Wheel Hop?
11-07-2015, 02:05 PM | #1 |
Rep 1,596
Wheel Hop?
Had an interesting encounter earlier.
I'm used to driving 4wd cars, and have driven 4wd cars for years. The E90 is my first RWD car, and i find it catches me out from time to time when i try to do certain things that 4wd cars just do without any drama. Applying power on the exit of wet roundabouts was something that would catch me out quite a lot, but i'm getting used to it now. Anyway today i'm driving to the shops in the lashing rain. Waiting at a roundabout, and it was one of those situations where traffic flows meant a constant stream of cars coming. I'd already waited for a while behind a bus, and now i was at the front. Saw a small gap and decided i'm having that and gave it a boot full. Not full throttle, perhaps half throttle but a good strong launch. What i expected was it to launch forwards with perhaps a small amount of slip which the ESP usually does a fine job of controlling. What actually happened was it spun the rear wheels, but then it all went rather odd. I've become used to the fact that you can just keep the throttle down and let the ESP sort out the available grip, except today it didnt seem to. It spun the wheels up, then you could feel the rear end almost bouncing across the road surface. It felt like wheel hop you get in a FWD car when you floor it and it transfers all the weight off the front end. The ESP didnt seem to sort it out and the car somewhat slowly crawled out onto the roundabout. I lifted a bit and it seemed to sort itself out and regain traction and off i went. I tried a similar launch at the next roundabout and it just did what it usually does with no drama. Is this perhaps a sign of worn suspension bushings in the rear end? |
11-08-2015, 06:43 AM | #3 |
Rep 1,596
Yeh perhaps, but i'd have expected it would just have spun the wheels in that case, not started hopping around. It was also noisey, bang bang bang as it lost and regained traction.
If you've ever driven an old leaf sprung RWD car and experienced axle tramp, it was similar to that. |
11-08-2015, 07:03 AM | #4 |
Rep 8,339
Wheel hop happens with large amounts of power. If you're stock it's more likely the road surface. It's not good to do as it's how drag racers snap axles.
11-08-2015, 08:57 AM | #5 |
Rep 1,596
Yeh its stock. Must have just been a weird quirk of the road surface i guess.
I can sure imagine it snapping axles, it felt and sounded bloody awful in the wet on road tyres. Must be horiffic to get that happening on drag radials and a prepped track with lots of power! I really just wondered if it was a sign that the rear suspension needs attention. The cars on 145k and the control arms on the front seem to be needing replaced, so i can imagine that bits out back also need looked at. |
11-09-2015, 03:54 AM | #7 |
Rep 444
I got this when doing a hard start in my 320d, never happened again until a couple months later it started doing it if I put my foot down round a corner on a dodgy surface and it turned out my rear shock had gone..
11-09-2015, 04:08 AM | #8 |
Rep 1,596
hmm! The shocks look like they've been replaced (they look new/rust-free and say "Sachs Pro-Touring" on them) but they may well be crap.
Will defo need to have a good look over the rear suspension i guess. Swapping winter wheels on soon, so i'll have a poke around then. |
11-09-2015, 04:36 AM | #9 | |
Rep 444
Since I've replaced mine they've been ok, although I'm starting to get a similar feel to before and I'm unsure whether this is the shocks gone straight away or the new shocks have caused something else to go Either way if you find anything keep us updated as I may look at it on mine soon! |
11-09-2015, 05:57 AM | #10 |
Rep 2,343
The bushings in the rear subframe are quite soft and can be upgraded to help but the best option is to secure the diff to the subframe. That'll directly reduce the wheel hop and reduce the chances of you snapping components like suspension and drive shafts.
I can supply kits for £160 to people in the UK. I just need to know if it's for a small or large diff. E9x (3 series) and E8x (1 series). Right now turn around would be a few weeks for machining. You were on the limit of grip on your tyres where they will either slip (wheel spin) or hop over the surface to relieve the pressure. By adding stiffer bushes and securing the diff to the subframe, less energy will be wasted in subframe flex or wheel hop. The large plate attaches to the diff and the arm connects to the bushing which mounts in the subframe reducing independent movement. Similar to
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
11-09-2015, 05:45 PM | #12 |
Rep 2,343
No brand name. I get them made by a machinist who is an expert in aluminum.
