help me with injectors going out one by one misfire
11-06-2015, 09:54 PM | #1 |
Rep 161
my plugs good
my coils good injector 4 stopped working i replace it did not code it yet but now injector 1 gives up and misfires can it be pump? my bimmer runs at about 18psi with tune after i replace valve cover gasket i started to have injectors problem one by one goes out any help please Last edited by Boss777; 11-07-2015 at 01:00 PM.. |
11-08-2015, 09:25 AM | #3 | |
Rep 350
Then index 11. So with 4 u should have replaced 4 5 6. And coded it. I would took. The extra injectors and swapped 1 out With the older injector. Fuel pump. Need to do some logs with Mhd and jb4 To see. U need to code these injectors. |
11-08-2015, 10:32 AM | #4 | |
Rep 161
my index is # 7 New one index 9 When I install new number 4 it worked but number 1 and 5 stopped working |
11-08-2015, 08:53 PM | #6 | |
Rep 922
11-08-2015, 10:16 PM | #7 |
Rep 161
all good i drove for about a 2 miles no lights i get all the power and then it started to shake and light came up code said low pressure cylinder 4 after i got new injector it all worked good for another mile till i get to gas station and then number one fail i got home and number 5 fail
11-08-2015, 10:18 PM | #8 | |
Rep 161
i dont get it one by one injectors go out |
11-09-2015, 02:26 PM | #10 |
Major Private First Class
450
Rep 1,327
Drives: 2010 E90 335i M Sport
Can I ask how you've identified these bad injectors? You said you replaced one and then found out the other ones are bad as well. How did you make this determination? How did you diagnose the first one? Are your plugs fouled? Smell like fuel?
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
11-09-2015, 02:31 PM | #11 |
Rep 922
It's worth noting that shortly after I replaced an index 10 with an index 9 to troubleshoot, I had the same misfires shortly after and injector 1 looked as bad as the injector 3 I had originally replaced.
11-09-2015, 02:37 PM | #12 |
3442
Rep 79,211
Ive tried myself to play the injector game. I ended up replacing all 6 injectors to index 12 and all head aches were gone.
Pull the spark plug on the offending bank and see how they look. If they are fouled up it could be an indication that the injector is weak too. Start with pulling the plugs. Its hard to tell if an injector is weak unless the spark plug is fouled, the injector tips are gunked up or the injector itself is louder then others. Only other way to really diagnose injectors is through INPA and it's not bullet proof either but you can look in the "System Status" "Rough Running Idle" area and look at the injectors for anomalies. I feel like im getting a head of myself here so sorry for the rant LOL. Anyway, if the plugs check out and you really think it's not the injector then it could be a need for walnut blasting on the intake valves. |
11-09-2015, 02:45 PM | #13 | |
Rep 350
don't forget to get new decoupling elements.. i wonder if injectors should be 100k wear item? |
11-09-2015, 10:13 PM | #14 |
Rep 161
11-09-2015, 10:15 PM | #15 |
Rep 161
once i replace injecgtor it started to work all perfect i went for a drive and #5 #1 stopped i switch coils and plugs still same i will try to get some codes
11-09-2015, 10:19 PM | #16 | |
Rep 161
ill try to get the codes from inpa but dont know how to get injector status |
11-09-2015, 10:53 PM | #17 |
Rep 161
just pulled this out from inpa
__________________________________________________ _________ $error locationNr: 11800 $error locationtext: 2E18 ignition, cylinder 1 570E2E18020013010828312E7B801200312E7D821500312E49 841400 Error: 2(11) No.: 11800 2E18 ignition, cylinder 1 frequency: 8 error type: 2 (4841 ) duration of combustion too short readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) P-Code: P1301 Ignition Monitoring Cylinder 1 Spark Duration Too Short F_LZ: 40 ambient text / entry at 100720 km(n.) 100720 km(2.) 100720 km(1.) coolant temperature OBD 33.00 °C 85.00 °C 83.00 °C voltage Kl. 87 13.41 V 13.20 V 13.00 V Engine speed 640.00 rpm 672.00 rpm 576.00 rpm spark duration cylinder 1 0.00 ms 0.00 ms 0.00 ms __________________________________________________ _________ $error locationNr: 11804 $error locationtext: 2E1C ignition, cylinder 5 570E2E1C020013050928312E7B811300312E7C821400312E51 7F1400 Error: 3(11) No.: 11804 2E1C ignition, cylinder 5 frequency: 9 error type: 2 (4841 ) duration of combustion too short readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) P-Code: P1305 Ignition Monitoring Cylinder 5 Spark Duration Too Short F_LZ: 40 ambient text / entry at 100720 km(n.) 100720 km(2.) 100720 km(1.) coolant temperature OBD 41.00 °C 84.00 °C 83.00 °C voltage Kl. 87 12.90 V 13.20 V 13.10 V Engine speed 640.00 rpm 640.00 rpm 608.00 rpm spark duration cylinder 5 0.00 ms 0.00 ms 0.00 ms __________________________________________________ _________ $error locationNr: 10701 $error locationtext: 29CD misfirings, cylinder 1 570E29CDA21003010528312EAF271E80312E4F3E2480312E52 3E2580 Error: 4(11) No.: 10701 29CD misfirings, cylinder 1 frequency: 5 error type: 2 (4097 ) exhaust fume causing damages after start procedure readines Flag: (16 ) Test conditions fulfilled error status: (33 ) failure presently not available, OBDon-board diagnosis debounced MIL - Status: (49) failure would cause warning lamp show light (MIL) P-Code: P0301 Cylinder 1 Misfire Detected F_LZ: 40 ambient text / entry at 100720 km(n.) 100720 km(2.) 100720 km(1.) Engine temperature 13.50 °C 11.25 °C 83.25 °C load value for misfire detection 24.22 % 24.22 % 15.23 % Engine speed 1184.00 rpm 1152.00 rpm 960.00 rpm Lambda integrator group 1 -0.00 % -0.00 % -0.00 % __________________________________________________ _________ $error locationNr: 0 $error locationtext: 7F2112 Error: 5(11) No.: 0 frequency: 0 error type: 9 (56 ) readines Flag: (56 ) error status: (56 ) MIL - Status: (56) P-Code: F_LZ: 6 ambient text / entry at __________________________________________________ _________ $error locationNr: 11803 $error locationtext: 2E1B ignition, cylinder 4 570E2E1B020013040128312E7C841600000000000000000000 000000 Error: 6(11) No.: 11803 2E1B ignition, cylinder 4 frequency: 1 error type: 2 (4841 ) duration of combustion too short readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) P-Code: P1304 Ignition Monitoring Cylinder 4 Spark Duration Too Short F_LZ: 40 ambient text / entry at 100720 km(1.) coolant temperature OBD 84.00 °C voltage Kl. 87 13.41 V Engine speed 704.00 rpm spark duration cylinder 4 0.00 ms __________________________________________________ _________ $error locationNr: 10700 $error locationtext: 29CC misfirings, several cylinders 570E29CCA21003000428312E4D248300312E4F7F8400312E50 7F8300 Error: 7(11) No.: 10700 29CC misfirings, several cylinders frequency: 4 error type: 2 (4097 ) exhaust fume causing damages after start procedure readines Flag: (16 ) Test conditions fulfilled error status: (33 ) failure presently not available, OBDon-board diagnosis debounced MIL - Status: (49) failure would cause warning lamp show light (MIL) P-Code: P0300 Random/Multiple Cylinder Misfire Detected F_LZ: 40 ambient text / entry at 100720 km(n.) 100720 km(2.) 100720 km(1.) ambient temperature 12.00 °C 11.25 °C 9.75 °C rail pressure 172531.75 hPa 172531.75 hPa 48906.64 hPa voltage Kl. 87 13.30 V 13.41 V 13.30 V counter recognition bad road 0.00 - 0.00 - 0.00 - __________________________________________________ _________ $error locationNr: 11801 $error locationtext: 2E19 ignition, cylinder 2 570E2E19020013020128312E7E821400000000000000000000 000000 Error: 8(11) No.: 11801 2E19 ignition, cylinder 2 frequency: 1 error type: 2 (4841 ) duration of combustion too short readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) P-Code: P1302 Ignition Monitoring Cylinder 2 Spark Duration Too Short F_LZ: 40 ambient text / entry at 100720 km(1.) coolant temperature OBD 86.00 °C voltage Kl. 87 13.20 V Engine speed 640.00 rpm spark duration cylinder 2 0.00 ms __________________________________________________ _________ $error locationNr: 11805 $error locationtext: 2E1D ignition, cylinder 6 570E2E1D020013060128312E7E821500000000000000000000 000000 Error: 9(11) No.: 11805 2E1D ignition, cylinder 6 frequency: 1 error type: 2 (4841 ) duration of combustion too short readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) P-Code: P1306 Ignition Monitoring Cylinder 6 Spark Duration Too Short F_LZ: 40 ambient text / entry at 100720 km(1.) coolant temperature OBD 86.00 °C voltage Kl. 87 13.20 V Engine speed 672.00 rpm spark duration cylinder 6 0.00 ms __________________________________________________ _________ $error locationNr: 11757 $error locationtext: 2DED power management, standby current control 570E2DED0804160F0828312E2A000071312E00000001312E00 000000 Error: 10(11) No.: 11757 2DED power management, standby current control frequency: 8 error type: 8 (4286 ) standby current violation readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) P-Code: P160F Powermanagement No-Load Current Error F_LZ: 40 ambient text / entry at 100720 km(n.) 100720 km(2.) 100720 km(1.) time with idle current 80 - 200 mA 0.00 min 0.00 min 627.20 min time with idle current 200 - 1000 mA 0.00 min 0.00 min 0.00 min time with idle current larger than 1000 mA 0.00 min 0.00 min 0.00 min voltage Kl. 87 0.00 V 0.10 V 11.48 V __________________________________________________ _________ $error locationNr: 10706 $error locationtext: 29D2 misfirings, cylinder 6 570E29D2A11003060228312E613A1580312E6E2F1680000000 000000 Error: 11(11) No.: 10706 29D2 misfirings, cylinder 6 frequency: 2 error type: 1 (4096 ) by means of fuel switch-off readines Flag: (16 ) Test conditions fulfilled error status: (33 ) failure presently not available, OBDon-board diagnosis debounced MIL - Status: (49) failure would cause warning lamp show light (MIL) P-Code: P0306 Cylinder 6 Misfire Detected F_LZ: 40 ambient text / entry at 100720 km(2.) 100720 km(1.) Engine temperature 34.50 °C 24.75 °C load value for misfire detection 18.36 % 22.66 % Engine speed 704.00 rpm 672.00 rpm Lambda integrator group 2 -0.00 % -0.00 % __________________________________________________ _________ |
11-17-2015, 12:53 PM | #18 |
Rep 161
Got 2 new injectors and installed 09 on bank 4 5 6 and all is good fixed still misfire when it starts you can hear from muffler and drawing sometimes jerks but check engine light went away and put down all the power
11-20-2015, 10:56 PM | #19 |
Rep 161
29D1 Misfirings, cylinder 5
29D2 Misfirings, cylinder 6 29D0 Misfirings, cylinder 4 29CC Misfirings, several cylinders 2E1B Ignition, Normal 2STEP/NLS code 0000 Unknown Fault again number 5 gives up and 6 leacky injectors just also any idea my 2 step does not work i try all the steps still no go any help |
11-21-2015, 09:53 AM | #20 |
Rep 3,553
You sure you installed them right? Were they new or used injectors? Did you code them? It's not a coincidence that the ones you replaced are the ones that aren't working correctly.
11-22-2015, 10:33 PM | #21 | |
Rep 161
well it said on ebay new never used they look like new but had some marks but not like installing marks i did install all correct but had some inpa issue coding it some errors popped |
12-01-2015, 01:16 AM | #22 |
Rep 161
I got two more new injectors one was leaky other one stop working so new ones in coded and wala all good but still got misfire drove all good and p0175 code came up and now new injector 5 stopped any idea my 2nd new injector stop
