Attention Oil Junkies
01-31-2006, 10:57 AM | #1 |
Rep 10,373
http://www.mr2.com/ARTICLE/Mobil1.html
On side note. Ne1 know if it's ok to use non-synthetic oil if you're going to change your oil every 5k miles? |
01-31-2006, 03:35 PM | #2 |
Rep 3,011
why would you? Cheaper? With the temp fluctuations, synthetic gives better viscosity and proetection throughout seasonal temp variation... even in
Hot-lanta
"Teach the ignorant. Ignore the stupid."
02-02-2006, 11:01 AM | #3 | |
Rep 10,373
You are correct. The reason why BMW uses synthetic and therefore recommends 15k oil changes is precisely due to the properties you mentioned. My arguement is that changing the oil on these cars every 3-5k miles negates the benefits of synthetic. I would even go so far to suggest that when the oil is changed that frequently (ie.3-5k miles) engine wear or lack thereof is exactly the same regardless of whether or not you use synthetic. If this is true, then why spend the $$ on synthetic if you're going to do more frequent changes. You could potentially cost yourself 2x the $ for no add'l benefit. I just don't know. |
02-02-2006, 11:23 AM | #4 |
Rep 889
I think using non-syn. oil would do more neg. that pos. even if u do change it more frequently. Just as it does damage to an engine such as the e90 if you use 87 octane instead of 93 octane. Plus its much cheaper! 15,000mi.=$80-$100 or 3,000mi.=$25-$30. Thats $125-$150 for regular oil changes, which makes synthetic oil changes much better.
02-02-2006, 12:49 PM | #5 | |
blaupunkt
56
Rep 525
Drives: 2008 335xi 6spman montego
BMW ENGINEERS |
02-02-2006, 01:07 PM | #6 | |
Rep 10,373
Naw..I what I'm trying to say is the reason why you use synthetic is to get prolonged change intervals. You're spending more $ on oil but changing the oil less frequently. If you're going to change the oil more often (3-5k miles) you're not realizing the full benefit of using synthetic. Am I making sense? |
02-02-2006, 01:09 PM | #7 | |
Rep 10,373
That's the thing..we just don't know. I believe BMW didn't switch to synthetic oil until they extended the change interval to 15k miles. I'd really like an Oil Guru to give us the lowdown. |
