n54 WG idea share what do u think
12-05-2015, 04:42 PM | #1 |
Rep 164
i was thinking of welding the flaper shut for turbos or disconnect vacuum line with zip tie to keep the arm from moving
its just an idea maybe someone did it?
BMS Dual intake system RB PCV Valve BMS Oil Catch Can BMS Oil Thermostat COBB FMIC COBB AccessPort V3 Aerodynamic kit M Package Cp-e BOV Cp-e 3" catless DP Wedge performance stg2 map
12-05-2015, 05:25 PM | #3 |
Rep 164
yes u r right i dont.. its just an idea came to my mind
12-05-2015, 05:40 PM | #5 |
Rep 841
How does an Internal Wastegate work?
The actuator of the internal wastegate is connected to a pressure only source which means that whatever the pressure is within the pressure side of the turbocharger compressor, the sealed chamber is also at the same pressure. As the pressure of the air being compressed by the turbocharger increases, the pressure within the sealed chamber of the actuator increases which applies a force on the spring. When the pressure is high enough to overcome the spring force, the wastegate valve begins to open, diverting exhaust gas around the turbine, allowing it to maintain its speed. If the pressure drops, then the spring pushes the valve shut and allows the turbine to build up speed. If the pressure increases, then the valve will open further, bypassing more exhaust gas to try to maintain the desired pressure. .....aka. You aint welding it shut ha |
12-05-2015, 06:00 PM | #6 |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
LMAO!
Research your next big idea before you cause more damage! You'll probably want to route exhaust back into intake next. |
12-05-2015, 06:25 PM | #8 | |
Macgyver
208
Rep 942
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
12-05-2015, 07:29 PM | #9 |
Rep 538
Welding it shut would probably cook your turbos and you'll be in constant boost and even over boost then most likely blow your rods through the block. I'd actually like to see this done to see how long it will last and what will happen.
12-05-2015, 08:54 PM | #10 |
Rep 319
Flapper closes to build boost then opens to regulate and control boost at boost target. Running closed all time would over boost and likely mess up something rather quickly
12-05-2015, 09:26 PM | #11 | |
Rep 710
Drives: 23 M3 Competition
12-05-2015, 09:26 PM | #12 |
Rep 841
12-05-2015, 10:49 PM | #15 |
Rep 868
Great idea..... YOU FIRST
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
12-06-2015, 01:15 AM | #16 |
Rep 164
okay guys now its clear no worries of some comments now i have good idea
