Oil temp too low with BMS diverter?
11-25-2015, 04:27 PM | #1 |
Rep 31
Hey guys. I was concerned about high oil temps (240-250 just seems too damn high) so I installed a BMS diverter valve. On a recent trip to Las Vegas, outside air temps were around 40-50˚F and with the oil constantly flowing through the cooler, my oil temps got pretty low, around 170˚ sometimes (downhill), cruising at around 2800 RPM / 80 mph on the freeway.
Now I'm concerned that these oil temps are too low. Any thoughts? |
11-25-2015, 05:28 PM | #3 |
Rep 494
Drives: '04 M3 & '07 X3 M-Sport
Terry makes great stuff, but his oil cooler "thermostat replacement" should be for track cars only. I think it's a terrible part for daily drivers especially in climates with freezing temps. The oil cooler shouldn't be operating at all times for best efficiency.
You should have gone for Andy Divers thermostat. I forget the exact temp, but it opens at like 180 or 190 I think (stock is something crazy high like 250 or maybe 235, I forget). Optimum oil temp is 212-220. P.S. 170 is much too low in my opinion. Needs to be 212-220 (water boils at 212 at sea level). |
11-25-2015, 06:08 PM | #4 |
Rep 31
Around town my oil temps are always good - usually 220-230, so the bypass is a benefit for that situation (I'm in SoCal so temps are usually on the warm side year round). It's only freeway cruising with cooler outside air temps that causes the oil temps to dip below 200.
Is there a spring available for the stock oil cooler thermostat that opens the valve at a lower temp? Stock opens at 240 - crazy high! I can't find any info on Andy Divers except on Facebook - hit him up there? Last edited by YRAGAEL; 11-25-2015 at 06:14 PM.. |
11-25-2015, 07:24 PM | #5 | |
Rep 494
http://www.ad-eng.net/store/p19/BMW_...hermostat.html Edit: considering you're in SoCal, you can probably get by on the bypass, but I think the lower temp t-stat will be perfect for you. I'm in Chicago, so I don't know exactly what kind of year round temps you get. We can't have the oil cooler running at all times here. The car will never reach operating temps during daily winter use. Last edited by C ///M; 11-25-2015 at 07:33 PM.. |
11-25-2015, 08:49 PM | #6 | |
Major Private First Class
450
Rep 1,327
Drives: 2010 E90 335i M Sport
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
11-25-2015, 08:55 PM | #7 |
Rep 1,473
That is a mod that you should really remove in the colder months and put the stock thermostat back in. That is what I do and it works great. I actually just took my BMS thermostat out this week.
11-25-2015, 09:28 PM | #8 |
Rep 3,148
Can't seem to find any technical information on the AD engineering thermostat.
So it looks like has more parts than just the BMS bypass. Is this an actual thermostat that opens at a lower temperature? If so what is the temperature? http://www.ad-eng.net/store/p19/BMW_...hermostat.html Has no other technical information I can see on the website
11-25-2015, 10:42 PM | #9 | |
Reborn
87
Rep 1,217
11-26-2015, 10:04 AM | #10 | |
3442
Rep 79,211
11-26-2015, 11:31 AM | #11 | |
Rep 494
Don't get me wrong, I like all of Terry's products, but something like this has a specific use. For most of the country that gets fluctuationing temperatures, it's just not a good part, unless you want to be swapping it in and out. That's why I like Andy's solution much better, best of both worlds (and he charges less for it). N54's should have come with a lower temp oil cooler thermostat from the factory, but you know how crazy BMW has gotten with efficiencies and emissions. Why not try to get [mention]andy_divers[/mention] opinion on it. Dude is awesome and knows his stuff. Edit: how do you mention people on this forum? |
11-26-2015, 11:32 AM | #12 |
Rep 31
Thanks guys. It sounds like the AD Engineering thermostat would be a good 'medium' between stock and the 'fully open' BMS diverter. Does anyone know what temp it is set to open at? Not sure why they don't list this info as it's the one question literally everyone would have about it!
Jeff thanks for the reassurance about my low oil temp concerns. I was afraid at 170 the oil might be too thick to flow as it should and put added stress on the pump and cooler. Oil temp paranoia! C///M just saw your post. I was also always under the impression that oil should be in the 200˚ range, but I am certainly no expert. I believe you are correct that BMW chose to run this engine so damn hot for emissions/mileage reasons.
2016 F80 M3 • Individual (1 of 1 in the US) Venetian Violet Pearl Effect • Silverstone Interior • 6sp. Manual • Carbon Roof • 666 Wheels
11-26-2015, 05:27 PM | #13 |
450
Rep 1,327
Man this is exactly what I need to control my temps! I can't believe more SoCal people don't use this part. This past Summer brought some brutal temps. I just ordered Andy's. Is he on these forums? I would like to know what temperature his opens up at too.
11-27-2015, 10:04 AM | #14 | |
3442
Rep 79,211
Oil viscosity is not any differnet at 150-170-190. For example my corvette never exceeds 170F ever on a day to day basis, even in summer heat. Only during an endurance run over 7 minutes above 120MPH with bursts to 170MPH did it near 195F oil then it quickly cooled itself well below 170 again. So I guess my engine is full of water and just wearing itself to pieces? I don't think so I'm all for looking over scientific data if you have any. |
11-27-2015, 10:10 AM | #15 |
Rep 6,478
170-200 is pretty standard operating procedure for most motors; the 54/55 series of motors run unusually hot. The 'exact' oil temperature for optimal use is unknown if we're being honest, clearly BMWAG felt 240-260 was just fine (which seems unlikely).
Think it's just important to properly define what the BMS unit is. It's not a thermostat, it's a thermostat delete. It removes the spring all together; oil is flowing through the cooler whether it's 20 degrees or 200 degrees. Andy's unit is a modified thermostat which opens at a lower temperature than the OE unit. It functions identically to the factory design, but introduces oil into the cooler at a lower temperature.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
11-27-2015, 10:15 AM | #16 |
Rep 951
So does anyone have any factual information or real world experience with Andy's?
I have the BMS delete and live in Florida, but during the winter months I feel that it takes a little too long to warm up.
11-27-2015, 10:26 AM | #17 | |
Rep 6,478
Motor reaches what i'd consider a safe temperature (180-190) for normal driving in the same amount of time as with the factory thermostat. Until you exceed the temperature at which AD's thermostat opens, the car functions and warms up 100% identically to stock.
11-27-2015, 10:28 AM | #18 | |
3442
Rep 79,211
IIRC most of these high running temps were simply for emissions purposes and reducing pumping losses. My point about cars rarely getting to 170F daily is true. The average Joe daily driving to work does not get enough heat in the motor to get oil to those temps. Of course many other factors will fall into play, engine size, N/A or Turbo, ambient temps ETC We also have a Porsche 911 Carrera 4s in the family and the only person to actually get that car to full operating oil temp was me after beating the snot out of it for 30 minutes. That temp was also 210. My mother who primarily drives it barely got it into the 150F range. I agree it's a moot subject on the thermostat delete. If you're in cooler temps simply remove it if you are worried. The modification was technically for "Race Applications" anyway. I'm not going to deny it's not good to get your oil temps up to temp, I'm a true advocate of waiting for oil to warm up but the difference between 170-190 is extremely negligible. Last edited by Jeff@TopGearSolutions; 11-27-2015 at 10:41 AM.. |
11-27-2015, 12:50 PM | #19 |
Rep 234
This seems like something i need!!!
My n54 gets extremely hot in heavy traffic. I feel my cars performance suffer too. Is there anything for us pre 03/2007 owners which operate in the same way andys does? |
11-27-2015, 01:25 PM | #20 | |
Rep 922
In addition, its not like everybodies running 20w50 in these engines. Last edited by theweebabySeamus; 11-27-2015 at 01:41 PM.. |
11-27-2015, 06:08 PM | #22 |
calibrator
12
Rep 80
If you're never getting the oil over 190F when you drive it, I sure hope you change the oil very frequently. Getting it past 90 C is essential in getting the fuel out of the oil, which is something that inherently occurs when you cold start a DI engine.
