Help me diagnose my problem...misfire related
11-02-2015, 11:36 PM | #1 |
Rep 57
I'm getting misfires in multiple cylinders (2, 3, 5 and 6 if I remember correctly). It takes a while to start when cold but seems to fire right up when it is warm. Also, when I recently changed the plugs there was some oil on the threads of the plugs from cylinders 5 and 6. I'm not sure if the starting issue or having oil on the plugs are related to the misfires. The car runs fine and there isn't any stuttering or hesitation that I notice.
I just bought the car a few weeks ago so I'm not sure what maintenance has been done. I plan on having it walnut blasted in the next couple of weeks when a local member who does blasting on the side is back. I'd be surprised if it has ever been blasted and it has 64k on the clock. Your thoughts are appreciated. |
11-03-2015, 02:51 AM | #2 |
Rep 1,381
Sounds like it could be leaky injectors.
11-03-2015, 09:35 AM | #4 |
3442
Rep 79,211
Likely valve cover gasket, potentially cracked valve cover, plugs and injectors. I don't think it's just one of these.
It likely hasn't been blasted either. Inspect the valve cover thoroughly and look for oil seepage and cracks. That will need to be address and then you can change the plugs. If the plugs are still fouled with fuel it could be an indication of a leaky injector. With that kind of mileage those problems areas I listed first are all potentially on the way out. |
11-03-2015, 09:39 AM | #5 | |
Joint Chiefs of Staff
4927
Rep 116,037
Mike |
11-03-2015, 03:30 PM | #6 |
Rep 57
Thanks for the comments everyone. I replaced the plugs last week but it is still misfiring and taking a while to start. Based on your comments I will check the valve cover and gasket for leaks next and move to the fueling-related items after.
11-03-2015, 03:39 PM | #7 | ||
Rep 1,070
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
