporated some 'idiocy factor' into the warning system, and you would continue for quite a distance even after it says zero. Or maybe not? BMW have started showing some symptoms of idiocy themselves lately
That said, I always fill mine up when the needle is around 1/4 of the tank, simply because with so many kilometers of virgin new motorways in Poland with gas station only catching up, a medium distance between them (particularly on those just finished stretches of new roads( can be as high as 70-80 km... With my driving style (180-200 km/h on a motorway is a norm; I consider myself extremely lucky with no speeding tickets since buying the M235i, and just one but earned with my R)...
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD |
10-31-2015, 09:15 AM | #6 |
Rep 99
Sorry, to clarify, the car starts warning you about your fuel state much earlier. The first warning comes when you're at about the 1/4 tank level and then the car starts nagging you when your range hits 30 miles/50 km. I just stupidly kept driving in spite of the warning and gassed it up on empty.
10-31-2015, 12:24 PM | #7 |
Rep 52
I've wondered this myself and would much prefer a 99% accurate "miles to empty" indicator than early warning. The gauge is perfectly legible so a warning when a quarter tank of gas is left is just an annoyance.
I haven't pushed it on this car but have driven 25 miles in my other car when the indicated range was "0 miles". I've driven down to just barely zero range in the BMW and still didn't quite reach 13 gallons when refueling. What are the potential issues of driving on empty besides getting stranded? Is there any mechanical issue (fuel pump, etc.?). |
10-31-2015, 12:30 PM | #8 |
Rep 893
Mine Aint accurate it warned me 90 km to empty tank, fueled it up it only took 40 liters from a 52 liter tank .
Current Car: Bicycle
Former Car:BMW i4 M50 Brooklyn Grey (MY22)| BMW i3s BEV (MY19)|Former Car: BMW X1 20d x-drive (MY16)|BMW m235i (MY14)|Former Car: BMW 120d (MY12)|Former Car: Volvo C30 T5 R-Design (MY08)|Former Car: Volvo C70 T5 (MY06)|Former Car: Volvo S40 2.0T(MY1999) |
10-31-2015, 02:23 PM | #9 | |
Rep 886
So, it would have shown 0 miles to go with about a gallon left in the tank, just like the OP. Now, mind you, I find that stunningly inaccurate, as opposed to what I think the general tenor of the thread to this point has been. Telling my I'm dry with a gallon left isn't doing me any favors.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
10-31-2015, 02:30 PM | #10 | |
Rep 75
Drives: 2015 228i MSport,THP, PP
Low Fuel Warning
VIDoug Vancouver Island
2015 228i MSport, THP, PP, MG |
11-01-2015, 06:41 AM | #11 | |
Rep 596
11-01-2015, 07:33 AM | #12 |
Rep 1,091
I agree in 100% - making the driver worry about his fuel being low too early is just yet another factor making driving under stress, which is never a good thing (it spoils the pleasure we're getting from driving those otherwise great machines, but above all it can distract us from any possible, much more important factors - thus negatively influencing the safety).
11-01-2015, 08:14 AM | #13 |
Rep 893
I think it should warn me when i have 5 liters left thats a LOT When you switch to comfort mode or eco mode thats more then enough for me to get to a gas station. Even When its run out out of fuel it will still go on on the gas fuemes that are left but after that your Done for it. :-D
11-01-2015, 10:16 AM | #15 |
Rep 893
I think you misunderstood me, i think its annoying when its warning me to early the tank is 52 liters the meter says 95 km to empty tank so when going to the gas station to fuel up it only fills up 40 liters that means I have 12 liters left so it's warning me too early. Wish it would do that when it's 5 liters left. That would be perfect.
11-01-2015, 12:14 PM | #16 | |
Rep 87
11-01-2015, 12:22 PM | #17 |
Rep 87
11-01-2015, 04:37 PM | #19 |
Rep 85
I've coded my car so it only shows low fuel once it reaches 50km. I've also ran my car to zero km left and could fit 50l of gas, yielding a buffer of 2-3 liters, or 20 or so km.
I think the furthest I've gone past this test is 10km and was fine. |
11-01-2015, 07:33 PM | #21 |
Rep 99
According to the manual the range is calculated based on your average MPG over the past 20 miles (30 km). Not sure how accurate the fuel level reading is.
11-02-2015, 07:47 AM | #22 |
Rep 87
