DCT adaptations reset
11-18-2015, 11:05 AM | #1 |
Rep 2,343
Please,please,please,please,please! Can anyone help me figure out how to reset the DCT transmission (adaptations) using INPA?
I don't want to use the holding down the throttle method. I get these 3 options and can't read any of them? http://postimg.org/image/waqq2d2u5/ I have the V54 datens installed.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
11-18-2015, 04:33 PM | #2 |
Rep 74
I dont know the answer to your specific issue, however I will explain one I had recently which is very similar.
Although I had datens installed, I could not select my engine in INPA, none in the list I could read as I needed DDE 7.3 and it wasnt there. It was because I needed to add a line to the CFGDAT to tell INPA that was an available selection. Sounds like this is similar if your gearbox isnt in the list? Basically INPA wont update its lists based on the datens installed, you need to tell it they are there. http://www.e90post.com/forums/showthread.php?t=834032 |
11-18-2015, 07:52 PM | #3 | |
Rep 2,343
01-08-2016, 05:22 PM | #4 | ||
Ballin' out of control.
521
Rep 1,289
Code:
<JOB> <JOBNAME>STEUERN_ADAPTION_ZURUECKSETZEN</JOBNAME> <JOBCOMMENT></JOBCOMMENT> <JOBCOMMENT>Adaptionswerte Zurücksetzen</JOBCOMMENT> <JOBCOMMENT>( Service ID 0x30, Identifier 0x04 )</JOBCOMMENT> <JOBCOMMENT>Voraussetzung für ordnungsgemäße Funktion ist, dass</JOBCOMMENT> <JOBCOMMENT>man in Anschluss die Zündung abschaltet und den</JOBCOMMENT> <JOBCOMMENT>Steuergeräte-Abfall abwartet, damit die Defaultwerte</JOBCOMMENT> <JOBCOMMENT>im NVRAM abgespeichert werden.</JOBCOMMENT> <ARG> <ARGNAME>ADAPTIONSWERT</ARGNAME> <ARGTYPE>int</ARGTYPE> <ARGCOMMENT>Eingebe des Hexwertes</ARGCOMMENT> <ARGCOMMENT>0xA0 = Adaptionswerte Kisspoint K1</ARGCOMMENT> <ARGCOMMENT>0xA1 = Adaptionswerte Kisspoint K2</ARGCOMMENT> <ARGCOMMENT>0xA2 = Adaptionswerte Kupplungsmomentenkennlinie K1</ARGCOMMENT> <ARGCOMMENT>0xA3 = Adaptionswerte Kupplungsmomentenkennlinie K2</ARGCOMMENT> <ARGCOMMENT>0xB1 = Adaptionswerte für DRM</ARGCOMMENT> <ARGCOMMENT>0xB2 = Adaptionswerte des Semischlupfs für Gänge 1-7</ARGCOMMENT> </ARG> Quote:
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
CarAbuser475.00 |
01-12-2016, 06:15 AM | #5 | |
Rep 2,343
I'm at work at the moment but going to look into this tonight. Do I load up Tool32 and find the options inside? Pretty excited about this but I think I also want to update to the latest DCT firmware as mine is 2009 probably.
01-12-2016, 10:32 AM | #6 | |
521
Rep 1,289
If you're not familiar with Tool32, be cautious and don't randomly execute jobs by pressing Enter. Use the Job menu and select Start Job once only.
01-20-2016, 07:13 AM | #7 | |
Rep 2,343
What is the argument I need to provide? Thanks
01-20-2016, 09:42 AM | #8 | |
521
Rep 1,289
Code:
01-26-2016, 06:08 AM | #9 | |
Rep 2,343
01-26-2016, 08:39 AM | #10 | ||
521
Rep 1,289
10-21-2016, 09:50 AM | #14 |
Rep 2,343
Yes ISTA is actually quite easy and runs automated tests/checking. Under servicing.
04-29-2017, 09:11 AM | #16 |
Rep 1,600
The Tool32 method just seems to default everything. I personally wouldn't do it for long term use as it may cause excessive or premature wear of the clutches. I did it, it did make the shifts a bit more firm in manual mode but there was more hesitation from a standstill and in D it seemed to hold the gears/take longer to change gears. It may learn by itself over time but who knows how long.
On my car with 144k, i didnt want to chance it so after about 100km I hooked it up to ISTA/D and went through all the resets and calibrations. Some of them must be done with the engine running, foot on brake because it engages the gears to learn the characteristics of the shift valves. For those calibrations, i dont see how clicking reset with the engine off will do it correctly. There was also no mention of a specific drive pattern to follow after resetting everything in ISTA/D. So it's pretty much a drive in drive out affair I will post up the before and after printouts when i get back in a week. It shows the clutch actuation pressures, shift valve compensation and a few other things i dont remember at the moment. |
01-05-2018, 06:23 AM | #18 |
Rep 1,600
Yippy, sorry for the delay. I wont be able to upload for a while as i only have internet access via my phone. Can you PM me with your email and i will send them to you there
01-05-2018, 11:40 AM | #19 | |
Rep 2,343
As juld0zer says, you just load up ISTA/D and follow the instructions. Then it's all done. You just drive off and the transmission relearns as you drive again.
07-13-2018, 06:03 AM | #20 |
Rep 6
hi guys
i have flashed the 135is DCT software and then I wanted to re-train the transmission but have tried to relearn the DCT with Ista / D but I can only relearn the normal automatic not the DCT and now the car does NOT roll anymore when I go from the brake does anyone know the problem? thx |
07-13-2018, 09:07 AM | #21 |
Rep 2,343
I can't help. Never heard of this. Can you just do the dct relearn again on ISTA/D?
It's there. I've done it myself. I also have 135is flash on the transmission. Rolls forward when idle and off the brake.
