E85
11-10-2015, 10:24 PM | #1 |
Rep 205
Drives: 2011 335i E90 AT M-Sport
E85
I have been running E50 in my car for a couple of months now and I curious how the 335i fuel system will hold up over time. Is the fuel system going to deteriorate prematurely running E85? Do you have any actual examples of fuel system component failures created by running E85? I am not looking for speculation or "BMW states this". I want actual facts, no BS. I love how the car runs on E50, I have total confidence in the car every time I hammer it on E50.
11-10-2015, 10:28 PM | #2 |
Rep 316
Do you have a tune on your car? Capable of logging? Log some WOT 3rd gear pulls and be sure that it's logging your lpfp. Send them to a tuner or on the forums here and then u will be able to see how your lpfp is holding up.
11-10-2015, 11:06 PM | #4 |
Rep 208
Man you cant run e85 in non flex fuel vehicle lol. No offense but your post sounds like a post from the year 2012. I pretty sure the consensus is yes you can run e85 and no it will not hurt anything.
11-10-2015, 11:28 PM | #6 |
Rep 398
I think what the OP is getting at is will long term E85 use have a deteriorating effect on parts when compared to non-E85 use.
Will the HPFP last x amount of kms on E85 compared to 91/93 octane fuel. As most know that are cars are capable of running E85 long term. |
11-10-2015, 11:54 PM | #7 | |
Rep 205
11-11-2015, 12:23 AM | #9 |
Rep 1,943
i don't run e85 and never have. but I'm just going to shape my coworker experience since all we do at work is talk about cars, mostly his set up lol, I'm a great listener lol. he's car ran into some issues 2 weeks ago do to the fact that his running e85 and some parts from his fuel system were corroded even when his set up cost over 40 grand and his total set is over 100k. just to give guys an idea he owns the fastest porsche in the world, currently making over 1800 whp. his tunner recommended that he run 1 full talk of regular gas at least once a month to clean the system because e85 is corrosive. hope that helps you.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-11-2015, 05:57 AM | #10 |
Rep 195
I have about 15000 miles on E60-70 without issue. I am well over due (8months) to run a tank of 93.
Wagner EVO II C | Akarpovic SS Evolution Exhaust | Cp-e DPs | Koni | CV5F Forgestar et 32/38 on 255/35/19 & 275/35/19 | DW400 | Swift spec R | N20 sensor | PB Valve Cover | GCL | M3 control arms | JE forged piston kit | Carillo forged rods | Ported Head | F80 DMFW |
11-11-2015, 06:11 AM | #11 |
Rep 841
I don't always drive my car so when I know it's going to sit in the garage for a while I will make sure I fill the tank up with straight 93 because e85 is corrosive and I as well don't want to prematurely deteriorate anything for no reason. It's not even a question that e85 is corrosive but like you said I have not seen anyone with our fueling system fall apart yet other than due to faulty parts.
11-11-2015, 06:28 AM | #12 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Over 2 years running E60+ and no straight 93 in over a year. Car is not daily driven and can sit a week or more in between drives. Zero issues related to fueling. Our cars are sold in markets abroad where E25 is common and no changes are made from the fueling system we get.
11-11-2015, 06:50 AM | #13 |
Rep 1,093
135k. Been running e30-40 since 70k. Not a single injector, line, pump or fuel system component has failed or needed replacing (at least since I've owned it).
11-11-2015, 07:08 AM | #14 |
Macgyver
208
Rep 942
For storage or a car that is sitting for weeks , you must use Stabil or other brand of E85 stabilizer. It stops the gasoline from separating from the ethanol. Ethanol attracts water and a spoonful of water can separate a gallon of e85. There are videos of this. That's the corrosive part as water is the item that can cause fuel pump lock-up. Fuel is the lubricant .
As for line deterioration , if you look at the fuel pump installs BMW uses nylon e85 compatible flex hose. In other areas there may be rubber hose that is compatible with e85 inside but not submerged. Up in the engine area, it's hard lines. Then there is the injector issues with e85 that some people have discovered that gunk up injectors. Some people have stated that it was like a syrup sticky mess. This can be combated with Lucas fuel cleaner for e85. It's so slick it helps the fuel pump lubricate, and the detergents clean the injectors. If it's any clue that I've lasted this long on series -01 injectors. That's all I know and I hope it's helpful.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
11-11-2015, 08:21 AM | #15 |
Rep 1,910
I Have ran ethanol mixes for 2 1/2 years straight; car hasnt seen a tank of just pump 93 gas that entire time either. car runs good.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
11-11-2015, 03:49 PM | #17 |
Rep 2,049
Our fuel lines are silicon based and can resist some corrosive behavior. I remember SteveAZ talked about this in the past.
The problem you may have is killing your LPFP if your demand is too high for it to keep up with the e85. That's why you need to log some runs and make sure the PSI doesn't drop below 50 or remain at 50. It's not about how much e85 you can run on a stock fuel setup it's about how you tune it. Running a stock setup will force the tuner to sacrifice midrange power(which is what the n54 is good at) An upgraded LPFP will allow the tuner to add more power. Now when I first started running e85 my HPFP died but that was a coincidence. Since last year I haven't had any issues with running e30 Cobb. E85 makes a night and day difference.
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
11-11-2015, 04:24 PM | #19 |
Rep 5,776
Ah..maybe that's why my car has needed and extra crank or two this week with the cold weather (40-50 degrees, which is cold by our Cali standards).
11-11-2015, 04:39 PM | #20 |
Rep 3,553
try doing it in 10 degree weather. embarrassing sometimes when it wont start on the 2nd/ 3rd time. Main reason im switching over to pump gas and meth, at least for the winter.
11-11-2015, 05:40 PM | #21 | |
Rep 272
FBO , MHD , tuned
11-11-2015, 10:35 PM | #22 | |
Rep 649
No offense to you, but your post is a perfect example of how misinformation gets spread.
17 M3 Comp
